Batch find and replace with wildcards
Message 1 of 10
I have projects that repeat the same steps every time I start up. A lot of these steps are find and replace based and can  contain wildcards. I'm having trouble finding the best solution whether it be a script to run find and replace that I can just press play on to run all the different steps I want or if a lisp routine would be best.
Please let me know what the best options available are.
Note: I did try Bfind and it would have worked great if it supported wildcards.
Replies (9)
Message 2 of 10
(defun C:TRC ; = Text Replace for Complete text/mtext strings, pre-defined content
  (/ tss tdata)
  (setq tss (ssget "X" (list (cons 1 "issued for tender"))))
  (repeat (sslength tss)
    (setq
      tdata (entget (ssname tss 0))
      tdata (subst (cons 1 "issued for construction") (assoc 1 tdata) tdata)
    ); end setq
    (entmod tdata)
    (ssdel (ssname tss 0) tss)
  ); end repeat
); end defun
 I have also found this lisp for a predefined find replace. Can someone show me how to add more find replaces to it?
an example of a wild card I'm having trouble with would be Find "###A!###A"  and replace with "!###A"
where number signs are wildcard numbers.
Message 3 of 10
Message 4 of 10
rkmcswain
So you have variable text on each project/sheet?
This is exactly what Sheet Set Manager can solve.
Message 5 of 10
ВeekeeCZ
THIS is what you need.
Message 6 of 10
It is all single line Mtext.
Message 7 of 10
I'm not sure that will help me I'm mostly looking for a script for find and replaces that can support wildcards.
Message 8 of 10
Valentin_CAD
Are you looking for something like this: JTB Batch Change for AutoCAD
Also search in the Autodesk App Store
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 9 of 10
Can you give me an example of how I would use this to accomplish the following wild card task?
Find "###A!###A" and replace with "!###A" where number signs are wildcard numbers.
Message 10 of 10
pbejse
is the replacement an entirely different value or a truncated version of the the target string ?
for example:
"I'm the the bowery king, 152A!657A of New York" to
"I'm the the bowery king, !657A of New York"
or
 "I'm the the bowery king, !234A of New York" <-- entirely different string specified by user prompt?
