autoloader displays nil with a lisp routine
Message 1 of 8
Hi everyone, AutoCAD 2016, Windows 7, I've been using the autoloader mechanism to load a dll, works as expected
I've just added a lisp routine to be called on command invocation
this is PackageContents.xml:
<Components>
    <ComponentEntry
        AppName="pp3"
        ModuleName="./contents/windows/pp3.dll"
        LoadOnCommandInvocation="True">
        <Commands>
            <Command Global="pp3" />
        </Commands>
    </ComponentEntry>
    <ComponentEntry
        AppName="pp4"
        ModuleName="./contents/windows/pp4.lsp"
        <Commands>
            <Command Global="pp4" />
        </Commands>
    </ComponentEntry>
</Components>
It works except for an unwanted "nil" display when opening every dwg:
Regenerating model.
AutoCAD menu utilities loaded.*Cancel*
 nil
Command:
Command:
Command:
if I remove the component entry relative to pp4.lsp from PackageContents.xml, there is no "nil" message:
Regenerating model.
Command:
Command:
Command:
I tried to bundle just the lisp command, same issue
Replies (7)
Message 2 of 8
hmsilva
Hello Jf and welcome to the Autodesk Community!
Probably the.lsp file on load will evaluate some expression and the nil is the evaluate result, try to add a (princ) at the .lsp file end...
Without seeing the lisp code, just guessing...
Hope this helps,
Henrique
Message 3 of 8
Hello Henrique, thank you
the lisp file is intended to be loaded only on command invocation, and it is, I checked
What it contains shouldn't cause this problem
In any event here is the lisp code:
(defun c:pp4()
  (setq pp4-loaded t) ;exposed
  (print "pp4: done")
  (princ)
(princ)
Message 4 of 8
sorry the lisp routine shoud read:
(setq pp4-loaded t)
(defun c:pp4()
  (print "pp4: done")
  (princ)
(princ)
(not that it changes anything to the problem at hand)
Message 5 of 8
hmsilva
Hi Jf,
I do not see anything to cause the 'nil'... 😞
Henrique
Message 6 of 8
I hope this thread will not stop at that
I made a test with LoadOnAutoCADStartup="True" in PackageContents and no nil shows up with this setting
It seems like there is a problem with LoadOnCommandInvocation="True"
I also tried on a fresh install of AutoCAD 2015, same problem
Message 7 of 8
hmsilva
I hope so too!
But, unfortunately, I am abroad and I don't have AutoCAD in this old laptop...
Hopefully someone else can step in and assist better.
Henrique
Message 8 of 8
Thank you Henrique
