Autocad ribbon panel icon size
I want to use the large icons in the ribbon panels. I know that I can go into the CUI and change the icons individually (as on the attached screenshot.), one at a time.  But is there a way to change them all at once? Changing them one at a time is a bit much.
ВeekeeCZ
Probably not in CUI.
You can find your *cuix file, then rename it to *.zip, unzip, find RibbonRoot.cui, open it in Notepad... and make your edits manually. (perhaps find-replace in selection).
Just do a back up first !!!
So....Then zip the folder and change the name to a cuix extension?
