Autolisp moving the object by a certain length
I have a problem with lisp code. I don't know anything about coding in it, can you please help me?
Basically I have a code that gives length of line/polyline in middle of it, but turns up that it obscures mentioned line. How I can modify that to add f.e. +0.5 to the x parameter of geometry x y?
Code (thanks to Lee Mac):
;;----------------------=={ Length at Midpoint }==----------------------;;
;;  This program prompts the user for a selection of objects to be      ;;
;;  labelled and proceeds to generate an MText object located at        ;;
;;  the midpoint of each object displaying a Field Expression           ;;
;;  referencing the length of the object.                               ;;
;;  The program is compatible for use with Arcs, Circles, Lines,        ;;
;;  LWPolylines, 2D & 3D Polylines, and under all UCS & View settings.  ;;
;;  The program will generate MText objects positioned directly over    ;;
;;  the midpoint of each object, and aligned with the object whilst     ;;
;;  preserving text readability. The MText will have a background mask  ;;
;;  enabled and will use the active Text Style and Text Height settings ;;
;;  at the time of running the program.                                 ;;
;;  Author:  Lee Mac, Copyright © 2013  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2013-11-12                                      ;;
;;  - First release.                                                    ;;
;;  Version 1.1    -    2016-01-16                                      ;;
;;  - Modified LM:objectid function to account for 64-bit AutoCAD 2008. ;;
(defun c:midlen ( / *error* ent fmt idx ins ocs par sel spc txt typ uxa )
    (setq fmt "Dł. %lu2%pr1%ps[,m]") ;; Field Formatting
    (defun *error* ( msg )
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
        (princ)
    (if
        (setq sel
            (ssget
                (list
                   '(0 . "ARC,CIRCLE,LINE,*POLYLINE")
                   '(-4 . "<NOT")
                       '(-4 . "<AND")
                           '(0 . "POLYLINE")
                           '(-4 . "&")
                           '(70 . 80)
                       '(-4 . "AND>")
                   '(-4 . "NOT>")
                    (if (= 1 (getvar 'cvport))
                        (cons 410 (getvar 'ctab))
                       '(410 . "Model")
        (progn
            (setq spc
                (vlax-get-property (LM:acdoc)
                        'paperspace
                        'modelspace
            (setq ocs (trans '(0.0 0.0 1.0) 1 0 t)
                  uxa (angle '(0.0 0.0) (trans (getvar 'ucsxdir) 0 ocs t))
            (LM:startundo (LM:acdoc))
            (repeat (setq idx (sslength sel))
                (setq ent (ssname sel (setq idx (1- idx)))
                      par (vlax-curve-getparamatdist ent (/ (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)) 2.0))
                      ins (vlax-curve-getpointatparam ent par)
                      typ (cdr (assoc 0 (entget ent)))
                (setq txt
                    (vlax-invoke spc 'addmtext ins 0.0
                        (strcat
                            "%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid (vlax-ename->vla-object ent)) ">%)."
                            (cond
                                (   (= "CIRCLE" typ) "Circumference")
                                (   (= "ARC"    typ) "ArcLength")
                                (   "Length"   )
                            " \\f \"" fmt "\">%"
                (vla-put-backgroundfill  txt :vlax-false)
                (vla-put-attachmentpoint txt acattachmentpointmiddlecenter)
                (vla-put-insertionpoint  txt (vlax-3D-point ins))
                (vla-put-rotation txt (LM:readable (- (angle '(0.0 0.0 0.0) (trans (vlax-curve-getfirstderiv ent par) 0 ocs t)) uxa)))
    (princ)
;; Readable  -  Lee Mac
;; Returns an angle corrected for text readability.
