Block attribute extraction
Gorra
Message 1 of 18
Gorra
I am trying to extract attributes from all copies of a specific block to csv. I found a very promising LISP by @ronjonp in a related thread, but it has a user selection via polyline, where I just always want the same block without the user needing select them (there's hundreds of copies per drawing).
I hope I just need to know where to change the selection method. The LISP is:
(defun c:foo (/ _writefile a e p r s z)
  ;; RJP » 2020-07-14
  (defun _writefile (fn lst / f)
    (cond ((and (eq 'str (type fn)) (setq f (open fn "w")))
	   (foreach x lst
	     (if (= 'list (type x))
	       (write-line
		 (apply 'strcat (mapcar '(lambda (z) (strcat (vl-princ-to-string z) ",")) x))
		 f
	       (vl-princ-to-string x)
	   (close f)
	   fn
  (cond	((and (setq e (car (entsel "\Pick fence for selection: ")))
	      (setq p (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget e)))
	      (setq s (ssget "_F" (mapcar 'cdr p) '((0 . "INSERT") (66 . 1))))
	 (sssetfirst nil s)
	 (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (setq a (vlax-invoke (vlax-ename->vla-object e) 'getattributes))
	   (setq r (cons (append (cdr (assoc 10 (entget e))) (mapcar 'vla-get-textstring a)) r))
	 (princ	(_writefile
		  (strcat (getvar 'dwgprefix) "BlockStuff.csv")
		  (append '((x y z attvals)) (reverse r))
  (princ)
(vl-load-com)
 Any help would be appreciated
Gorra
Replies (17)
Message 2 of 18
ronjonp
@Gorra
;; Replace this
;; With this
(setq s (ssget "_X" '((0 . "INSERT") (66 . 1) (2 . "YOURBLOCKNAME"))))
Message 3 of 18
Gorra
Thank you, that's what I was looking for
Message 4 of 18
ronjonp
You're welcome 👍
Message 5 of 18
Gorra
When I load the lisp, CAD says it loaded successfully but when I type it I get an 'unknown command' error. I checked the lisp in the built-in lisp editor, it gives a warning "local variable used as function: _writefile"
I checked other lisp functions and they are loading ok.
Message 6 of 18
ronjonp
@Gorra Weird .. this loads fine for me:
  ;; RJP » 2020-07-14
	   (foreach x lst
	       (write-line
		 f
	   (close f)
	   fn
  (cond	((setq s (ssget "_X" '((0 . "INSERT") (66 . 1) (2 . "YOURBLOCKNAME"))))
	 (sssetfirst nil s)
	 (princ	(_writefile
  (princ)
(vl-load-com)
Message 7 of 18
Gorra
Ok, I have finally gotten it to load by removing the _writefile from the list of variables, which my copy of Map3D didn't like (It loaded unmodified with another workstation, just not mine).
Instead of extracting attributes of all copies of a block to a csv, it is inserting a new copy of the target block. Is the insertion required for how this script works?
Gorra
Message 8 of 18
ronjonp
@Gorra Are you loading the code I provided? There is nothing in it that would insert blocks?
Message 9 of 18
Gorra
Ah. I wasn't matching the name of the LISP to the defun. Once I typed foo and had it work I clued in.
All working now.
To get the attribute names to extract for the top row of the csv, do I just add them to the list in the x y z ATTVALS?
Message 10 of 18
ronjonp
How would you take care of headers of differing blocks? If all your blocks are the same this is doable.
Message 11 of 18
Gorra
Yes, they're always the same block. They have 13 attributes, but don't need coordinates. If I put them into the line :
(append '((NAPNUMBER VACANT PREMISETYPE STREETTYPE STREETNAME NAPID ADDRESSID HOUSENUMBER F R B RSV 00_ID)) (reverse r))
would I need to change anything else? The attributes are all extracting currently, they just don't have headers.
Gorra
Message 12 of 18
ronjonp
Give this version a try .. it creates the header using the tagstring values.
