AutoCAD Script Error
i have an issue with Script file, which is not allowing me to launch AutoCAD.
Error: Windows Script Host,
Cannot find script file "C:\Program Files\Autodesk\AutoCAD 2015\Acad\MechanicalLauncherEnglish.vbs"
Can i know what is the problem that is causing this.
regards,
Avinash
paullimapa
Perhaps you can provide everyone with a bit more information such as:
Are you running a command when this error occurs?
Does this occur when you start AutoCAD?
Are you trying to run an AutoCAD script file which uses SCR as the file type extension and not .VBS?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
This issue is happening when i start AutoCAD.
Avinash
paullimapa
You may want to try setting AutoCAD 2015 back to defaults:
Start>All Program>Autodesk>AutoCAD 2015>Reset Settings to Default
Paul Li
IT Specialist
@The Office
