Basic lisp question
Basic lisp question
Message 1 of 18
Basic lisp question
Hi everyone, i have a simple question i think, but i cant solve it.
Im tryin a routine that draw a polyline and then add a text.
I need first draw a polyline with some vertexs, end the command and then directly add a text (by this example, or any other command)
That i cant do, is the lisp let me end the polyline and then run the next command (Text or whatever)
If someone can help me, grateful
Thanks in advanced and regards.
Claudio
Replies (17)
Message 2 of 18
john.uhden
Please explain a little more. Do you want to add text that is associated with the polyline, as in maybe total length or length of each segment, or are you just trying to eliminate having to type in the Text command?
John F. Uhden
Message 3 of 18
Hi John.
The text that i want to add is fixed, is not a variable.
But i need to decide where the text are inserted then.
I need, to draw the polyline and then run another lisp (that i got, and must to modify) to add a text aligned to the polyline
The second routine woks like that.
"ATC" "" "n" "TEXT" "L"
is a macro
That i cant do is draw the poly and automatically starts the next command (ATC)
Claudio
Message 4 of 18
marko_ribar
Not sure, but try something like this :
(vl-load-com)
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "(defun pp nil\n(command \"_.PLINE\")\n(while (< 0 (getvar 'cmdactive)) (command \"\\\\\"))\n(princ)\n)\n(pp)\nATC\n\nn\n(defun tt nil\n(command \"_.TEXT\" \"L\")\n(while (< 0 (getvar 'cmdactive)) (command \"\\\\\"))\n(princ)\n)\n(tt)\n(setq pp nil tt nil)\n")
(princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 5 of 18
john.uhden
This might work...
(defun c:PL+ () ;; which stands for "Polyline Plus"
  (command "_.PLINE")
  (while (> (getvar "cmdactive") 0)(command pause))
  (command "ATC" "" "n" "TEXT" "L")
  (princ)
Now if ATC is just an AutoLisp command function, then in some global location, like acaddoc.lsp,
add the following to make ATC a real command... (vl-load-com) (vlax-add-cmd "ATC" 'c:ATC) Then the above PL+ should work. OR, if we can figure out just what you want to label and where, then we can build you a custom function
to do everything. It could even work by drawing all your polylines first and then labeling them all
with one command function. I have one for my pool liner client called AutoLabel that labels the lengths of all the polyline
segments that make up the separate panels of a vinyl liner.
John F. Uhden
Message 6 of 18
hi John, almost there....
Your routine works fine but when end the polyline, the cursor change like when windows are thinking, no buttons responses
instead mouse whell to change zoom and then start the second command (ATC)
The ATC command is like you say, other lisp routine. I add the 2 lines in a lsp that i have in trusted locations
I try to add the 2 lines in the PL+ routine itself and the same happend.
it almost ready, tha last help please??
And really thanks for the time.
Regards
Claudio
Message 7 of 18
john.uhden
Your symptoms don't make any sense. I just tried it (changing ATC to DTEXT) and it worked as expected. Then again, I'm running 2002. You're probably running a much newer version.
You shouldn't add the (vlax-add-cmd) to PL+. It has to be done outside and before.
Is the ATC code in text format or is it from a FAS or VLX? If you can post the ATC code we can incorporate it into PL+. to make it all work as desired.
