Automating Wire Labeling in AutoCAD Electrical
joel_gaglia
joel_gaglia
Hello All,
In my current task we place component and draw wire as per circuit logic.
to complete schematic drawing we need to insert wire labels as well through programming.
 As I gone through AutoCAD Electrical API but not found any API to insert wire-labels.
In AutoCAD Electrical  there is command "AEWIRECOLORLABEL" (Wire colour / Gauge Labels ). When It run after selecting "Auto Placement" Option and Wires, Labels automatically place over the wire.
Can we  call this function via Programming by passing some variables to that command?
please suggest solution or any other way to achieve this task.
Ed__Jobe
The (command) function just takes a string as an argument. You can concatenate the wire label command with any arguments you need, including a space to simulate {Enter}, e.g.
(command "AEWIRECOLORLABEL " var1 var2 " ")
Ed
How to post your code.
