Automatically Change Sheet Name?
BenCads
BenCads
Hello everyone, I've been trying to get the publish command to work and I am just about there. I'm wondering if there is a way to have my sheet names match the dwg file name and then save the pdfs to the dwg files location.
For example, in the screenshot I posted, I would like for the sheets to say
  1. test-door1
  2. test-glass1
  3. test-door2
  4. test-glass2
then save to the dwg's file location.
Any help is appreciated, Thanks!
maratovich
Maybe this will help you - Revers
You can specify any file name. See print or publish settings tab
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
BenCads
do you have a trial version?
pbejse
You should be able to do that with publish using Sheet set manager. BTW, where is the screenshot you're referring to ?
maratovich
Yes, of course.
A strange question, if you open the site, then it says there ...
www.kdmsoft.net
BenCads
Whoops, added the screen shot @pbejse
@maratovich appreciate the help but didn't quite like revers.
Sea-Haven
If your plotting 1 dwg then yes can have dwgname+layoutname, extras are plot range of layouts, plot to dwg location, plot individual and a single pdf with multiple pages.
Does not do multi dwg's and title blocks need to be consistent in layouts.