(defun c:foo (/ a e h p r s z)
  ;; RJP » 2023-06-06
	   (foreach x lst
	       (write-line
		 f
	   (close f)
	   fn
  (cond
    ((setq s (ssget "_X" '((0 . "INSERT") (66 . 1) (2 . "*"))))
     (sssetfirst nil s)
       ;; Get the attributes
       ;; Compile a list of attribute values
       (setq r (cons (append (mapcar 'vla-get-textstring a)) r))
       ;; Create header of tagstring values
       (or h (setq h (mapcar '(lambda (x) (vla-get-tagstring x)) a)))
     ;; Write the file
     (princ (_writefile (strcat (getvar 'dwgprefix) "BlockStuff.csv") (append (list h) (reverse r)))
  (princ)
(vl-load-com)
Message 13 of 18
Gorra
Thanks @ronjonp, both versions run quite well. It turns out I do need the coordinates after all, so the first one is what I'm working with. (and thanks for adding comments, I'm starting to grasp how it all works)
The northing coordinate is in Canada, so is in the 5.5million meters range. It is coming into the csv rounded to the nearest 10, whereas I need it to 3 decimals. I've been digging through the command list & group codes for hours and can't find anything that specifies precision. Is there a switch/argument/code I can tuck in behind the attribute headers? No need recode, I'm trying to see if I can understand this well enough to reverse the process after the csv gets updated.
Message 14 of 18
Gorra
@ronjonp Hi, I'm still having some trouble with the precision problem, with the easting coming in rounded off to the nearest 10m. I've put the coordinates into a list called Lctn after doing an rtos with the right precision, but I can't figure out where in the cons line it should go. I've tried between the cons and append commands, and after the append command, with and without apostrophes. I just get bad argument type or too many arguments. Which doesn't make sense to me as the append is supposed to string lists together. I'm assuming I'm missing something obvious.
(defun c:MPTBLK (/ a e p r SelSet z SnapHold Northing Nrthng Easting Estng Lctn) ;; this lisp extracts the position        ;; and data fields of all MPT blocks in the drawing.
  ;; RJP » 2020-07-14
  (vl-load-com)
  (command _attdia 0) ; turnoff attdia
  (setq SnapHold (getvar 'osmode)) ; records current snap settings
  (setvar 'osmode 0) ; turns off snaps
  (setvar 'luprec 😎 ; sets significant digits to maximum
  (defun _writefile (FlNm lst / f)
    (cond ((and (eq 'str (type FlNm)) (setq f (open FnNm "w"))) ; While the file name is a string and the
        ; file is open for writing then:
   (foreach x lst
     (if (= 'list (type x)) ; if x is a list then:
       (write-line
FlNm
       ) ; end true
       (vl-princ-to-string x) ; end false
   ) ; end foreach
   (close f) ; close file
   fn
) ; end "and"
    ) ; end cond
  (cond ((setq SelSet (ssget "_X" '((0 . "INSERT") (66 . 1) (2 . "MPT")))) ; Selet all blocks named MPT
(sssetfirst nil SelSet)
(foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex SelSet)))
   (setq Northing (getpropertyvalue e "Position/X"))
   (setq Easting (getpropertyvalue e "Position/Y"))
   (setq Nrthng (rtos Northing 2 3))
   (setq Estng (rtos Easting 2 3))
   (setq Lctn (list Nrthng Estng))
) ; end foreach
(princ (_writefile
  (strcat (getvar 'dwgprefix) "MPTBLK.csv") ; passes to _writefile function as argument "FlNm"
  (append '((NORTH EAST z NUMPORT TAILLENGTH NAPNUMBER LIVESTART LIVEEND DEADSTART DEADEND LOCATION POLEID SPLICEID ADDRESS NAPID SPLICEORDER ADDRESSID )) (reverse r))
  ; passes to _writefile as argument "lst"
  (setvar 'osmode SnapHold)
  (princ)
Message 15 of 18
ronjonp
@Gorra
Try upping your precision from 3 to 16 for RTOS like so:
	   (setq nrthng (rtos northing 2 16))
	   (setq estng (rtos easting 2 16))
Also changing the LUPREC variable does not help with this problem. LUPREC changes the precision you see in the properties palette.
Message 16 of 18
Gorra
The numbers are coming out ok for precision with the 2-3, it's just a matter of getting the values into the list so they're included in the writefile. I thought this should work:
(setq r (cons (append 'Lctn (cdr (assoc 10 (entget e))) (mapcar 'vla-get-textstring a)) r))
but returns a bad argument
or this:
(setq r (cons (append (setq Lctn (list Nrthng Estng)) (cdr (assoc 10 (entget e))) (mapcar 'vla-get-textstring a)) r))
but still returns bad argument.
Sorry, the error was coming from a typo elsewhere in the code. There's a different problem but I'll make a new thread for it.
Message 17 of 18
ronjonp
@Gorra Try this .. although not sure why you're not using the code I provided above?
(setq r (cons (append Lctn (mapcar 'vla-get-textstring a)) r))
Message 18 of 18
Gorra
I didn't see the reply in time. That works just right. I'll see if I can cancel a post now.
Thank you