John F. Uhden
Message 8 of 18
You are right John, works fine with other commands
ATC is another routine that i get from this forum. I paste the content
and the problem may be in this routine, but works fine outside PL+
Thanks again
Claudio
Spoiler
;;----------------------=={ Align Text to Curve }==---------------------;;
;; Program Overview ;;
;; This program enables the user to dynamically align a new or ;;
;; existing Text or MText object to a selected curve, with intuitive ;;
;; placement controls available. ;;
;; User Input ;;
;; Upon issuing the command syntax 'atc' at the AutoCAD command-line, ;;
;; the user is prompted to select a Text or MText object to align. ;;
;; At this prompt, the user also has the option to create a new Text ;;
;; or MText object, or configure the program settings. ;;
;; If the 'New' option is chosen, the user is prompted to enter the ;;
;; content for the new text object, or may press 'Enter' to return to ;;
;; the previous prompt. ;;
;; If the 'Settings' option is chosen, the user is presented with a ;;
;; dialog interface through which several program parameters may be ;;
;; configured - these settings are detailed in the section below. ;;
;; The user is then prompted to select a curve to which the text will ;;
;; be dynamically aligned. The program is compatible for use with ;;
;; Lines, LWPolylines, 2D (Heavy) Polylines, 3D Polylines, Arcs, ;;
;; Circles, Ellipses, Elliptical Arcs & Splines; furthermore, these ;;
;; objects may be primary or nested (to any depth) within a block or ;;
;; xref. ;;
;; Dynamic Text Alignment ;;
;; Following valid selection of a curve, the new or existing Text or ;;
;; MText object is dynamically aligned to the curve based on the ;;
;; position of the AutoCAD cursor. ;;
;; During text alignment, several controls are available at the ;;
;; command-line to refine the text position & other properties; these ;;
;; controls are individually detailed below: ;;
;; [ Enter ] - (or Esc/Space/Right-Click) Exit program (Cancel) ;;
;; [ Click ] - Place text ;;
;; [ +/- ] - Incrementally increase/decrease text offset ;;
;; [ O ] - Specify exact text offset ;;
;; [ </> ] - Rotate text by 45 degrees ;;
;; [ R ] - Specify exact text rotation (relative to curve) ;;
;; [ Y ] - Toggle text readability ;;
;; [ B ] - Toggle MText Background Mask ;;
;; Program Settings ;;
;; Upon selecting the 'Settings' option when prompted, the user is ;;
;; presented with a dialog interface offering the following options: ;;
;; Object type for new text: this setting determines whether the ;;
;; program will create a single-line Text object or MText object when ;;
;; the user opts to create a new text. ;;
;; Justification for new text: this setting controls the justification ;;
;; of any new text object created by the program. ;;
;; Text Offset Factor: this is the default offset factor of the text ;;
;; from the selected curve, as a multiple of the text height. This ;;
;; factor may also be zero if the text is to be positioned directly ;;
;; over the selected curve. ;;
;; Text Rotation: this setting controls the default rotation of the ;;
;; text relative to the selected curve. ;;
;; Text Readability: this toggle determines whether the text should ;;
;; be rotated to preserve readability, i.e. the text will never appear ;;
;; upside-down. ;;
;; Background Mask: this toggle controls whether a background mask is ;;
;; used when aligning MText objects. ;;
;; Multiple Text Mode: if this setting is enabled, the program will ;;
;; continuously generate text objects to align with the selected curve ;;
;; until the user exits the program. ;;
;; Notes ;;
;; The program is compatible with all full versions of AutoCAD ;;
;; supporting Visual LISP with ActiveX (COM) functionality (that is, ;;
;; AutoCAD 2000 onwards on a Windows OS). ;;
;; The program will perform successfully under all UCS & View ;;
;; settings and with Annotative Text Styles. ;;
;; Author: Lee Mac, Copyright © 2013 - www.lee-mac.com ;;
;; Version 1.2 - 12-10-2013 ;;
;; First release - previously 'CurveAlignedTextV1-1.lsp'. ;;
(setq atc:version "1.2")
(defun c:atc2
*error*
ang
bak
cfg
dcl def dis
ent enx
gr1 gr2
hgt
jus
mat msg mtp
nrm
off
pi2 prn prp pt1 pt2
red rot
sav sel str sym
tmp txt typ
uxa
(defun *error* ( msg )
(if
(and
(= 'list (type def))
(= 'str (type cfg))
(findfile cfg)
(atc:writeconfig cfg (mapcar 'eval (mapcar 'car def)))
(if
(and
(= 'vla-object (type txt))
(not (vlax-erased-p txt))
(vlax-write-enabled-p txt)
(if (= 'list (type prp))
(foreach x prp
(if (vlax-property-available-p txt (car x) t)
(vl-catch-all-apply 'vlax-put-property (cons txt x))
(vl-catch-all-apply 'vla-delete (list txt))
(if
(and
(= 'list (type mat))
(= 'ename (type ent))
(entget ent)
(entdel ent)
(atc:endundo (atc:acdoc))
(if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
(princ (strcat "\nError: " msg))
(princ)
(atc:startundo (atc:acdoc))
(cond
( (or (atc:layerlocked (getvar 'clayer))
(atc:layerlocked "0")
(princ "\nCurrent layer or layer \"0\" locked.")
( (null (vl-file-directory-p (setq sav (atc:savepath))))
(princ "\nSave path invalid.")
