Autonumbering rectangle (same height/length/orientation)
ccsmith25
Message 1 of 23
ccsmith25
I've already found a file what can add number in center of each selected rectangle. - see attachment (demo.lsp)
Unfortunatelly I am not an expert in autolisp so I would like to ask for some support.
Is it possible to modify the function to add the same number to each rectangulars where the height/width and orientation is the same?
The rectangulars are placed orthogonal. No 45° or any different orientation like 0°; 90°; 270°.
Thank you in advance for the answers.
Any help is greatly appreciated!
Accepted solutions (3)
Replies (22)
Message 2 of 23
pbejse
300x200 not the same as 200x300 correct?
Message 3 of 23
ccsmith25
It is correct. It is two difference elements.  ID1=300x200mm and ID2=200x300mm.
Message 4 of 23
pbejse
Was hoping you would say they are the same 😆 Its way more easy.
The additonal code could be really simple depending on how those Polylines were created @ccsmith25 . For now I will assume it was created the same way for all.
Message 5 of 23
pbejse
(defun c:demo (/ TxtHt	sn     ss     i	     e	    sum	   verts
		 ptList	p      RefData	     bbox   pts	   Len
		 Wid	l&W
  (initget 7)
  (if (and
	(setq TxtHt (getreal "\nEnter Text Height: "))
	(setq sn (initget 7)
	      sn (getint "\nEnter Start Number: ")
	(setq ss (ssget '((0 . "LWPOLYLINE"))))
    (repeat (setq i (sslength ss))
      (setq e	  (ssname ss (setq i (1- i)))
	    sum	  '(0 0)
	    verts (cdr (assoc 90 (entget e)))
      (setq ptList
	     (mapcar 'cdr
		     (vl-remove-if-not
		       '(lambda (x) (= (car x) 10))
		       (entget e)
      (foreach x ptList (setq sum (mapcar '+ x sum)))
      (setq p (mapcar '/ sum (list verts verts)))
;;  Because we are not sure how the LWPOLYLINES are created	;;
;;  pBe July 2020						;;
      (setq bbox (Vla-getboundingbox (vlax-ename->vla-object e) 'll 'ur))
      (setq pts (mapcar 'vlax-safearray->list (list ll ur)))
      (setq Len  (vl-princ-to-string (- (caadr pts)(caar pts))))
      (setq Wid  (vl-princ-to-string (- (cadadr pts)(cadar pts))))
      (setq l&W  (strcat Len "X" Wid))
      (entmakex
	(list
	  (cons 0 "TEXT")
	  (cons 10 p)
	  (cons 11 p)
	  (cons 40 TxtHt)
	  '(50 . 0.0)
	  '(72 . 4)
	  '(73 . 3)
;;  pBe July 2020						;;
	  (cons	1
		(cond
		  ((setq f (assoc l&W RefData))
		   (cadr f)
		  ((setq RefData (cons (list l&W (itoa sn)) RefData))
		   (setq sn (1+ sn))
		   (cadar RefData)
  (princ)
HTH
BTW: would you happen to know who the original author is?
Message 6 of 23
ccsmith25
Thanks for your solution. it is working properly. Could you modify the program to add 25 unit offset of the TEXT in height from the center?
I found the orignal LISP: https://www.cadtutor.net/forum/topic/46252-autonumbering-of-selected-rectangles/
Message 7 of 23
Kent1Cooper
EDITED:
I agree the bounding-box approach is better.  But I would do it before  the calculation of the midpoint for the Text insertion point. Then all this:
	    sum	  '(0 0)
      (setq ptList
	     (mapcar 'cdr
		     (vl-remove-if-not
		       (entget e)
can be replaced with just:
      (setq p (mapcar '/ (mapcar '+ (car pts) (cadr pts)) '(2 2 2)))
Kent Cooper, AIA
Message 8 of 23
ccsmith25
Can I ask for another favor?
Once the lenght and width are collected (l&W) we could also write this data.
