Autocad Text to CSV table
vishalghuge2500
Message 1 of 12
vishalghuge2500
I'm trying to export a manually created AutoCAD table to CSV format as shown in the images above.
I have a LISP routine (downloaded online) that works same like I needed but it exports the data to an Excel file (xlsx).
please help me modify the LISP routine to export data to a CSV file instead?
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
@vishalghuge2500 wrote:
...modify the LISP routine to export data to a CSV file instead?
May I ask why the built-in feature to do just that is not an option?
Message 3 of 12
komondormrex
check the following
(defun c:m_table_csv (/ line_sset line_list _angle separator text_row_sset top_line bottom_line cp_height_delta csv_text_list csv_file csv_file_id)
	(princ "\nSelect manually drawn table...")
	(if (setq line_sset (ssget '((0 . "line"))))
		(progn
			(setq line_list (vl-sort (vl-remove-if-not '(lambda (line) (or (equal (setq _angle (vla-get-angle (vlax-ename->vla-object line))) 0 1e-1)
															  			   (equal _angle pi 1e-1)
															  			   (equal _angle (* 2 pi) 1e-1)
										   				(vl-remove-if 'listp (mapcar 'cadr (ssnamex line_sset)))
									 '(lambda (line_1 line_2) (> (caddr (assoc 10 (entget line_1)))
															  	 (caddr (assoc 10 (entget line_2)))
							separator ";"
			(while (cdr line_list)
				(if (setq text_row_sset (ssget "_cp" ((lambda () (progn
																	(setq top_line (vl-sort (list (cdr (assoc 10 (entget (car line_list)))) (cdr (assoc 11 (entget (car line_list)))))
																			  	 		   '(lambda (point_1 point_2) (< (car point_1) (car point_2)))
																	 	  bottom_line (vl-sort (list (cdr (assoc 10 (entget (cadr line_list)))) (cdr (assoc 11 (entget (cadr line_list)))))
																			  	 			  '(lambda (point_1 point_2) (> (car point_1) (car point_2)))
																		  cp_height_delta (/ (- (cadar top_line) (cadar bottom_line)) 10.0)
																	(append (mapcar '(lambda (point) (mapcar '- point (list 0 cp_height_delta))) top_line)
																			(mapcar '(lambda (point) (mapcar '+ point (list 0 cp_height_delta))) bottom_line)
											    	'((0 . "*text"))
					(setq csv_text_list (append csv_text_list (list (mapcar '(lambda (text) (cdr (assoc 1 (entget text))))
													 	 (vl-sort (vl-remove-if 'listp (mapcar 'cadr (ssnamex text_row_sset)))
													 	   		 '(lambda (text_1 text_2) (< (cadr (assoc 10 (entget text_1)))
														   							   		 (cadr (assoc 10 (entget text_2)))
				(setq line_list (cdr line_list))
			(setq csv_file (strcat (vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\Shell Folders" "Desktop") "\\" (vl-filename-base (getvar 'dwgname)) ".csv")
				  csv_file_id (open csv_file "w")
			(foreach row (cons (list (strcat "sep=" separator)) csv_text_list)
				(princ (apply 'strcat (append (cdr (apply 'append (mapcar '(lambda (column) (list separator column)) row))) '("\n"))) csv_file_id)
			(close csv_file_id)
			(princ (strcat "\nCSV file \"" csv_file "\" has been written."))
	(princ)
updated
Message 4 of 12
Sea-Haven
Just a clarification for future, a "Table" is a CAD object that contains a grid of cells with values, think Excel, what you have is columns of text with surrounding line work. Komondormrex has given you a great answer. Very simple method added to "may need in future" also added acknowledgement to author at start of code.
Message 5 of 12
vishalghuge2500
Thank you @komondormrex  for your help. Your code works very well.
but, I'm facing issues in some cases (sorry, I forgot to mention these cases at the start).
Message 6 of 12
vishalghuge2500
@pendean Yes, you're correct, but not all my CAD files have tables in them. It depends on the client.
Message 7 of 12
pendean
Community Legend
Community Legend
I suggest you edit your post's title then, all you seem to have are floating text and floating lines, not table object types then.
Message 8 of 12
Sea-Haven
You need a consistent arrangement the 300 being a problem. Move it left or right, blank entry maybe use a "-" spending a minute or 2 editing will mean code should run every time. Your still getting what you want at a reasonable time interval.
Message 9 of 12
vishalghuge2500
I'm sorry, I don't know who wrote this code. Is it possible to edit the code to create/save a CSV file of CAD text data instead of an Excel file?
