AutoLisp .PLINE command results in a completed polyline AND *Invalid* ???
hencoop
Advisor Advisor
hencoop
Hello all,
I have a bit of code that produces both a closed polyline AND an error "*Invalid*".
I used VL-CATCH-ALL-ERROR-P... (from within the errortrap function) to get beyond the error.  My program continues the WHILE loop it is in for placing multiple separate closed polylines but it leaves an unsightly *Invalid* after each instance of this polyline command in the loop:
(errortrap '(command ".pline" plp2 "a" "a" 180.0 (reverse (cdr (reverse (POLAR plp2 pi90 ptwid)))) "l" plp4 "a" plp1 "CL"))
All of the variables have been confirmed to have the correct data type.  The .PLINE command successfully concludes after the "CL" even if I don't trap for the error so it seems that the command and the polyline have nothing to do with it... but I don't know.
Any ideas what the error that produces the message "*Invalid*" is about?  Thanks for your help.
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
Kent1Cooper
Can you post the entire code?  It looks like the problem should be coming from something outside the PLINE command part.
Kent Cooper, AIA
hencoop
DOSLIB is required in the CHKKWDS subroutine.  I have not attempted to include DOSLIB.  You can get it from Robert McNeel & Associates for free here: https://wiki.mcneel.com/doslib/home
;;;Draws a pressure tank from centers or ends.
;;;Requires: Ukword.lsp, Upoint.lsp, Ureal.lsp
(defun c:ptank (/ pttyp pt1 pt2 pi00 pi90 pi180 pi270 hwid ptp1 ptp2
                plp1 plp2 plp3 plp4)
  (setq pttyp "End")                    ;(ukword 1 "Center End" "Place from Centers or Ends?" "End"))
  (setvar "OSMODE" 1285)
  (setvar "AUTOSNAP" 7)
  (if upoint nil (load "upoint" "\nFile UPOINT.LSP not loaded!"))
  (if ureal nil (load "ureal" "\nFile UREAL.LSP not loaded!"))
  (while
    (and (setq pt1 (upoint 0 "Quit" "First point of Pressure Tank [Quit]" nil nil))(/= pt1 "Quit"))
    (progn
      (setq
        pt2 (upoint
              1
              "A-500 B-1000"
              "Second point of Pressure Tank or [A-500 gal/B-1000 gal]"
              nil
              pt1
             ) ;_ end of upoint
      ) ;_ end of setq
      (cond
        ((and (eq (type pt2) 'STR)(wcmatch pt2 "A-500"))
         (setq ptdir (upoint
                     1
                     "Direction of 500 gallon Pressure Tank"
                     nil
                     pt1
                    ) ;_ end of upoint
         ) ;_ end of setq
         (setq pt2 (polar pt1 (angle pt1 ptdir) ptlen))
         (setq ptlen (+ 9.0 (/ 11.0 12.0))
               ptwid (/ 37.0 12.0)
         ) ;_ end of setq
        ((and (eq (type pt2) 'STR)(wcmatch pt2 "B-1000"))
         (setq ptdir (upoint
                       1
                       "Direction of 1000 gallon Pressure Tank"
                       nil
                       pt1
                      ) ;_ end of upoint
         ) ;_ end of setq
         (setq ptlen 16.0
               ptwid (/ 42.0 12.0)
         ) ;_ end of setq
        (T
         (setq ptwid (ureal 0 "" "Width of Pressure Tank" ptwd))
      ) ;_ end of cond
      (setq pi00  (angle pt1 pt2)
            pi180 (angle pt2 pt1)
            pi90  (+ pi00 (* pi 0.5))
            pi270 (+ pi00 (* pi 1.5))
            hwid  (* ptwid 0.5)
      )                                ;setq
      (if (eq pttyp "End")
        (setq ptp1 (polar pt1 pi00 hwid)
              ptp2 (polar pt2 pi180 hwid)
              plp1 (polar ptp1 pi270 hwid)
              plp2 (polar ptp2 pi270 hwid)
              plp3 (polar ptp2 pi90 hwid)
              plp4 (polar ptp1 pi90 hwid)
        )                              ;setq
        (setq pt1  (polar pt1 pi180 hwid)
              pt2  (polar pt2 pi00 hwid)
        )                              ;setq
      )                                ;if
      (setvar "osmode" 0)
      (IF errortrap NIL (LOAD "errortrap" "\nFile ERRORTRAP.LSP not loaded! "))
      (PRINC "\nDistance plp1 - plp2 = ")
      (PRINC (distance plp1 plp2))
    )                                  ;progn
  )                                     ;while
)                                       ;defun
;|«Visual LISP© Format Options»
(72 2 40 2 T "end of " 60 9 0 0 0 nil T nil T)
;*** DO NOT add text below the comment! ***|;
UPOINT.LSP
;This function is freeware courtesy of the author's of "Inside AutoLisp" for rel. 10 published by New Riders Publications.  This credit must accompany all copies of this function.