( (progn
(setq def
(typ . "txt")
(jus . "Middle-Center")
(off . 1.0)
(rot . 0.0)
(red . t)
(bak . nil)
(mtp . nil)
(setq cfg (strcat sav "\\LMAC_ATC_V" (vl-string-translate "." "-" atc:version) ".cfg")
dcl (strcat sav "\\LMAC_ATC_V" (vl-string-translate "." "-" atc:version) ".dcl")
(if (not (findfile cfg))
(atc:writeconfig cfg (mapcar 'cdr def))
(atc:readconfig cfg (setq sym (mapcar 'car def)))
(while
(progn
(setvar 'errno 0)
(initget "New Settings Exit")
(setq sel (entsel "\nSelect text to align [New/Settings] <Exit>: "))
(cond
( (= 7 (getvar 'errno))
(princ "\nMissed, try again.")
( (= 'list (type sel))
(setq ent (car sel)
enx (entget ent)
(cond
( (not (wcmatch (cdr (assoc 0 enx)) "TEXT,MTEXT"))
(princ "\nObject must be either Text or MText.")
( (atc:layerlocked (cdr (assoc 8 enx)))
(princ "\nObject is on a locked layer.")
( t
(setq txt (vlax-ename->vla-object ent)
prp (atc:getproperties txt)
nil
( (= "Exit" sel)
nil
( (= "Settings" sel)
(mapcar 'set sym (atc:settings dcl (mapcar 'eval sym)))
( (= "New" sel)
(= "" (vl-string-trim " \t\n" (setq str (getstring t "\nSpecify text <Select>: "))))
(not
(or (= 'vla-object (type txt))
(and (= 'str (type str)) (/= "" (vl-string-trim " \t\n" str)))
(atc:writeconfig cfg (mapcar 'eval sym))
( (progn
(while
(progn
(setvar 'errno 0)
(setq sel (nentselp "\nSelect curve to align text <Exit>: "))
(cond
( (= 'ename (type (car sel)))
(if
(not
(or (= "VERTEX" (cdr (assoc 0 (entget (car sel)))))
(not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getendparam (list (car sel)))))
(princ "\nInvalid object selected.")
(null sel)
( (not
(or
(and
(setq mat (caddr sel))
(setq ent (atc:copynested (car sel) mat))
(and
(setq ent (cdr (assoc 330 (entget (car sel)))))
(setq ent (car sel))
(princ "\nUnable to recreate nested entity.")
( t
(if (null txt)
(if (= "txt" typ)
(progn
(setq txt
(vla-addtext
(vlax-get-property (atc:acdoc)
(if (= 1 (getvar 'cvport))
'paperspace
'modelspace
str
(vlax-3D-point (trans (cadr sel) 1 0))
(atc:styleheight (getvar 'textstyle))
(vla-put-alignment txt
(eval
(cadr
(assoc jus
("Left" acalignmentleft)
("Center" acalignmentcenter)
("Right" acalignmentright)
("Middle" acalignmentmiddle)
("Top-Left" acalignmenttopleft)
("Top-Center" acalignmenttopcenter)
("Top-Right" acalignmenttopright)
("Middle-Left" acalignmentmiddleleft)
("Middle-Center" acalignmentmiddlecenter)
("Middle-Right" acalignmentmiddleright)
("Bottom-Left" acalignmentbottomleft)
("Bottom-Center" acalignmentbottomcenter)
("Bottom-Right" acalignmentbottomright)
(progn
(setq txt
(vla-addmtext
'paperspace
'modelspace
( (lambda ( box ) (- (caadr box) (caar box)))
(textbox
(list
(cons 01 (strcat str "."))
