Batch Plotting 100+ A4 Layouts (Portrait & Landscape) from Model Space Using AutoLISP or Other Automation
sHubamyadav016
Message 1 of 12
sHubamyadav016
jhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhv,,,,,,vnbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbiuooooooooooooooooooooooooooooooo
Replies (11)
Message 2 of 12
sHubamyadav016
This is the drawing i have in autocad and this is potrait but in my case it can be potrait or landscape anything how can i print this suing auyolisp suggest some ways
Message 3 of 12
paullimapa
Message 4 of 12
paullimapa
Sheet sets only help if you have these on separate dwgs in Layout
In your case you have all A4 frames on a single dwg in Model
If your A4 frames are Blocks with Attributes that show unique a Sheet #, then it's also possible when generating the pdf to name by the sheet number. If not, then they'll be named by order of selection like dwgname-01, dwgname-02 & etc.
But to see what can be done share the following:
A sample dwg
Your lisp that you have developed so far that attempts to select and plot these A-4 size windows
Paul Li
IT Specialist
@The Office
Message 5 of 12
sHubamyadav016
Sorry Sir any solution for above problem
Message 6 of 12
paullimapa
refer to your OP
Paul Li
IT Specialist
@The Office
Message 7 of 12
Sea-Haven
You can use this maybe as a start, will need to be edited.
As you have not posted an example dwg a few questions, A4 is only output size ?. PDF required ?  Outlines are different sizes ? Do you want single pdfs or a single one ? Order of plotting is there something within a boundary like sheet number ?
Landscape or portrait that is ok.
Message 8 of 12
Sea-Haven
Posted twice see other post.
Message 9 of 12
sHubamyadav016
hjgggjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
Message 10 of 12
sHubamyadav016
yes output size is A4 YES PDF REQUIRED YES OUTLINES ARE DIFFERENT SIZES FOR EVERY OUTLINE SINGLE PDF YES ORDER OPF PLOOTING WITHIN BOUNDRY LINE
Message 11 of 12
avinash00002002
Is There equal distance between all horizontal and vertical distance. You want to create a PDF or direct printing from printer.
Message 12 of 12
paullimapa
 Please share an actual dwg with a few of these portrait or landscape rectangles
Paul Li
IT Specialist
@The Office
