AUTOMATIC DIMENSION SELECT OBJECT LISP
Gaganpatel
Message 1 of 39
Gaganpatel
Dear Sir,
I want to rectangle inner all attributes circle to attributes circle dimension automatic.
Please help me.
Replies (38)
Message 21 of 39
Moshe-A
forgot to add ...  you do not have to set the ucs before, start with ucs world and fdall will do the rest.
Message 22 of 39
Gaganpatel
Dear Sir,
This program is working good but i want to this type dimension on this program.
Please find the attached example drawing.
Please help me.
Message 23 of 39
Gaganpatel
Dear Sir,
Please help.
Message 24 of 39
Gaganpatel
Dear Sir,
ordinate dimension program is working good but i want to example type dimension on this program.
Please help me.
Message 25 of 39
Gaganpatel
 Dear Sir,
Please help and modify the program.
Message 26 of 39
Moshe-A
@Gaganpatel  hi,
how do you do?
wonder what would be you next request? Smiley LOL
moshe
Message 27 of 39
Moshe-A
@Gaganpatel ,
check this update...i add two more commands:
1) FDLIN   which preforms the linear dimensions
2) FDORD which preforms the ordinate dimensions
and the FDALL preforms 1+ 2
enjoy
moshe
Message 28 of 39
Gaganpatel
Dear Sir,
Thank you very much.
This programing very good but something problems.
1.Ordinate dimension -OK
2.Liner dimension mixed ordinate dimension and right side ,top side liner dimension are separately.
3. FDALL dimension ordinate dimension ok,right side ,top side liner dimension are separately.
4. This Program use auto cad 2014 to higher version usable .
Please find the attached example video
Please modify ,Help me.
Message 29 of 39
Moshe-A
@Gaganpatel ,
you are right, attached the fix
Message 30 of 39
Gaganpatel
THANK YOU VERY MUCH
THANKS
THIS PROGRAM IS WORKING VERY GOOD.
Message 31 of 39
Gaganpatel
Dear Sir,
how can possible this lisp 5type of block name process.
Please modify lisp share.
Message 32 of 39
Gaganpatel
Dear Sir,
Please modify this lisp, 5nos different type of block name input in this lisp please help sir.
Message 33 of 39
Gaganpatel
Dear Sir,
Please modify this lisp.
5nos. different type of circle block name input please help.
Message 34 of 39
Dear Sir,
how to fix this problem?
tnx
_______VRTLIB-1$# d ØLOAD((:protected . T) (:active-x . T) (:separate-namespace) (:load-file-list (:fas "fdall")))³" 2FDALL
FAS4-FILE ; Do not change it!
4072
217 $ Æ QÅ
W˜  Ä QÅ
W  Ã QÅ
 Á À ¿ ¾ 5½ 5¼ 5» ] º  \ g¹ \ (º \ )] º 5¹ ¸ 2
¸ 5· 5¶ µ 2 ¸ 5· 5¶ ´ µ 5¿ ´ 5¿ ³ 5² hM µ 5± ´ 5± ³ 5² h  h W _____
Message 35 of 39
m.pahee
Is it possible to share lsp file of this solution?
Message 36 of 39
Gaganpatel
Dear Sir,
and using auto cad 2013.
Message 37 of 39
ВeekeeCZ
You keep saying that. What that means? Post an xample. There is now reason to limit a routine to use only for some names...
I really did not try Moshe's routine.
Message 38 of 39
ВeekeeCZ
Here's my version. Commands BDim and BdimSet. You can adjust defaults as prefered.
