Autolisp moving the object by a certain length
08:49 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a problem with lisp code. I don't know anything about coding in it, can you please help me?
Basically I have a code that gives length of line/polyline in middle of it, but turns up that it obscures mentioned line. How I can modify that to add f.e. +0.5 to the x parameter of geometry x y?
Code (thanks to Lee Mac):
;;----------------------=={ Length at Midpoint }==----------------------;; ;; ;; ;; This program prompts the user for a selection of objects to be ;; ;; labelled and proceeds to generate an MText object located at ;; ;; the midpoint of each object displaying a Field Expression ;; ;; referencing the length of the object. ;; ;; ;; ;; The program is compatible for use with Arcs, Circles, Lines, ;; ;; LWPolylines, 2D & 3D Polylines, and under all UCS & View settings. ;; ;; ;; ;; The program will generate MText objects positioned directly over ;; ;; the midpoint of each object, and aligned with the object whilst ;; ;; preserving text readability. The MText will have a background mask ;; ;; enabled and will use the active Text Style and Text Height settings ;; ;; at the time of running the program. ;; ;;----------------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2013 - www.lee-mac.com ;; ;;----------------------------------------------------------------------;; ;; Version 1.0 - 2013-11-12 ;; ;; ;; ;; - First release. ;; ;;----------------------------------------------------------------------;; ;; Version 1.1 - 2016-01-16 ;; ;; ;; ;; - Modified LM:objectid function to account for 64-bit AutoCAD 2008. ;; ;;----------------------------------------------------------------------;; (defun c:midlen ( / *error* ent fmt idx ins ocs par sel spc txt typ uxa ) (setq fmt "Dł. %lu2%pr1%ps[,m]") ;; Field Formatting (defun *error* ( msg ) (LM:endundo (LM:acdoc)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (if (setq sel (ssget (list '(0 . "ARC,CIRCLE,LINE,*POLYLINE") '(-4 . "<NOT") '(-4 . "<AND") '(0 . "POLYLINE") '(-4 . "&") '(70 . 80) '(-4 . "AND>") '(-4 . "NOT>") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model") ) ) ) ) (progn (setq spc (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace ) ) ) (setq ocs (trans '(0.0 0.0 1.0) 1 0 t) uxa (angle '(0.0 0.0) (trans (getvar 'ucsxdir) 0 ocs t)) ) (LM:startundo (LM:acdoc)) (repeat (setq idx (sslength sel)) (setq ent (ssname sel (setq idx (1- idx))) par (vlax-curve-getparamatdist ent (/ (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)) 2.0)) ins (vlax-curve-getpointatparam ent par) typ (cdr (assoc 0 (entget ent))) ) (setq txt (vlax-invoke spc 'addmtext ins 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid (vlax-ename->vla-object ent)) ">%)." (cond ( (= "CIRCLE" typ) "Circumference") ( (= "ARC" typ) "ArcLength") ( "Length" ) ) " \\f \"" fmt "\">%" ) ) ) (vla-put-backgroundfill txt :vlax-false) (vla-put-attachmentpoint txt acattachmentpointmiddlecenter) (vla-put-insertionpoint txt (vlax-3D-point ins)) (vla-put-rotation txt (LM:readable (- (angle '(0.0 0.0 0.0) (trans (vlax-curve-getfirstderiv ent par) 0 ocs t)) uxa))) ) (LM:endundo (LM:acdoc)) ) ) (princ) ) ;; Readable - Lee Mac ;; Returns an angle corrected for text readability. (defun LM:readable ( a ) ( (lambda ( a ) (if (and (< (* pi 0.5) a) (<= a (* pi 1.5))) (LM:readable (+ a pi)) a ) ) (rem (+ a pi pi) (+ pi pi)) ) ) ;; ObjectID - Lee Mac ;; Returns a string containing the ObjectID of a supplied VLA-Object ;; Compatible with 32-bit & 64-bit systems (defun LM:objectid ( obj ) (eval (list 'defun 'LM:objectid '( obj ) (if (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*") (if (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring) (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false) '(LM:ename->objectid (vlax-vla-object->ename obj)) ) '(itoa (vla-get-objectid obj)) ) ) ) (LM:objectid obj) ) ;; Entity Name to ObjectID - Lee Mac ;; Returns the 32-bit or 64-bit ObjectID for a supplied entity name (defun LM:ename->objectid ( ent ) (LM:hex->decstr (setq ent (vl-string-right-trim ">" (vl-prin1-to-string ent)) ent (substr ent (+ (vl-string-position 58 ent) 3)) ) ) ) ;; Hex to Decimal String - Lee Mac ;; Returns the decimal representation of a supplied hexadecimal string (defun LM:hex->decstr ( hex / foo bar ) (defun foo ( lst rtn ) (if lst (foo (cdr lst) (bar (- (car lst) (if (< 57 (car lst)) 55 48)) rtn)) (apply 'strcat (mapcar 'itoa (reverse rtn))) ) ) (defun bar ( int lst ) (if lst (if (or (< 0 (setq int (+ (* 16 (car lst)) int))) (cdr lst)) (cons (rem int 10) (bar (/ int 10) (cdr lst))) ) (bar int '(0)) ) ) (foo (vl-string->list (strcase hex)) nil) ) ;; Start Undo - Lee Mac ;; Opens an Undo Group. (defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc) ) ;; End Undo - Lee Mac ;; Closes an Undo Group. (defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc) ) (vl-load-com) (princ (strcat "\n:: MidLen.lsp | Version 1.1 | \\U+00A9 Lee Mac " (menucmd "m=$(edtime,0,yyyy)") " www.lee-mac.com ::" "\n:: Type \"midlen\" to Invoke ::" ) ) (princ) ;;----------------------------------------------------------------------;; ;; End of File ;; ;;----------------------------------------------------------------------;;,
Aligning to the bottomcenter doesn't give proper distance from line...
I want to get something like this:
Instead of:
Effect from code
Effect with modification of aligment parameter to bottomcenter:
Effect with modified alligment from middle to bottom
Can you please tell me how I can modify this code as totally newbe to lisp?
