Automatically composite sheet expansion lisp
Hello to everyone. I am looking for lisp for automatic opening or bending. I added a sample picture.
Thanks in advance for help. Smiley Sad
Kent1Cooper
Welcome to these Forums!
It's not clear to me what the relationship is between the two parts of your image.  Can you elaborate?
I'm just guessing, but I expect AutoCAD may not be the best program for what you're after -- Inventor is more likely to have such capabilities [but I'm not a user, so what do I know?], and it may be worth your while to look around over at the Inventor Forums.
Kent Cooper, AIA
Cevap için teşekkürler. Bir lisp düşünün. Dikdörtgen çizdiğimde bu lisp'i çalıştırıyorum ve dikdörtgen otomatik olarak açılışını çiziyor. Resimde sol taraftaki ölçülen dikdörtgen. Sağdaki üretim için lisp'in sonucudur. Dikdörtgen yapacağım çizimim lisp imalatı olabilir.
When it closes it becomes a mountable box.
Automatic aluminum sheet expansion lisp ?
Kent1Cooper
I understand that about the right part of the image.  What is the left side?
Kent Cooper, AIA