HTH
(vl-load-com)
(defun c:BDimSet nil (BDimSet) (c:BDim) (princ))
(defun BDimSet nil
  (setq *bd-type* "Both")  ; default type
  (setq *bd-offset* 30.)   ; default offset
  (initget "Ordinate Continuous Both")
  (setq *bd-type* (cond ((getkword (strcat "\nSpecify DIM type [Ordinate/Continuous/Both] <" *bd-type* ">: ")))
			(*bd-type*)))
  (setq *bd-offset* (cond ((getdist (strcat "\nSpecify offset <" (rtos *bd-offset* 2) ">: ")))
			  (*bd-offset*)))
  (and *bd-type* *bd-offset*))
(defun c:BDim (/ *error* doc das LM:ssboundingbox ss sl bb mr mt ml mb sp i ed ep lp)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if lp (mapcar 'entdel lp))
    (if das (setvar 'dimassoc das))
    (if doc (vla-endundomark doc))
    (princ))
  ;; Selection Set Bounding Box  -  Lee Mac  ;; http://www.lee-mac.com/ssboundingbox.html
  (defun LM:ssboundingbox ( sel / idx llp ls1 ls2 obj urp )
    (repeat (setq idx (sslength sel))
      (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
      (if (and (vlax-method-applicable-p obj 'getboundingbox)
	       (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list obj 'llp 'urp)))))
	(setq ls1 (cons (vlax-safearray->list llp) ls1)
	      ls2 (cons (vlax-safearray->list urp) ls2))))
    (if (and ls1 ls2)
      (mapcar '(lambda ( a b ) (apply 'mapcar (cons a b))) '(min max) (list ls1 ls2))))
  (if (and (or (and *bd-type* *bd-offset*)
	       (BDimSet))
	   (princ (strcat "\nCurrent setting: Type=" *bd-type* ", Offset=" (rtos *bd-offset* 2) ". Call 'BDimSet' for reset."))
	   (setq ss (ssget '((0 . "INSERT,LINE"))))
	   (setq sl (ssget "_P" '((0 . "LINE"))))
	   (setq bb (LM:ssboundingbox sl))
	   (setq mr (list (caadr bb) (/ (+ (cadar bb) (cadadr bb)) 2))) ; right
	   (setq mt (list (/ (+ (caar bb) (caadr bb)) 2) (cadadr bb)))  ; top
	   (setq ml (list (caar bb) (/ (+ (cadar bb) (cadadr bb)) 2))) ; left
	   (setq mb (list (/ (+ (caar bb) (caadr bb)) 2) (cadar bb)))  ; bottom
	   (setq sp (ssadd))
	   (setq das (getvar 'dimassoc))
	   (setvar 'dimassoc 1)
    (progn
      (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
      (repeat (setq i (sslength ss))
	(and (setq ed (entget (ssname ss (setq i (1- i)))))
	     (= "INSERT" (cdr (assoc 0 ed)))
	     (setq ep (entmakex (list '(0 . "POINT") (assoc 10 ed))))
	     (ssadd ep sp)
	     (setq lp (cons ep lp))))
      (if (wcmatch *bd-type* "Continuous,Both")
	(command "_.qdim" sl sp "" "_c" (mapcar '+ (trans ml 0 1) (list (- *bd-offset*) 0))
		 "_.qdim" sl sp "" "_c" (mapcar '+ (trans mb 0 1) (list 0 (- *bd-offset*)))
		 "_.qdim" sl 	"" "_c" (mapcar '+ (trans mr 0 1) (list *bd-offset* 0))
		 "_.qdim" sl 	"" "_c" (mapcar '+ (trans mt 0 1) (list 0 *bd-offset*))))
      (if (wcmatch *bd-type* "Ordinate,Both")
	(command "_.qdim" sl sp "" "_p" "_non" (trans (car bb) 0 1) "_o" "_non" (mapcar '+ (trans ml 0 1) (list (- (* 2 *bd-offset*)) 0))
		 "_.qdim" sl sp "" "_o" "_non" (mapcar '+ (trans mb 0 1) (list 0 (- (* 2 *bd-offset*))))
		 "_.qdim" sl 	"" "_o" "_non" (mapcar '+ (trans mr 0 1) (list (* 2 *bd-offset*) 0))
		 "_.qdim" sl 	"" "_o" "_non" (mapcar '+ (trans mt 0 1) (list 0 (* 2 *bd-offset*)))))
  (*error* "end")
Message 39 of 39
Gaganpatel
Dear Sir,
Thanks for help.
Programming dimension are overwrite.
