autolisp-excel cell reading
i hv one excel file containing 4 column values. I can select first cell by this ' setq a (read-line c b),
but, i couldn't select next cell (RHS) by lisp. what is the program for that? any tab option will work? pls help me
Accepted solutions (3)
devitg
It is easy , if you save your XLS 4 columns as CSV , then you can read it easy .
roland.r71
You are lucky to get anything.
(read-line [file-desc]) is NOT ment/suited/capable for reading Excel files. (.XLS or XLSX)
Besides that, it only takes 1 argument, not 2. (setq a (read-line c b)) ??? what's that "b" for? it only takes an open file for argument ...)
As the name suggests, it reads a line from a (text) file, until the EOL character. ([Enter]=EOL, End Of Line)
Which has nothing to do with cells.
Either you should use a ODBC connection to read the file, or save it as a .CSV file (like @devitg already suggested). You can easily do it like that, just keep in mind that a LINE will have ALL columns in it. (so you still need to parse it into cell values...)
Here's an example of a function to read a CSV file into a list of lists:
   (defun readCSV ( / file_r record values csvLst)
      ; Read settings from csv file
      ; Returns list of lists with values (records with values)
      (setq file_r (open csvfile "r")
            csvLst nil
      (while (setq record (read-line file_r))
         (setq values nil)
         (while (> (setq pos (vl-string-position (ascii "\t") record)) 0)
            (setq values (append values (list (substr record 1 pos)))
                  record (substr record (+ 2 pos))
         (if (> (strlen record) 0)
            (setq values (append values (list record)))
         (if values (setq csvLst (append csvLst (list values))))
      csvLst
This will turn your 4 columns into a list of 'records' with each 4 'values'.
same as:
(list
   (list 1 2 3 4)
   (list 1 2 3 4)
thank you very much. Actually my purpose is, i have to connect excel file with autocad and if i am putting some values as x and y it should draw a curve/graph on the screen. As i am instructed by my boss, i have to use excel file for this. is it possible in excel to read cell values as we are giving cell number by using lisp??
roland.r71
Then you'll need something like this: GetCells
 I tried getcell function. But it is not working in my system. is it require any extra software or something? please give me a solution.
roland.r71
It works for me (without anything extra installed)
...but it doesn't check any inputs. Supply a wrong filename (or path), incorrect sheetname, use a1 instead of A1 and it fails.
& it fails hard: ; error: bad argument type: VLA-OBJECT #<%catch-all-apply-error%>
But:
getcells
- browse to file . . . . . . . . . . . . C:\\lisp\\getcel.xlsx
- supply sheetname . . . . . . . . Sheet1
- supply fields . . . . . . . . . . . . . A1
Returns the cells value for me.
The value of address A1 is: a
So does: (getCellsFunction "C:\\lisp\\getcel.xlsx" "Sheet1" "A1:D1")
("a" "b" "c" "d")