(cons 40 (atc:styleheight (getvar 'textstyle)))
(cons 07 (getvar 'textstyle))
str
(vla-put-attachmentpoint txt
(eval
(cadr
(assoc jus
("Top-Left" acattachmentpointtopleft)
("Top-Center" acattachmentpointtopcenter)
("Top-Right" acattachmentpointtopright)
("Middle-Left" acattachmentpointmiddleleft)
("Middle-Center" acattachmentpointmiddlecenter)
("Middle-Right" acattachmentpointmiddleright)
("Bottom-Left" acattachmentpointbottomleft)
("Bottom-Center" acattachmentpointbottomcenter)
("Bottom-Right" acattachmentpointbottomright)
(vla-put-height txt (atc:styleheight (getvar 'textstyle)))
(if bak (vla-put-backgroundfill txt :vlax-true))
(if
(and
(= "AcDbText" (vla-get-objectname txt))
(/= acalignmentleft (vla-get-alignment txt))
(setq prn 'textalignmentpoint)
(setq prn 'insertionpoint)
(setq hgt (vla-get-height txt)
pi2 (/ pi -2.0)
nrm (trans '(0.0 0.0 1.0) 1 0 t)
uxa (if (= "AcDbText" (vla-get-objectname txt)) (angle '(0.0 0.0 0.0) (trans (getvar 'ucsxdir) 0 nrm t)) 0.0)
msg (strcat "\n[+/-] for [O]ffset | [</>] for [R]otation | Readabilit[y] |"
(if (= "AcDbMText" (vla-get-objectname txt))
" [B]ackground Mask | <[E]xit>: "
" <[E]xit>: "
(princ msg)
(while
(progn
(setq gr1 (grread t 15 0)
gr2 (cadr gr1)
gr1 (car gr1)
(cond
( (or (= 5 gr1) (= 3 gr1))
(setq pt2 (trans gr2 1 0)
pt1 (vlax-curve-getclosestpointto ent pt2)
(if (not (equal pt1 pt2 1e-8))
(progn
(setq dis (/ (* hgt off) (distance pt1 pt2))
ang (+ (angle (trans pt1 0 1) gr2) uxa rot pi2)
(vlax-put-property txt prn (vlax-3D-point (mapcar '(lambda ( a b ) (+ a (* (- b a) dis))) pt1 pt2)))
(vla-put-rotation txt (if red (atc:readable ang) ang))
(cond
( (= 5 gr1))
( mtp
(setq txt (vla-copy txt)
prp nil
t
( (= 2 gr1)
(cond
( (member gr2 '(043 061))
(setq off (+ off 0.1))
( (member gr2 '(045 095))
(setq off (- off 0.1))
( (member gr2 '(044 060))
(setq rot (+ rot (/ pi 4.0)))
( (member gr2 '(046 062))
(setq rot (- rot (/ pi 4.0)))
( (member gr2 '(013 032 069 101))
(*error* nil)
nil
( (member gr2 '(089 121))
(if (setq red (not red))
(princ "\n<Text Readability Enabled>")
(princ "\n<Text Readability Disabled>")
(princ msg)
( (member gr2 '(066 098))
(progn
(vlax-put txt 'backgroundfill (~ (vlax-get txt 'backgroundfill)))
(if (setq bak (= -1 (vlax-get txt 'backgroundfill)))
(princ "\n<Background Mask On>")
(princ "\n<Background Mask Off>")
(princ "\nBackground mask only available with MText.")
(princ msg)
( (member gr2 '(082 114))
(if (setq tmp (getangle (strcat "\nSpecify Rotation <" (angtos rot) ">: ")))
(setq rot tmp)
(princ msg)
( (member gr2 '(079 111))
(if (setq tmp (getdist (strcat "\nSpecify Offset <" (rtos (* hgt off)) ">: ")))
(setq off (/ tmp hgt))
(princ msg)
( t )
( (member gr1 '(11 25))
(*error* nil)
nil
( t )
(if mat (entdel ent))
(princ)
(defun atc:readable ( a )
( (lambda ( a )
(if (and (< (* pi 0.5) a) (<= a (* pi 1.5)))
(atc:readable (+ a pi))
a
(rem (+ a pi pi) (+ pi pi))
(defun atc:styleheight ( sty / tmp )
(if (zerop (setq tmp (cdr (assoc 40 (tblsearch "style" sty)))))
(setq tmp (getvar 'textsize))
(if (atc:annotative-p sty)
(/ tmp (cond ((getvar 'cannoscalevalue)) (1.0)))
tmp
(defun atc:annotative-p ( sty )
(and
(setq sty (tblobjname "style" sty))
(setq sty (cadr (assoc -3 (entget sty '("AcadAnnotative")))))
(= 1 (cdr (assoc 1070 (reverse sty))))
(defun atc:copynested ( ent mat / enx tmp )
(if (= 1 (cdr (assoc 66 (setq enx (entget ent)))))
(progn
(atc:entmakex enx)
(setq ent (entnext ent)
enx (entget ent)
(while (/= "SEQEND" (cdr (assoc 0 enx)))
(atc:entmakex enx)
enx (entget ent)
(setq tmp (cdr (assoc 330 (entget (atc:entmakex enx)))))
(setq tmp (atc:entmakex enx))
(if tmp (vla-transformby (vlax-ename->vla-object tmp) (vlax-tmatrix mat)))
tmp
(defun atc:entmakex ( enx )
(entmakex
(append
(vl-remove-if
(function
(lambda ( x )
(or (member (car x) '(005 006 008 039 048 062 102 370))
(= 'ename (type (cdr x)))
enx
(006 . "CONTINUOUS")
(008 . "0")
(039 . 0.0)
(048 . 1.0)
(062 . 7)
(370 . 0)
(defun atc:getproperties ( obj )
(vl-remove nil
(mapcar
(function
(lambda ( prp )
(if (vlax-property-available-p obj prp t)
(list prp (vlax-get-property obj prp))
insertionpoint
textalignmentpoint
backgroundfill
rotation
(defun atc:settings ( dcl lst / *error* alg bak dch jus mtp off off:str red rot rot:str typ typ:fun )
(if (< 0 dch)
(unload_dialog dch)
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ)
(cond
( (not (atc:writedcl dcl))
(princ "\nDCL file could not be written.")