;-------------------------------------- GATHERING TABLE INFORMATION ------------------------------------
(defun tableinfo ( ss  / n entlist)
 (setq n 0)
 (repeat (sslength ss)
   (setq entlist (entget (ssname ss n)))
   (cond ((member (cdr (assoc 0 entlist)) '("LINE" "POLYLINE"))
             (getlinepts entlist)(setq linelist (cons (ssname ss n) linelist)))
            ((member (cdr (assoc 0 entlist)) '("TEXT" "MTEXT"))
             (setq textlist (cons (ssname ss n) textlist)))
            ((member (cdr (assoc 0 entlist)) '("INSERT"))
             (setq blocklist (cons (ssname ss n) blocklist)))
   (setq n (1+ n))
;-------------------------- Cell Count/Height/Width Determination ----------------------
;;Gathers x and y positions of lines and polylines in separate lists
;;This is used to determine height/width & # of rows/columns
;;Line info must be gathered first in order to determine
;;cell position of any other gathered information
(defun getlinepts (alist / x  xpt ypt)
  (foreach x alist
     (if (member (car x) '(10 11))
         (progn
           (if (not (vl-position (setq xpt (atof (rtos (car (trans (cdr x) 0 1)) 2 2))) lpxlist))
               (setq lpxlist (cons xpt lpxlist)))
           (if (not (vl-position (setq ypt (atof (rtos (cadr (trans (cdr x) 0 1)) 2 2))) lpylist))
               (setq lpylist (cons ypt lpylist)))
);defun
;---------------------------- Text Info and Cell Position -----------------------------------------------------
;;Determine cell position by insertionpoint of text objects
;;(Using text center is probably more reliable)
;;Create list of indexed lists containing "Order", "Position", "Content", "Height", "Rotation", "StyleName" and "TrueColor"
;;to be used to fill acad table after creation
;;If row and column is already in list, replace with combined string
(defun gettxtinfo (alist / x vlaobj pos rpos cpos expos)
(setq vlaobj (vlax-ename->vla-object txt)
        pos (trans (midp vlaobj) 0 1);Midpoint
        rpos (1- (vl-position (cadr pos)(vl-sort (cons (cadr pos) lpylist) '>)));Row Position
        cpos (1- (vl-position (car pos) (vl-sort (cons (car pos) lpxlist) '<))));Column Position
(if (setq expos (vl-position (list rpos cpos) (mapcar '(lambda (x)(cdr (assoc "Position" x))) tinfo)));if cell is taken
   (setq tinfo
     (replace tinfo expos
      (replace
       (nth expos tinfo)
        2
        (cons "Content"
       (if (> (cadr pos) (cdr (assoc "Order" (nth expos tinfo))));in order according to y position
          (strcat (vla-fieldcode vlaobj) " " (cdr (assoc "Content" (nth expos tinfo))))
          (strcat (cdr (assoc "Content" (nth expos tinfo))) " " (vla-fieldcode vlaobj))
(setq tinfo
 (cons
  (list
   (Cons "Order" (cadr pos))
   (Cons "Position" (list rpos cpos));Position
   (Cons "Content" (vla-fieldcode vlaobj));Content
   (Cons "Height" (vla-get-height vlaobj))
   (Cons "Rotation" (vla-get-rotation vlaobj))
   (Cons "StyleName" (vla-get-StyleName vlaobj))
   (Cons "TrueColor"
    (if
     (= (vla-get-colorindex (vla-get-truecolor vlaobj)) 256)
      (vla-get-truecolor
       (vla-item
        (vla-get-layers ActDoc)
        (vla-get-layer vlaobj)))
tinfo)))
;(vla-delete vlaobj)
);defun
;--------------------------- Block Info and Cell Position -------------------------------------------------------
;;Gather block information
;;determine cell position according to insertion point
;;Create an indexed list of lists containing "Position" (row, column), "ObjID",
;;"Attributes" (attribute id, attributetextstring) and "Scale"
(defun getblockinfo (obj / pos rpos cpos bname objid bobj attid)
  (if (= (type obj) 'ename)
    (setq obj (vlax-ename->vla-object obj))
(setq pos (trans (midp obj) 0 1)
        cpos (1- (vl-position (car pos) (vl-sort (cons (car pos) lpxlist) '<)));Column Position
        bname (vla-get-name obj);Block Name
