Block's Effective name conflicts with *U
This widget could not be displayed.
Hello Everyone!
Need some help on a code. The code works to pick on specific blocks and attout data but when other dynamic blocks goes in the mix it grabs those data as well, coz if the dynamic blocks parameters changed ACAD names it as *UXXX. I know I need to get the effectivename and tried to insert it to the code but I cant make it work. Please help!!!!
Here's the code:
(defun c:out-att ()
(load "attout")
(setq fna "C:\\folder1\\att.txt")
	(setq data   nil
	      bnames "blk01,blk02,blk03,`*U*"
	      ss     (ssget "_X"
			    (list '(0 . "INSERT") '(66 . 1) (cons 2 bnames))
	(repeat	(setq i (sslength ss))
	  (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
	  (if (and (wcmatch (strcase (vla-get-effectivename e)) bnames)
(bns_attout fna ss)
 Thanks in advance!!!!Smiley Happy
Replies (10)
hmsilva
Something like this perhaps
(defun c:out-att ( / bnames e fna i n o ss ss1)
  (load "attout")
	ss1    (ssadd)
  (if (setq ss (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 bnames))))
      (setq e (vlax-ename->vla-object (setq o (ssname ss (setq i (1- i))))))
      (if (vlax-property-available-p e 'effectivename)
	(setq n (vla-get-effectivename e))
	(setq n (vla-get-name e))
      (if (wcmatch (strcase n) bnames)
	(ssadd o ss1)
    (if	(/= (sslength ss1) 0)
      (bns_attout fna ss1)
  (princ)
HTH
Henrique
Hello Henrique,
Thanks for the reply! The code still grabs all dblocks with *U. Here's the original code:
(defun c:out-att ()
(load "attout")
	(setq data   nil
	      ss     (ssget "_X"
(bns_attout fna ss)
hmsilva
Revised...
  (load "attout")
	bnames "blk01,blk02,blk03"
	ss1    (ssadd)
  (if (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 (strcat bnames ",`*U*")))))
	(ssadd o ss1)
  (princ)
HTH
Henrique
It's not doing anything. No error message either. Its not re-writing to its designated directory.
it just goes like this:
Command: OUT-ATT
Command:
hmsilva
Did you change the block names and the directory to load the attout.lsp?
Henrique
Yes i did. it just simply jumps and no message when I press enter
hmsilva
Sorry, my bad...
(defun c:out-att (/ bnames e fna i n o ss ss1)
  (load "attout")
	bnames "block1,block02,blk03"
	ss1    (ssadd)
  (if (setq
	ss (ssget "_X"
		  (list (cons 0 "INSERT") (cons 2 (strcat "`*U*," bnames)))
    (progn
	  (ssadd o ss1)
  (princ)
HTH
Henrique
Your code worked perfect!!!!!Smiley Very Happy
Thanks Henrique!!!!!!!!!!
hmsilva
You're welcome, JCprog
Glad I could help
Henrique
unable to explode or edit block its name is *E
