Hi, sunethW86GH
You could put it this way:
1. For many selected polylines, do OFFSET or COPY.
2. Immediately for all these polylines make inscriptions - XDLabel (fas).
3. Also make cross Lines - XDPoint (fas).
XDLABEL_CREATE command - create inscriptions. In the first window double click on the Layer property. In the second window select NEAR, SINGLE, CENTER, define Delta Y - distance from polylines and other necessary parameters and Ok. Then in the first window double click on the Length 2D property, and in the second window set parameters and Ok.
In the first window select both defined parameters and Ok.
XDPOINT_CREATE command - create Lines. In the program window select Type of point objects LINE, select ON, SINGLE, START, define Relative Rotation 90 or 270 and Line length. Press ^ ^ Add.
Give another parameter name, select ON, SINGLE, END, press ^ ^ Add.
Select the names of the created parameters in the upper list and Ok.
The created inscriptions and Lines will be linked to their base objects. If these polylines are shifted or lengths, layers, or shifted, inscriptions and Lines are changed, their relative position and inscriptions content can be restored with the XDLABEL_UPDATE and XDPOINT_UPDATE commands.
-- Alexander, private person, pacifist, english only with translator
Object-modeling _
odclass-odedit.com _ Help