Could you modify the output text to contain the id, width and lenght data in format: ID.1_L300xW500?
I appreciate your effort.
Thanks is advance.
Message 9 of 23
pbejse
@ccsmith25 wrote:
... add 25 unit offset of the TEXT in height
Is that 25% of the text height or 25 regardless of the text height?
Let me guess, you wanted the text rotated to 90% if W is longer than L?
Tell me before i post the modified code incorporating @Kent1Cooper suggestion for the TEXT insertion point.
Message 10 of 23
ccsmith25
Sorry for confusing. I meant that I would like to offset the position of text in height by 25 units (mm).
Also concatenate ID., length, width data in following form. No need to rotate the text. It is always positioned at 0°.
Thanks for your help in this matter.
Message 11 of 23
pbejse
Here you go [ refer to attached lsp file ]
Command: LabelTheBox
Enter Text Height: 25
Enter Start Number: 1
Select objects: Specify opposite corner: 3 found
HTH
Message 12 of 23
Sea-Haven
A suggestion or 2, search the text on a layer get last ID number. Its pushing my own wheel barrow the Multi getvals.lsp you can save a value for use in the dcl the default value just needs to be reset.
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(if (= ah-num nil) (setq ah-num "1"))
(if (= ah-txtht nil)(setq ah-txtht "2.5"))
(setq ans (AH:getvalsm (list "Enter values" "Text height" 5 4 ah-txtht "Enter start number" 5 4 ah-num)))
; do your thing then set ah-num and ah-txtht
Message 13 of 23
pbejse
@Sea-Haven wrote:
A suggestion or 2, search the text on a layer get last ID number...
You may have something there @Sea-Haven.
(setq existing (ssget "_X" '((0 . "TEXT")(1 . "ID.*_L*xW*"))))
Message 14 of 23
ccsmith25
I am grateful for you help. It is working very well.
Message 15 of 23
ccsmith25
Hi! Could you change the LISP to the result precision will be 0 instead of 0.0?
Is it possible to use MULTITEXT instead of TEXT? I would like to add a new line after ID.
Message 16 of 23
pbejse
Yes, easy. If your adding a new line as part of the MTEXT, then i guess you dont need that 25Omm offset??  What is the source /value of the new line?
Message 17 of 23
ccsmith25
No need the offset in this case.
The text format will be like below. Middle centered justify. In first line the ID. and the second one the dimension with 0 precision. (Example 792 and not 792.0).
Message 18 of 23
pbejse
 No problem.. here you go...
(entmakex
	(list
	  (cons 0 "MTEXT")
	  (cons 100 "AcDbEntity")
          (cons 100 "AcDbMText")
	  (cons 10 p)
	  (cons 40 TxtHt)
	  '(50 . 0.0)
	  '(71 . 5)
	  '(72 . 5)
	  '(73 . 1)
	  (cons	1
		(cond
		  ((setq f (assoc (setq size (strcat "L" Len "xW" Wid)) RefData))
			  (strcat "ID." (Cadr f) "\\P" size)
		  ((setq RefData (cons (list size (itoa sn) ) RefData))
		   (setq sn (1+ sn))
		    (strcat "ID." (cadar  RefData) "\\P" size)
Please refer to attached lisp file [ LabelTheBox 2.0.LSP ]
HTH
Message 19 of 23
ccsmith25
Thanks for your previous solution. It is working like a charm.
Hi! Does LISP allow to add two different text height in multitext like this below?
First row text height would be double than the second line.
Message 20 of 23
pbejse
You have exceeeded the maximum number of request.
Please deposit 40USD to this account
77 121 32 110 97 109 101 32 105 115 32 80 97 116 114 105 99 107 44 32 78 105 99 101 32 116 111 32 109 101 101 116 32 121 111 117 33
This time i will let you modify the code on your own.
Check the string on the  existing MTEXT you manually configured, look at the Contents value at Properties dialog.
make note of the formating. See if you can figure out the bit where the control for the mext height for the secondline
Hint: strcat
