batch plotting lisp
batch plotting lisp
batch plotting lisp
I am looking for lisp file, that print multiple drawing (Drawing that are open). Page set up must be Extent, Center the plot, Scale 1:1 (mm), Monochrome.ctb,  Landscape, and printer name.
Lisp file should read drawing title back (Which is Block- Name e.g.  A0_XXX,  A1_XXX,  A2_XXX,  A3_XXX,  A4_XXX,  b1_XXX) and automatically add above page set up.
I would really appreciate if anyone can provide me lisp file. Please send me lisp file so i can add printer name myself and rename title block name myself.
let me know if further explanation is required?
Thank you,
DP
john.uhden
Might all the drawings be associated with the same project, or drawing set?
If so, I strongly recommend your using Sheet Set Manager.  That way you can publish all the sheets at once, without even having them all open.
While I am pontificating, I also recommend that you publish to a DWF file.  Autodesk provides a FREE DWF viewer which also provides for adding mark-ups and searching the entire set for words or phrases.  I once had a project where I was concerned that I had not called out for the "removal" of various items.  In the DWF I was able to search for "remov" across all the sheets and verified that I had done my job correctly (whew).
Also, DWFs are about 1/3 the size of a PDF and can be plotted to PDF using freeware such as CutePDF, and with none of the problems of missing or excessive graphics.
John F. Uhden
