Block insert function not working in 2021
4 REPLIES 4
murmanator
727 Views, 4 Replies
Hello, The code below is part of a larger program which I am having trouble with one aspect since upgrading to 2021 from 2013. The issue is on the "SDX" COND part. Im being prompted to enter the scale where I wasnt before. Im able to set the rotation but Im losing the layer part which is working on the other CONDs and the program is not finishing after I insert the block. I guess this is a syntax issue or maybe I need something else for that COND. The difference between the SDX and others is I need to be able to set the rotation of the SDX but not the others.
(command "layer" "off" "*" "n" "m" "PLUMBING" "")
(setq pt_ins (osnap pt_temp2 "mid"))
(IF (null typ)
(PROGN (INITGET "SDX MDX Superflow AquaStar")
(SETQ TYP (COND ((GETKWORD "\nSpecify Main Drain [SDX/MDX/Superflow/AquaStar] <AquaStar>: "))
("AquaStar")
(COND
((= TYP "Superflow")
(if pt_ins
(progn
(vl-cmdf "-INSERT" "PE_DRAIN-SUPERFLOW" pt_ins "1" "1" (angtos (angle pt_temp1 pt_temp2)) "2" "2" "0" "0"))))
((= TYP "SDX")
(if pt_ins
(progn
(vl-cmdf "-INSERT" "PE_DRAIN-SDX" pt_ins "S" 1 PAUSE PAUSE)))) ;;2021 fix scale prompt and dosent finish
((= TYP "MDX")
(if pt_ins
(progn
(vl-cmdf "-INSERT" "PE_DRAIN-MDX3" pt_ins "1" "1" (angtos (angle pt_temp1 pt_temp2)) "2" "2" "0" "0"))))
((= TYP "AquaStar")
(if pt_ins
(progn
(vl-cmdf "-INSERT" "PE_DRAIN-AquaStar" pt_ins "1" "1" (angtos (angle pt_temp1 pt_temp2)) "2" "2" "0" "0"))))
I had a similar issue with some dimensioning programs and worked it out by adding this:
(while (> (getvar 'CMDACTIVE) 0) (command pause))
but this did not help with this problem. Thanks for looking.
4 REPLIES 4
Moshe-A
in reply to: murmanator
@murmanator  hi,
first i reformat the code to make it easy for me to read,  hope you don't mind 😀
second i think the problem is in "PE_DRAIN-SDX" block something with it's definition or attributes existent  so without seeing it, can not exactly tell
Moshe
(defun c:xxx (/ insert_block ; local function
                savAttdia savAttreq)
 (defun insert_block (bname flag)
  (if pt_ins
   (if flag
    (vl-cmdf "._insert" bname pt_ins "_s" 1 pause pause)))) ;;2021 fix scale prompt and dosent finish
    (vl-cmdf "._insert" bname pt_ins 1 1 (angtos (angle pt_temp1 pt_temp2)) 2 2 0 0)
 ); insert_block
 ; here start c:xxx
 (setq savAttdia (getvar "attdia"))
 (setq savAttreq (getvar "attreq"))
 (setvar "attdia" 0)
 (setvar "attreq" 1)
 (command "._layer" "_off" "*" "_make" "PLUMBING" "")
 (if (null typ)
  (progn
   (initget "SDX MDX Superflow AquaStar")
   (if (not (setq typ (getkword "\nSpecify Main Drain [SDX/MDX/Superflow/AquaStar] <AquaStar>: ")))
    (setq typ "AquaStar")
   (cond
    ((= typ "Superflow")
     (insert_block "PE_DRAIN-SUPERFLOW" nil)
    ((= typ "SDX")
     (insert_block "PE_DRAIN-SDX" t)  ;;2021 fix scale prompt and dosent finish
    ((= typ "MDX")
     (insert_block "PE_DRAIN-MDX3" nil)
    ((= typ "AquaStar")
     (insert_block "PE_DRAIN-AquaStar" nil)
   ); cond
  ); progn
 ); if
 (setvar "attdia" savAttdia)
 (setvar "attreq" savAttreq)
 (princ)
); c:xxx
murmanator
in reply to: Moshe-A
Not saying there isnt something wrong with the block but this program works perfectly in 2013. Thats why I was thinking syntax issue and/or I just need something else in there for the pause part. In any case I have attached the block.
ВeekeeCZ
(vl-cmdf "-INSERT" "PE_DRAIN-SDX" "S" 1 "NON" pt_ins PAUSE)
murmanator
in reply to: ВeekeeCZ
Viola! That did it. Thank you so much!!!
Technology Administrators