        bobj (vla-item (vla-get-blocks ActDoc) bname));Block Vla Object
(vlax-for i bobj ; Foreach item in block
(if (eq (vla-get-objectname i) "AcDbAttributeDefinition");If item is an attribute
  (setq attid (append attid (list (vla-get-objectid i))));List Attribute Id
(setq objid (vla-get-objectid bobj));Block Object Id
 (setq binfo
   (cons
    (list
     (Cons "Name" bname)
     (Cons "ObjID" objid)
  (if (= (vla-get-hasattributes obj) :vlax-true)
   (Cons "Attributes"
    (reverse
    (mapcar
      '(lambda (x y) (cons y (vla-get-textstring x)))
      (vlax-safearray->list (variant-value (vla-getattributes obj)))
      attid
     (Cons "Scale" (vla-get-xscalefactor obj))
binfo))
;-------------------------------------------- REPLACE by Charles Alan Butler---------------------------------------------
;;Cab's replace function used in this routine to avoid overwriting cells and to update cell merge lists
(defun replace (lst i itm)
  (setq i (1+ i))
  (mapcar
    '(lambda (x)
      (if (zerop (setq i (1- i))) itm x)
    lst
;-------------------------Midpoint-----------------
(defun midp (obj / ObjLl ObjUr)
 (vla-GetBoundingBox obj 'ObjLl 'ObjUr)
 (mapcar
  '(lambda (a b) (/ (+ a b) 2.0))
   (safearray-value ObjLl)
   (safearray-value ObjUr))
;-------------------------Q&D Number Accumulation---------------------------
;Used in this routine for polar distances to determine which cells to merge.
;;Recursive function possible. Ask Gile (recursion master) if desired.
(defun acnumlist (nlist / acnlist)
 (repeat (length nlist)
  (setq acnlist (cons (apply '+ nlist) acnlist)
        nlist (reverse (cdr (reverse nlist))))
 acnlist
;;   Remove_nth    (Lee Mac)          ;;
;; ~ Removes the nth item in a list.  ;;
(defun Remove_nth (i lst / j)
  (setq j -1)
  (vl-remove-if
    (function
      (lambda (x)
        (eq i (setq j (1+ j))))) lst))
 ;;; private function (fixo)
(defun setcelltext(cells row column value)
  (vl-catch-all-apply
    'vlax-put-property
    (list cells 'Item row column
	 (vlax-make-variant
	   (vl-princ-to-string value) 8)))
  (defun setgridlines(xlapp range);(fixo)
  ;; select the range:
  (vlax-invoke-method range 'Select)
  ;; get excel application selection property:
  (setq range (vlax-get-property xlapp 'Selection))
  ;; get selection borders
  (setq borders (vlax-get-property range 'Borders))
  ;; iterate through all edges of the selection
  (setq cnt 0)
    (vlax-for a	 borders
      (setq cnt (1+ cnt))
      (vl-catch-all-apply
	(function
	  (lambda ()
	    (progn
	      (if (< cnt 5)
		(progn
		  (vlax-put-property
		    a
		    'LineStyle
		    (vlax-make-variant 1 3)); single line style
		  (vlax-put-property
		    a
		    'Weight
		    (vlax-make-variant 2 3));  lines
		  (vlax-put-property
		    a
		    'ColorIndex
		    (vlax-make-variant 1 5))); color black
		;; turn off the diagonal lines:
		(vlax-put-property a 'LineStyle (vlax-make-variant -4142 3))
  (princ)
(defun conexcelcolumn (/ a b list1);(Q. J. Chen)
  (setq a 65)
  (setq list1 nil)
  (repeat 26
    (setq list1 (append
		  list1
		  (list (chr a))
    (setq a (1+ a))
  (setq a 65)
  (repeat 26
    (setq b 65)
    (repeat 26
      (setq list1 (append
		    list1
		    (list (strcat (chr a) (chr b)))
      (setq b (1+ b))
    (setq a (1+ a))
  list1
 ;;;  apply props
(defun Orient (xlrange)
  (mapcar '(lambda (prop value)
	     (vl-catch-all-apply
	       'vlax-put-property
	       (list xlrange
		     prop
		     value
	  (list	'HorizontalAlignment 'VerticalAlignment 'Orientation)
	  (list -4143 -4108 (cvunit (cdr (assoc "Rotation" x)) "radian" "degree"))
;------------------------------------------- CONVERT OLD TABLE ROUTINE -----------------------------------------------
(defun c:TE (/ ActDoc   *error* orerror otcontents textlist    colwidths i mlist  p0 hmergelist2 vmergelist2
