Block in SSGet
Block in SSGet
rvtquestions
Block in SSGet
rvtquestions
My intention is: user prompt pick block and that would inform an ssget filter. I am aware of this line of code:
ssget "_x" '((0 . "INSERT")(2 . "Blockname")))
however from my use of it, you have to manually type in the blockname and cannot reference a variable for example
(setq pt(cadr(entsel"\nSelect Block:")))
(setq e1(ssget pt))
(setq e2 (entget (ssname e1 0)))
(setq bname (cdr(assoc 2 e2)))
ssget "_x" '((0 . "INSERT")(2 . bname)))
Am I missing something fundamentally simple or can this not be done? I keep resulting in an error. Any help would be appreciated. Thank you!
ВeekeeCZ
' will not evaluate an expression. So use (list) and (cons) functions...
(ssget "_x" (list '(0 . "INSERT") (cons 2 bname)))
Added: actually if you scroll down the page you can find THIS THREAD where is this approach used many times....
Shneuph
Yes. It's the '( again.
http://www.lee-mac.com/quote.html
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
ВeekeeCZ
BTW Seeing the rest of the code... (ssget pt) You've got a kudos for that... I never know that's possible...
Usually the code would look like this...
(if (setq ensel (entsel "\nSelect Block: "))
  (setq bname (cdr (assoc 2 (entget (car ensel))))))