;;;October 19, 2004 added function to check keywords
;* UPOINT User interface point function
;* BIT (1 for no null, 0 for none) and KWD key word ("" for none) are same as
;* for INITGET. MSG is the prompt string, to which a default point variable
;* is added as <DEF> (nil for none), and a : is added. BPT is base point
;* (nil for none).
(defun upoint (bit kwd msg def bpt / inp)
  (IF chkkwds nil (load "chkkwds" "\nFile CHKKWDS.LSP not loaded! "))
  (chkkwds kwd)
  (if def
    (if (eq (type def) 'STR)
      (setq msg (strcat "\n" msg " <" def ">:")
            bit (* 2 (fix (/ bit 2)))
      (progn
        (setq pts (strcat
                    (rtos (car def)) "," (rtos (cadr def))
                    (if
                      (and (caddr def) (= 0 (getvar "FLATLAND")))
                      (strcat "," (rtos (caddr def)))
                  ) );if&strcat
              msg (strcat "\n" msg " <" pts ">: ")
    (setq msg (strcat "\n" msg ": "))
  );if a default was supplied
  (initget bit kwd)
  (setq inp
    (if bpt
       (getpoint msg bpt)
       (getpoint msg)
  ) );setq&if
  (if inp inp def)
);defun
(princ)
UKWORD
;;; This function is freeware courtesy of the author's of "Inside AutoLisp" for rel. 10 published by New
;;; Riders Publications.  This credit must accompany all copies of this
;;; function.
;;;October 19, 2004 added function chkkwds (see description at end of file)
;;;* UKWORD User key word. DEF, if any, must match one of the KWD strings
;;;* BIT (1 for no null, 0 for none) and KWD key word ("" for none) are same as
;;;* for INITGET. MSG is the prompt string, to which a default string is added
;;;* as <DEF> (nil or "" for none), and a : is added.
(DEFUN ukword (bit kwd msg def / inp)
  (chkkwds kwd)
  (IF (AND def (/= def ""))
    (SETQ msg (STRCAT "\n" msg " <" def ">: ")
          bit (* 2 (FIX (/ bit 2)))
    );setq
  );if
  (INITGET bit new-kwd)
  (SETQ inp (GETKWORD msg))
  (IF inp
    inp
    def
  ) ;_ end of if
);defun
(PRINC)
UREAL
;* UREAL User interface real function
;* BIT (0 for none) and KWD key word ("" for none) are same as for INITGET.
;* MSG is the prompt string, to which a default real is added as <DEF> (nil
;* for none), and a : is added.
(defun ureal (bit kwd msg def / inp)
  (chkkwds kwd)
  (if def
    (setq msg (strcat "\n" msg " <" (if (eq (type def) 'REAL)(rtos def 2)(if (eq (type def) 'INT)(itoa def)def)) ">: ")
  );if
  (initget bit kwd)
  (setq inp (getreal msg))
  (if inp inp def)
);defun
(princ)
CHKKWDS
(DEFUN chkkwds (kwd /)
  (SETQ invalidcharlst (LIST "!" "@" "$" "%" "^" "#" "`" "(" ")" "*" "=" "<" ">" "_"));"&" "+" "_"
  (SETQ kwd-list (DOS_STRTOKENS kwd " ")
        new-kwd NIL
        stripped-kwd NIL
  (FOREACH q kwd-list
    (IF (WCMATCH q "*`!*,*`@*,*`$*,*`%*,*`^*,*`#*,*`**,*(*,*)*,*=*,*<*,*>*,*`_*")
      (IF stripped-kwd
        (SETQ stripped-kwd (STRCAT stripped-kwd ", " q))
        (SETQ stripped-kwd q)
      (IF new-kwd
        (SETQ new-kwd (STRCAT new-kwd " " q))
        (SETQ new-kwd q)
  (SETQ kwd new-kwd)
  (IF stripped-kwd
    (PROGN
      (IF (WCMATCH stripped-kwd "*`,*")
        (PRINC "\nThese linetypes were removed because their names are invalid as a keyword: ")
        (PRINC "\nThis linetype was removed because its name is invalid as a keyword: ")
      (PRINC stripped-kwd)
      (PRINC "\n")
      (PRINC)
Kent1Cooper
Does it report the distance from plp1 to plp2 after each Polyline?  If so, is that before or after the invalid message?
Kent Cooper, AIA
hencoop
It does.  it is reported after *Invalid*
Kent1Cooper
My guess:  You have a situation analagous to this:
in which the next-to-last segment is an arc [the left end], and I used the Close option after it, though it can't close the Polyline with another arc segment, because it would need to be of infinite radius to get back to the starting point as a tangent continuation of the previous arc segment.  It closes with a line segment [I overlaid a red Line] anyway, but scolds me with *Invalid*.
If that's comparable to the ending situation in the shapes you're drawing, give it the "_line" option before the "_close" option at the end, and it won't complain.
Kent Cooper, AIA
hencoop
@Kent1Cooper Thank you.  That was it!  I didn't consider that since it actually closed the polyline anyway.