                       *Space*  lpxlist lpylist  tinfo     cwidths     check        tstyle     spos newstring
                       tstylelst blocklist  rowheights selsets       tstylelst2 tstylelst3
                       kword     linelist       binfo        rheights   hmergelist vmergelist  ssitem   tblobj mb
                       colorlst colorlst2 th tr ts tc newstyle RowTypes a acapp acsp address adoc atable borders cnt col data_list fname font prop release row
	       selrange sset txt_list urange value xlapp xlbook xlbooks xlcells xlrange xlsheet xlsheets)
(vl-load-com)
(setq oerror *error*)
(defun *error* ( msg )
        (princ (strcat "\n<" msg ">\n"))
	(mapcar '(lambda (x)(and x (not (vlax-object-released-p x))(vlax-release-object x))) (list ssitem))
        (setq *error* oerror)
        (setvar 'nomutt 0)
	(vla-EndUndoMark ActDoc)
        (princ)
);defun *error*
(setq ActDoc (vla-get-activedocument (vlax-get-acad-object))
        *Space* (vlax-get-property ActDoc (nth (vla-get-ActiveSpace ActDoc)'("PaperSpace" "ModelSpace"))))
(vla-StartUndoMark ActDoc)
(setq otcontents (ssget))
(command "._zoom" "object" otcontents "")
(princ "\nSorting Line Info...")
(tableinfo otcontents)
(setq lpxlist (vl-sort lpxlist '<) lpylist (vl-sort lpylist '>))
(princ "\nSorting Text Info...")
(mapcar '(lambda (txt)(gettxtinfo (entget txt))(redraw txt 2)) textlist);;using redraw function To avoid interference
(princ "\nSorting Block Info...")
(mapcar '(lambda (blk)(getblockinfo blk)) blocklist)
(setq colwidths (mapcar '(lambda (x)(- (nth (1+ (vl-position x lpxlist)) lpxlist) x))(reverse (cdr (reverse lpxlist))))
      rowheights (mapcar '(lambda (x)(- x (nth (1+ (vl-position x lpylist)) lpylist)))(reverse(cdr (reverse lpylist)))))
(setq p0 (vlax-3d-point (trans (list (car lpxlist) (car lpylist) 0.0) 1 0)));;<---Table Placement (Currently using Top Left corner)
(progn
(princ "\nSearching for merged cells...")
(princ)
(setvar 'nomutt 1)
;-----------------------------------Method to determine which cells to merge--------------------------------------------
;Method fails if missed selection is not possible at zoom level.
;To determine which cells to merge, a selection at point is used.
;For each row, a selection is attempted at each vertical line at row's center.
;If no selection is made, the point is at the center or left of horizontally merged cells.
;For each column, a selection is attempted at each horizontal line at column's center.
;If no selection is made, the point is at the center or upper region of vertically merged cells.
;Continuation of merging is determined by a 'consecutive miss'.
;When a 'consecutive miss' is made, max column/row item is replaced by the next column/row.
(setq selsets (vla-get-selectionsets ActDoc))
(vl-catch-all-error-p (vl-catch-all-apply 'vla-add (list selsets "InxCheckSet")))
(setq ssitem (vla-item selsets "InxCheckSet")
        cwidths (acnumlist colwidths)
        rheights (acnumlist rowheights));;col widths & row heights accumulated for polar use
(mapcar '(lambda (pt rh)
   (vl-catch-all-error-p (vl-catch-all-apply 'vla-clear (list ssitem)))
   (vla-selectatpoint ssitem (vlax-3d-point (polar (list (car lpxlist) (+ pt (/ rh 2)) 0.0) 0 x)))
   (if (zerop (vla-get-count ssitem))
         (if check
           (setq hmergelist (replace hmergelist 0 (replace mlist 3 (1+ (vl-position x cwidths)))))
           (setq hmergelist
            (cons
             (setq mlist
               (list
                 (1- (vl-position pt lpylist))
               )) hmergelist)
             check T)
         );if
       (setq check nil mlist nil)
   ));lambda
   cwidths
  );mapcar
);lambda
(member (nth 1 lpylist) lpylist)
rowheights
);mapcar
(mapcar '(lambda (pt cw)
    (vla-selectatpoint ssitem (vlax-3d-point (polar (list (+ pt (/ cw 2)) (car lpylist) 0.0) (* pi 1.5) x)))
         (if check