( (<= (setq dch (load_dialog dcl)) 0)
(princ "\nDCL file could not be loaded.")
( (not (new_dialog "atc" dch))
(princ "\nProgram dialog could not be loaded.")
( t
(mapcar 'set '(typ jus off rot red bak mtp) lst)
(set_tile typ "1")
(setq typ:fun
(lambda ( typ )
(setq alg (atc:justlist typ))
(set_tile "jus"
(itoa
(cond
( (vl-position jus alg))
( (setq jus (car alg)) 0)
(if (= "mtx" typ)
(mode_tile "bak" 0)
(mode_tile "bak" 1)
typ
(action_tile "jus" "(setq jus (nth (atoi $value) alg))")
(action_tile "txt" "(typ:fun (setq typ $key))")
(action_tile "mtx" "(typ:fun (setq typ $key))")
(set_tile "off" (setq off:str (rtos off)))
(action_tile "off" "(setq off:str $value)")
(set_tile "rot" (setq rot:str (angtos rot)))
(action_tile "rot" "(setq rot:str $value)")
(foreach key '("red" "bak" "mtp")
(set_tile key (if (eval (read key)) "1" "0"))
(action_tile key (strcat "(setq " key " (= \"1\" $value))"))
(action_tile "accept"
(vl-prin1-to-string
'(cond
( (not (distof off:str))
(alert "\nOffset Factor must be numerical.")
(mode_tile "off" 2)
( (not (angtof rot:str))
(alert "\nText Rotation must be numerical.")
(mode_tile "rot" 2)
( (setq off (distof off:str)
rot (angtof rot:str)
(done_dialog 1)
(if (= 1 (start_dialog))
(setq lst (list typ jus off rot red bak mtp))
(if (< 0 dch)
(unload_dialog dch)
lst
(defun atc:justlist ( typ / lst )
(start_list "jus")
(foreach itm
(setq lst
(append
(if (= "txt" typ)
"Left"
"Center"
"Right"
"Middle"
"Top-Left"
"Top-Center"
"Top-Right"
"Middle-Left"
"Middle-Center"
"Middle-Right"
"Bottom-Left"
"Bottom-Center"
"Bottom-Right"
(add_list itm)
(end_list)
lst
(defun atc:layerlocked ( lay / def )
(and
(setq def (tblsearch "layer" lay))
(= 4 (logand 4 (cdr (assoc 70 def))))
(defun atc:writedcl ( dcl / des )
(cond
( (findfile dcl))
( (setq des (open dcl "w"))
(foreach x
"edt : edit_box"
" edit_width = 8;"
" edit_limit = 10;"
" alignment = left;"
"atc : dialog"
" label = \"Settings\";"
" spacer;"
" : text"
" label = \"Object type for new text:\";"
" : radio_row"
" alignment = centered;"
" fixed_width = true;"
" : radio_button"
" key = \"txt\";"
" label = \"Text\";"
" : radio_button"
" key = \"mtx\";"
" label = \"MText\";"
" spacer;"
" : text"
" label = \"Justification for new text:\";"
" : popup_list"
" key = \"jus\";"
" spacer;"
" : edt"
" key = \"off\";"
" label = \"Offset Factor:\";"
" : edt"
" key = \"rot\";"
" label = \"Text Rotation:\";"
" spacer;"
" : toggle"
" key = \"red\";"
" label = \"Retain Text Readability\";"
" : toggle"
" key = \"bak\";"
" label = \"MText Background Mask\";"
" : toggle"
" key = \"mtp\";"
" label = \"Multiple Text Mode\";"
" spacer;"
" ok_cancel;"
(write-line x des)
(setq des (close des))
(while (not (findfile dcl)))
dcl
(defun atc:writeconfig ( cfg lst / _tostring des )
(defun _tostring ( x / dim )
(cond
( (= 'int (type x))
(itoa x)
( (= 'real (type x))
(setq dim (getvar 'dimzin))
(setvar 'dimzin 0)
(setq x (rtos x 2 8))
(setvar 'dimzin dim)
x
( (vl-prin1-to-string x))
(if (setq des (open cfg "w"))
(progn
(foreach x lst (write-line (_tostring x) des))
t
(defun atc:readconfig ( cfg lst / des itm )
(if
(and
(setq cfg (findfile cfg))
(setq des (open cfg "r"))
(progn
(foreach sym lst
(if (setq itm (read-line des))
(set sym (read itm))
t
(defun atc:savepath ( / tmp )
(if (setq tmp (getvar 'roamablerootprefix))
(strcat (atc:fixdir tmp) "\\Support")
(atc:fixdir (getvar 'tempprefix))
(defun atc:fixdir ( dir )
(vl-string-right-trim "\\" (vl-string-translate "/" "\\" dir))
(defun atc:startundo ( doc )
