Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Automatically Change Sheet Name?
BenCads
BenCads
Hello everyone, I've been trying to get the publish command to work and I am just about there. I'm wondering if there is a way to have my sheet names match the dwg file name and then save the pdfs to the dwg files location.
For example, in the screenshot I posted, I would like for the sheets to say
  1. test-door1
  2. test-glass1
  3. test-door2
  4. test-glass2
then save to the dwg's file location.
Any help is appreciated, Thanks!
maratovich
Maybe this will help you - Revers
You can specify any file name. See print or publish settings tab
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
BenCads
do you have a trial version?
pbejse
You should be able to do that with publish using Sheet set manager. BTW, where is the screenshot you're referring to ?
maratovich
Yes, of course.
A strange question, if you open the site, then it says there ...
www.kdmsoft.net
BenCads
Whoops, added the screen shot @pbejse
@maratovich appreciate the help but didn't quite like revers.
Sea-Haven
If your plotting 1 dwg then yes can have dwgname+layoutname, extras are plot range of layouts, plot to dwg location, plot individual and a single pdf with multiple pages.
Does not do multi dwg's and title blocks need to be consistent in layouts.
