Automatically add a row that sums the table
aitorm
aitorm
Hi!
There is a process I repeat tons of times and would be amazing if you could help me automatize: I usually do dataextraction to create carpet area tables, but after it is created I need to add a total cell that sums all the value columns. This is how I do it (and would like it to be):
— Adds a new row at the bottom of the table and unlocks it
— Let you choose the column that I want to sum (normally B but it can be C or D)
— Create a sum formula that is =SUM(B3-BX), beeing X all the arrows of the table -1
[%<\AcObjProp Object(%<\_ObjId xxxxxxxxxxx>%).Rows>% - 1]
— Change its format to 2 decimals and m² as a sufix.
Could you help me create this?
Thank you so much,
cadffm
It's a question about how you created the table.
Is is a manually filed table, or automatically created by DataExtraction?
In Dataextraction, page 5 of 8, right click, ass sum row
Sebastian
Brock_Olly
I'd like to point out that you can also add a sum through the formula function. When you insert a row it automatically increases the range like you'd expect, except when you insert in the bottom row.
Sea-Haven
Some hints re tables,
(setq rows  (vla-get-Rows objtable))
(vla-InsertRows Objtable  rows (vla-GetRowHeight Objtable (1- rows)) 1)
(vla-settext objtable rows 3 Str) ; str "=sum E1:E5"
; use this to convert column numbers to a alpha
; Number2Alpha - Converts Number into Alpha string
; Function By: Gilles Chanteau from Marseille, France
; Arguments: 1
;   Num# = Number to convert
; Syntax example: (Number2Alpha 731) = "ABC" 1="E"
(defun Number2Alpha (Num# / Val#)
  (if (< Num# 27)
    (chr (+ 64 Num#))
    (if (= 0 (setq Val# (rem Num# 26)))
      (strcat (Number2Alpha (1- (/ Num# 26))) "Z")
      (strcat (Number2Alpha (/ Num# 26)) (chr (+ 64 Val#)))
);defun Number2Alpha
aitorm
True!! thanks a lot!!
I cannot add the totals footer to a column that is automatic, but I can add it to a formula column, which is good enough.
aitorm
Thats a good point! thanks
cadffm
Perhaps, you tried to sum characters, names like in column 1, instead of columns with numbers to sum.
Try right-clicking in a column that only contains numbers, like the second/AREA
Sebastian
