Been a long time... Lisp routine for zoom > object > node
jjones1700
Message 1 of 13
jjones1700
I'm starting with a fresh computer, and for the life of me I can't find my lisp files where I normally backup to.  So, I am having to try to recreate them.  They are super simple, and I feel like an idiot for not being able to get this working.
I just want to type "zc" and be able to zoom to the center of a viewport by node.
(defun c:zc()
(command “zoom” "center" "node"))
Like I said, stupid simple.  What am I missing?  It either does nothing or I get an error for "node".
Replies (12)
Message 2 of 13
paullimapa
Node is an object snap to a Point object.  I assume you don’t want to do that. So what are you trying to zoom to the center of?
Paul Li
IT Specialist
@The Office
Message 3 of 13
Kent1Cooper
You leave yourself in the Zoom command under an Object-snap mode, waiting for a selection of a Point object or Dimension definition point or something that NODE-mode Osnap can snap to.  Does it work if you add a pause for that?
(defun c:zc ()
  (command “zoom” "center" "node" pause)
Or not, if it's leaving you at the:
Specify center point: node
of
point, where you can pick a NODE-Osnappable thing.
Kent Cooper, AIA
Message 4 of 13
jjones1700
I have borders set up with a point/node (centered within it) in model space to draw up various pieces of machinery (not to scale), in various stages of assembly.  Depending on what is needed, I go into the viewport and pan to the needed boundary, and then use zoom > center > node, in order to keep things uniform with the other sheets.
I know, it's bizarre, but it's an everyday thing.
Message 5 of 13
paullimapa
How’s about zoom center object then use osnap node for you to snap to the border point?
Paul Li
IT Specialist
@The Office
Message 6 of 13
jjones1700
For some reason, when I add the pause, I now get unknown command "CENTER" and unknown command "NODE".
Message 7 of 13
jjones1700
Before the drive crash, I could simply type "zc" and space (enter) and then pick the node and it would center to the node.  Wish I could find the original.
Message 8 of 13
paullimapa
Have you tried
(defun c:zc ()
  (command “zoom” "center"  “on” "node" pause)
Paul Li
IT Specialist
@The Office
Message 9 of 13
jjones1700
Paulli, that brings up unknown command errors for center, on, and node.
I know zoom and center are commands, but I can't figure out how to pass along what would be user input for the osnap.  Appreciate the help and suggestions.  Just frustrated and I know it's going to be something really stinking simple.
Message 10 of 13
paullimapa
ok, this should work:
(defun c:zc ()(command"_.Zoom""_O""_node" pause ""))
Paul Li
IT Specialist
@The Office
Message 11 of 13
jjones1700
Close!!!
I think I figured it out by changing the "_O" to "_C" in your last suggestion!
Thank you very much for the help!
This one is going to be backed up right now...
Message 12 of 13
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
Message 13 of 13
Kent1Cooper
I'm reminded of something -- I think "center" spelled out [or "cen" shorthand] is taken as an Osnap call, as if you wanted to Osnap to the center of something as a corner of a Zoom window.  Try it with just "c" or "_c".
Kent Cooper, AIA