(atc:endundo doc)
(vla-startundomark doc)
(defun atc:endundo ( doc )
(while (= 8 (logand 8 (getvar 'undoctl)))
(vla-endundomark doc)
(defun atc:acdoc nil
(eval (list 'defun 'atc:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
(atc:acdoc)
(vl-load-com)
(princ
(strcat
"\n:: AlignTextToCurve.lsp | Version "
atc:version
" | \\U+00A9 Lee Mac "
(menucmd "m=$(edtime,0,yyyy)")
" www.lee-mac.com ::"
"\n:: Type \"atc2\" to Invoke ::"
(princ)
;; End of File ;;
Message 9 of 18
john.uhden
Wow, that's quite an extensive work of art by Lee Mac. I think it would be
improper to weave it into another piece of code without his permission. I
recommend your asking him for permission and for him to provide you with a
VLX version that does a (vlax-add-cmd). I say VLX because the DCL can be
included in the same file, and according to the help it is recommended.
OR... how do you really use it? Do you use all his options or maybe
perform the same operation every time? If the latter, then I am sure I
could write the code you need to align text with polyline segments, and
include it into PL+.
First, just for grins, try changing (command "ATC" etc.) to just (c:ATC).
John F. Uhden
Message 10 of 18
Yes you are right.
Massive work from Lee, an excellent routine.
I wil try to ask him about this problem in case he can help me.
The operation that i use is always the same.
I draw a Poly then insert a fix text aligned with a segment of the poly.
The thing is that the Lee routine is perfect about moving the text by the segments of the poly.
This is all that i need, but i ask Lee first, dont worry, PL+ is working fine only that i need to do is zoom with
the mouse wheel between commands. See the video.
Regards.
Claudio
Message 11 of 18
john.uhden
Merry Christmas to you too, but what is that contraption in the left picture, a proton accelerator?!
Anyway, as I said recently, try changing (command "ATC ...) to just (C:ATC).
John F. Uhden
Message 12 of 18
LOL..
in the .dwg?
there no more like shrinks and grill....jeje
Ok, i try (C:ATC) and works, but then ATC starts i need to "send" N and then the text "CPPN........"
In command mode my line are like this
(command "ATC" "n" "CPPN%%C110-PEND.1:60")(princ)
How can send this then??
Thanks.
Claudio
Message 13 of 18
john.uhden
How?
We would have to modify Lee Mac's code to accept arguments (which we would
have to figure out), or build our own.
I was very impressed by your video. Cool stuff.
John F. Uhden
Message 14 of 18
Hi Marko.
Thanks for the help but i take the solution from Jonh.
Thanks anyway again.
Message 15 of 18
John, Impressed with what? the dwg?
It´s really a very simple piece of architecture.
Ok i will try to set the arguments and inject the text with a variable
Message 16 of 18
john.uhden
I was impressed with the way the ATC function worked, realigning the text with every move of the pointer.  It's not that hard to program with the vlax-curve functions available.
If you're going to change Lee Mac's code, then I suggest you change its name... (defun ATC (arg1 arg2 etc.)).  It just feels more comfortable to call a function with arguments that is not a C: function.  I don't think I have ever seen a C: function that takes arguments.
John F. Uhden
Message 17 of 18
Thats what im saying, great great routine.
I solved finally. I inject the text with a variable. And set the options manually.
Works great now.!!
Thanks John for the help and time.
Message 18 of 18
john.uhden
I am very glad you have worked out a solution!
John F. Uhden