(defun LM:readable ( a )
    (   (lambda ( a )
            (if (and (< (* pi 0.5) a) (<= a (* pi 1.5)))
                (LM:readable (+ a pi))
                a
        (rem (+ a pi pi) (+ pi pi))
;; ObjectID  -  Lee Mac
;; Returns a string containing the ObjectID of a supplied VLA-Object
;; Compatible with 32-bit & 64-bit systems
(defun LM:objectid ( obj )
    (eval
        (list 'defun 'LM:objectid '( obj )
            (if (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*")
                (if (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
                    (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
                   '(LM:ename->objectid (vlax-vla-object->ename obj))
               '(itoa (vla-get-objectid obj))
    (LM:objectid obj)
;; Entity Name to ObjectID  -  Lee Mac
;; Returns the 32-bit or 64-bit ObjectID for a supplied entity name
(defun LM:ename->objectid ( ent )
    (LM:hex->decstr
        (setq ent (vl-string-right-trim ">" (vl-prin1-to-string ent))
              ent (substr ent (+ (vl-string-position 58 ent) 3))
;; Hex to Decimal String  -  Lee Mac
;; Returns the decimal representation of a supplied hexadecimal string
(defun LM:hex->decstr ( hex / foo bar )
    (defun foo ( lst rtn )
        (if lst
            (foo (cdr lst) (bar (- (car lst) (if (< 57 (car lst)) 55 48)) rtn))
            (apply 'strcat (mapcar 'itoa (reverse rtn)))
    (defun bar ( int lst )
        (if lst
            (if (or (< 0 (setq int (+ (* 16 (car lst)) int))) (cdr lst))
                (cons (rem int 10) (bar (/ int 10) (cdr lst)))
            (bar int '(0))
    (foo (vl-string->list (strcase hex)) nil)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com)
(princ
    (strcat
        "\n:: MidLen.lsp | Version 1.1 | \\U+00A9 Lee Mac "
        (menucmd "m=$(edtime,0,yyyy)")
        " www.lee-mac.com ::"
        "\n:: Type \"midlen\" to Invoke ::"
(princ)
;;                             End of File                              ;;
Aligning to the bottomcenter doesn't give proper distance from line...
I want to get something like this:
Instead of:
Effect from codeEffect from code
Effect with modification of aligment parameter to bottomcenter:
Effect with modified alligment from middle to bottomEffect with modified alligment from middle to bottom
Can you please tell me how I can modify this code as totally newbe to lisp?
Kent1Cooper
In lieu of altering that one, I offer one that I wrote that already places the Text above: LengthAtMidPoints.lsp with its LMP command, available >here<.  [It's far less sophisticated -- just Text, not a Field -- but it may serve your purpose.]
Kent Cooper, AIA
Thank you for answer but badly it is not enough for me...
Main reason - some numbers are upside-down, I think it depends on the start of the line/polyline but I don't know how to fix it...
Starting points are from perpendicular linesStarting points are from perpendicular lines
Kent1Cooper
@Anonymous wrote:
.... some numbers are upside-down, I think it depends on the start of the line/polyline but I don't know how to fix it...
I know, and yes, it does use the drawn direction of the object at its midpoint.  I have in mind to make it turn the Text to the more readable direction -- I'll post that when I finish working it out, if no one else posts something sooner.  In the meantime, grip-editing with Ortho on can very quickly spin the ones that come out upside-down to the better direction [180 degrees about their insertion points].
Kent Cooper, AIA
Sea-Haven
I know lee-mac has a make text readable basicly just need to look at text angle and if No than add PI.
Kent1Cooper
Yes, I know how to do it -- it's just a matter of working it in, with the complication of wanting to put the Text always on the outboard side of curves, for the reason illustrated in my link in Message 2.  It's also going to involve changing the justification and origin point of the Text, probably always MC with an origin offset from the path by the Text height, not just always using BC justification at the midpoint on  the path object.  But I'll work it out when I get the time.
Kent Cooper, AIA
Sea-Haven
Yeah there is a certain point of how much of my "FREE" time can I spend solving others solutions. Maybe s simple method Mirror text mid pt end pt ? Don't forget Mirrtext