           (setq vmergelist (replace vmergelist 0 (replace mlist 2 (1+ (vl-position x rheights)))))
           (setq vmergelist
            (cons
             (setq mlist
               (list
                 (vl-position pt lpxlist)
               )) vmergelist)
             check T)
         );if
   ));lambda
   rheights
  );mapcar
);lambda
lpxlist
colwidths
);mapcar
(setvar 'nomutt 0)
);progn
(setq hmergelist2 (mapcar '(lambda (b)(list (car b)(cadr b))) hmergelist))
(setq vmergelist2 (mapcar '(lambda (b)(list (car b)(cadr b))) vmergelist))
(mapcar
'(lambda (a / expos)
  (if
   (setq expos (vl-position (list (car a)(cadr a)) vmergelist2))
   (setq dmergelist (cons (list (car a)(cadr a)(caddr (nth expos vmergelist))(cadddr a)) dmergelist))))
   hmergelist
(setq	xlapp	   (vlax-get-or-create-object "Excel.Application");(fixo)
	xlbooks  (vlax-get-property xlapp 'Workbooks)
	xlbook	   (vlax-invoke-method xlbooks 'Add)
	xlsheets (vlax-get-property xlbook 'Sheets)
	xlsheet	   (vlax-get-property xlsheets 'Item 1)
	xlcells	   (vlax-get-property xlsheet 'Cells)
(vla-put-visible xlapp :vlax-true)
(vlax-invoke-method xlsheet "Activate")
(setq ecol (conexcelcolumn))
;place text
(mapcar '(lambda (x / r c xlrange)
         (setq r (1+ (cadr (assoc "Position" x))) c (1+ (caddr (assoc "Position" x))))
         (setcelltext xlcells r c (cdr (assoc "Content" x)))
         (setq xlRange (vlax-get-property xlsheet "Range" (strcat (nth (1- c) ecol) (itoa r))))
         (vlax-invoke-method xlRange "Select")
         (setq xlRange (vlax-get-property xlapp "Selection"))
         (Orient xlrange)
         tinfo
;place block info
(mapcar '(lambda (x / r c bstring)
         (setq bstring "")
         (if (cdr (assoc "Attributes" x))
         (progn
         (mapcar
          '(lambda (y )
           (setq bstring (strcat ":"(cdr y) bstring)))
           (cdr (assoc "Attributes" x)))
         (setcelltext xlcells r c (strcat "Block:"(cdr (assoc "Name" x)) bstring))
         ));if
         binfo
;merge cells
(princ "\nProcessing Merge Info")
(defun convertlist ( mrglist / newmrglist)
  (foreach x mrglist
   (setq newmrglist (append newmrglist (list (strcat (nth (cadr x) ecol)(itoa (1+ (car x)))":" (nth (cadddr x) ecol)(itoa (1+ (caddr x)))))))
(defun applylist ( mrglist / xlRange)
 (foreach x mrglist
 (setq xlRange (vlax-get-property xlsheet "Range" x))
 (vlax-put-property xlRange "MergeCells" :vlax-true)
(setq hmergelist2 (convertlist hmergelist)
      vmergelist2 (convertlist vmergelist))
(applylist hmergelist2)
(applylist vmergelist2)
 (vlax-invoke-method
   (vlax-get-property xlsheet 'Columns)
   'AutoFit)
;;;  align all columns to center
   (vlax-put-property
     (setq urange(vlax-get-property xlsheet 'UsedRange))
   'HorizontalAlignment -4108)
;;;  draw grid lines
  (setgridlines xlapp urange)
 (mapcar '(lambda (x);(fixo)
	     (vl-catch-all-apply
	       '(lambda	()
	  (list xlcells xlsheet xlsheets xlbook xlbooks xlapp)
  (setq  xlapp nil)
  (gc)(gc)(gc)
(mapcar '(lambda (txt)(redraw txt 1)) textlist);;using redraw function again
(princ)
(princ)
);defun
Message 10 of 12
Sea-Haven
Yes it is possible to edit the code but obviously your happy to just ignore the effort done previously to solve your problem. Yes have seen that code and it seems way over the top compared to a basic solution when the text are organised properly and a solution is offered.
Message 11 of 12
komondormrex
check update in message 3.
Message 12 of 12
vishalghuge2500
Respected sir @Sea-Haven
If the code was updated by @komondormrex  earlier than my last post, I apologize for not noticing the update.
I don't think anyone here would intentionally ignore a free solution to their problems. My intention was simply to provide a reference. Additionally, @pendean suggested changing the title, and I happily complied. I did not ignore that suggestion.
Thank you.
