Batch Bind DWG drawing sets in AutoCAD
tfitzhardinge
tfitzhardinge
Hi
I can batch etransmit dwg drawing sets via sheet set manager. How do I batch bind drawings? I am using AutoCAD 2016 and AutoCAD Civil 3D. Or if this cannot be done are there any free scripts or pluggins that can do this.
I made a macro that will bind all xrefs in the current drawing. Bind type 1 changes variable to Insert (as a block reference). Look up Bind vs Insert bind types.
^C^Cbindtype;1;-xref;bind;*;
Also refer to the attached pic. There is a setting in the Etrans menu that will Bind your drawings automatically. This setting should save when you do an Etrans thru SSM
tfitzhardinge
MRogoff
Sorry for the late reply. Your solution is perfect, thank you.
