Hi all
I have got more than 100 dxf files - rectangular plates with some holes.
I would need to 1.delete the layer "YELLOW" elements. 2. Change all 8mm holes to 6mm holes.
Is there any way to do it with a script.
I am using Autocad 2024.
Thanks.
Solved by Sea-Haven. Go to Solution.
Yes
The script is to do a dxfin or an insert into current dwg or just open the dxf.
get all objects on layer "yellow " and delete or if acad "Laydel".
Then do a simple lisp to change all 6mm Circles to 8 mm use ssget with filter correct rad=6
Save new dwg with a name. Depending on 1st step method do new dxf.
Do you understand how to make a SCRipt.
No I don't.
With help from IA I have made the code below that works when you have the dxf file open, but I don't know how to make it work in automatic, looking for all the dxf files in a directory, open them, apply the lisp, save close them.
Thank you.
(defun c:modifyDrawing (/ ss ent lay rad)
(setq ss (ssget "X" '((8 . "yellow"))))
(if ss
(progn
(command "_.erase" ss "")
(princ "\nDeleted all entities in layer 'yellow'.")
(princ "\nNo entities found in layer 'yellow'.")
(setq ss (ssget "X" '((0 . "CIRCLE"))))
(if ss
(progn
(repeat (setq i (sslength ss))
(setq ent (ssname ss (setq i (1- i))))
(setq rad (cdr (assoc 40 (entget ent))))
(if (and (>= rad 3.9) (<= rad 4.1)) ; check for radius within tolerance
(entmod (subst (cons 40 3) (assoc 40 (entget ent)) (entget ent)))
(princ "\nChanged all 8mm holes to 6mm.")
(princ "\nNo 8mm holes found.")
(princ)
In simple terms a script is just a sequence of command including lisp.
It would look something like this so do manually and write down all steps including enter's which are spaces in a script or a new blak line.
dxfin "dxf1"
(load "mydxffixer")
(c:modifyDrawing)
save "DXF1"
close Y
dxfin "dxf2"
(load "mydxffixer")
(c:modifyDrawing)
save "DXF2"
Close y
There are various ways to get a list of dxf file names. I would look at Lee-mac script writer.
