Background mask toggle for MText
h_s_walker
Mentor Mentor
Message 1 of 12
h_s_walker
So I asked CHATGPT for a lisp which would toggle the background mask of mtext between off and on with a border of 1.2, and I got the code below
I tried it and I got the following error
Select MText to toggle background mask: ; error: bad DXF group: (71 . 1.2)
Can anyone fix this so it will work in AutoCAD LT2025?
(defun c:ToggleMTextMask (/ ent mtext bgMask bgMargin)
  ;; Prompt user to select a single MText object
  (setq ent (car (entsel "\nSelect MText to toggle background mask: ")))
  (if (and ent (= "MTEXT" (cdr (assoc 0 (entget ent)))))  ; Check if the entity is MText
    (progn
      (setq mtext (entget ent))  ; Get the entity data of the MText
      ;; Get current background mask status (bit 70)
      (setq bgMask (cdr (assoc 70 mtext)))
      ;; Toggle the background mask (0 = off, 1 = on)
      (if (= bgMask 1)
        (progn
          ;; Turn the background mask off
          (entmod (subst (cons 70 0) (assoc 70 mtext) mtext))
          (princ "\nBackground mask turned off.")
        (progn
          ;; Turn the background mask on and set margin to 1.2
          (entmod (subst (cons 70 1) (assoc 70 mtext) mtext))  ; Turn mask on
          (entmod (subst (cons 71 1.2) (assoc 71 mtext) mtext))  ; Set margin to 1.2
          (princ "\nBackground mask turned on with margin of 1.2.")
    (princ "\nSelected entity is not an MText object.")
  (princ)
Howard Walker
Left Handed and Proud
Replies (11)
Message 2 of 12
ВeekeeCZ
Would you post a sample dwg with 2 mtexts, with and without mask?
Message 3 of 12
h_s_walker
Drawing attached
Howard Walker
Message 4 of 12
Moshe-A
@h_s_walker hi,
ChatGPT almost hit the target 😀
unfortunately classic lisp is not enough to turn on/off mtext background fill you need activex
but to set the border offset factor (dxf code 45) you still need classic autolisp.
check this ...
enjoy
Moshe
(defun c:ToggleMTextMask (/ ent mtext bgMask bgMargin AcDbMText)
    (progn
      (setq AcDbMText (vlax-ename->vla-object ent))
      (setq bgMask (vla-get-backgroundfill AcDbMText))
      (if (eq bgMask :vlax-true)
        (progn
	  (vla-put-backgroundfill AcDbMText :vlax-false)
        (progn
	  (vla-put-backgroundfill AcDbMText :vlax-true)
          (entmod (subst (cons 45 1.2) (assoc 45 mtext) mtext))  ; Set margin to 1.2
      (vlax-release-object AcDbMText)
  (princ)
Message 5 of 12
marko_ribar
Not sure if LT has (vla-xxx) functions, but perhaps it has (set/get-propertyvalue) functions - it was introuduced back with R 2012 AFAIK...
So, try this revision...
(defun c:ToggleMTextMask ( / ent mtext bgMask )
    (progn
      (if (= (getpropertyvalue ent "BackgroundFill") 1) ;|(assoc 45 mtext)|;
        (setq bgMask 1)
        (setq bgMask 0)
      (if (= bgMask 1)
        (progn
          (setq mtext (vl-remove (assoc 90 mtext) mtext))
          (setq mtext (vl-remove (assoc 63 mtext) mtext))
          (setq mtext (vl-remove (assoc 45 mtext) mtext))
          (setq mtext (vl-remove (assoc 441 mtext) mtext))
          (entupd (cdr (assoc -1 (entmod mtext))))
          (setpropertyvalue ent "BackgroundFill" 0)
        (progn
          (setq mtext (append mtext (list (cons 90 1))))
          (setq mtext (append mtext (list (cons 63 1))))
          (setq mtext (append mtext (list (cons 45 1.2))))  ; Set margin to 1.2
          (setq mtext (append mtext (list (cons 441 0))))
          (setpropertyvalue ent "BackgroundScaleFactor" 1.2)  ; Set margin to 1.2
          (setpropertyvalue ent "BackgroundFillColor" 1)  ; Set color to 1 = red
          (setpropertyvalue ent "BackgroundFill" 1)
  (princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 6 of 12
h_s_walker
@Moshe-A once again you've hit the mark
Howard Walker
Message 7 of 12
ВeekeeCZ
It's similar to @marko_ribar apart from allowing to select multiple objects at the time.
(defun c:ToggleMtextMask ( / s i e)
  (princ "\nSelect mtext to toogle background, ")
  (while (setq s (ssget ":S" '((0 . "MTEXT"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i))))
      (if (= 0 (getpropertyvalue e "BackgroundFill"))
	(progn
	  (setpropertyvalue e "BackgroundFill" 1)
	  (setpropertyvalue e "BackgroundScaleFactor" 1.2)
	  (setpropertyvalue e "BackgroundTransparency" 0)
	  (setpropertyvalue e "UseBackgroundColor" 1)
	  (princ "\nBackground mask turned on."))
	(progn
	  (setpropertyvalue e "BackgroundFill" 0)
	  (princ "\nBackground mask turned off.")))))
  (princ)
Message 8 of 12
komondormrex
mod to your code. mask color, if enabled, set to the background color.
(defun c:ToggleMTextMask (/ ent mtext bgMask)
    (progn
      ;; Get current background mask status (group 90)
      (setq bgMask (cdr (assoc 90 mtext)))
      (if (or (null bgMask)(= 2 bgMask))
        	(progn
        	  (setq mtext (append mtext '((90 . 3))))  ; Turn mask on
        	  (entmod (append mtext '((45 . 1.2))))  ; Set margin to 1.2
        	(progn
			  (vlax-put (vlax-ename->vla-object ent) 'backgroundfill 0)
  (princ)
Message 9 of 12
ВeekeeCZ
If you wanted to see how promising your attempt at using GPTChat was...
GPT tested for the existence of a background based on the code 70... in fact it is 90 and 70 is undefined.
It set the offset margin with the code 71... in fact it is 45. 71 defines the text alignment.
See HELP
How much time did you spend on it? No change to succeed.
    (progn
      (if (= bgMask 1)
        (progn
        (progn
  (princ)
Message 10 of 12
h_s_walker
@ВeekeeCZ No time. I don't know lisp, so I asked CHATGPT to create it for me
Howard Walker
Message 11 of 12
Moshe-A
@ВeekeeCZ ,
Maybe ChatGPT creators did not have the time to update their knowledge database?! 🤣
Message 12 of 12
ВeekeeCZ
Then there is no value in trying to fix that mess. It's just more efficient to start from scratch. That's what I thought.
