AutoCAD LISP Script Issues
cslibnm
cslibnm
(defun c:FinalHatchR (/ ss i obj vla-obj area oldsnap)
  (setq ss (ssget "X" '((0 . "LWPOLYLINE,POLYLINE,LINE,ARC,CIRCLE,ELLIPSE"))))
  (if ss
    (progn
      (command "_.undo" "_begin")
      (setq i -1)
      (while (setq obj (ssname ss (setq i (1+ i))))
	(setvar "cecolor" "green")
        (princ "\ni = ")
        (princ i)
        (princ "\n")
        (setq vla-obj (vlax-ename->vla-object obj))
        (setq area nil)
        (if (vl-catch-all-error-p (setq area (vl-catch-all-apply 'vla-get-area (list vla-obj))))
          (setq area nil)
        (setq ent (entget (ssname ss i)))
        (setq layer (cdr (assoc 8 ent)))
        (princ "\n")
        (princ layer)
        (princ "\n")
        (if (and area (not (ssget "_X" (list (cons 0 "HATCH") (cons 10 (vlax-curve-getstartpoint vla-obj))))))
          (progn
            (setq oldsnap (getvar "osmode"))
            (setvar "osmode" 0)
	    (cond
  		((wcmatch layer "*LayerYellow*")
   			(setvar "cecolor" "yellow")
  		((wcmatch layer "*LayerBlue*")
    			(setvar "cecolor" "blue")
  		((wcmatch layer "*LayerGrey*")
    			(setvar "cecolor" "8")
            (if (not (equal "green" (getvar "cecolor")))
              (progn
                (command "_.bpoly" (vlax-curve-getstartpoint vla-obj) "") ; Create a boundary polyline around the enclosed area
                (setq obj (entlast)) ; Get the last created entity (boundary polyline)
                (command "_.hatch" "S" "P" obj "") ; Hatch the enclosed area
                (command "_.erase" obj "") ; Erase the boundary polyline
            (setvar "osmode" oldsnap)
      (command "_.undo" "_end")
      (princ "\nAll enclosed areas have been hatched with color.")
  (princ "\nNo enclosed areas found.")
  (princ)
May I ask why when it comes to "LayerGrey", it paints the area as "blue"?
paullimapa
The following code:
(princ i)
Since i is an integer then the code should be:
(princ (itoa i))
Also for testing you may want to add an alert in each of the conditions just so you know which one is executing:
    (cond
(alert “This is yellow”)
    (setvar "cecolor" “blue”)
(alert “This is blue”)
  (alert “This is grey”)
Paul Li
IT Specialist
@The Office
Kent1Cooper
@paullimapa wrote:
The following code:
(princ i)
(princ (itoa i))
[Not necessary.  If it were the (prompt) function, it would require a text string argument, but (princ) can use a number, either integer or real.]
Kent Cooper, AIA
Kent1Cooper
Without testing, I wonder....  Could it be that your Layer names are not always spelled in the right case combination?  The (wcmatch) function is case-sensitive, so a Layer name containing [for example] "Layeryellow" [with the lower-case y] will not be recognized.
You can get around that possibility by forcing everything to upper-case for the comparison in the (cond) tests:
((wcmatch (strcase layer) "*LAYERYELLOW*")
[or force lower-case if you prefer -- read about the (strcase) function.]
Kent Cooper, AIA
paullimapa
Thanks for pointing that out. I wasn’t aware of this since I typically use the strcat function to princ combo of both strings & integers. So @cslibnm  following princ lines:
        (print "\ni = ")
        (princ i)
        (princ "\n")
can be combined as one:
 (princ (strcat "\ni = " (itoa i) "\n"))
Paul Li
IT Specialist
@The Office
Sea-Haven
Maybe "green" is not "Green" and (getvar 'cecolor) returns "3".
