Visual LISP, AutoLISP and General Customization
automatic block rotation parameters to separate texts
0 REPLIES 0
Message 1 of 1
jtm2020hyo
605 Views, 0 Replies
I have a lot of dynamic blocks with one or more rotation parameters each block.
My problem is that I need to use rotate parameters to rotate each text in 10000 nested/dynamic/regular blocks, so they do not overlap.
So I need your help to share or create a lisp-routine to use automatically the rotation parameters in my nested/dynamic/regular blocks to move text so they do not overlap.
PD: I leave an attached file to where I need to use the lisp-routine. each set of  texts inside the block are linked to one "rotation parameter"
0 REPLIES 0
AutoCAD Inside the Factory
