Autocad Changing Hatch color
F.Camargo
Advisor Advisor
Message 1 of 15
F.Camargo
Hi friends,
How are you?
In my project have about 300,000 pieces of hatches, there are 2 colors; red and green...
I'd like to change all red hatches to color 31 and green to 141 color.
I'm trying to using quick select, and isn't working. Maybe a lisp could help me.
Anybody could help me out, please?
File attached
Thank in advance
Fabrício
Replies (14)
Message 2 of 15
dlanorh
Any chance of a dwg version saved as AutoCAD 2010 or earlier?
I am not one of the robots you're looking for
Message 3 of 15
F.Camargo
Hi @dlanorh
Sure my friend!
Message 4 of 15
dlanorh
These are solids, not hatches and you have some color 10, which looks like red. Are these to be changed?
Message 5 of 15
F.Camargo
Yes @dlanorh .
I'd like to change all color red or 10 to 31.
Message 6 of 15
dlanorh
Try this. I've split the selection sets up because of the number of items, but it should take less than a minute (it did whilst testing)
(defun c:chc ( / *error* ss cnt ent elst)
  (defun *error* ( msg )
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : " msg " occurred.")))
    (princ)
  );_end_*error*_defun
  (setq ss (ssget "_X" '((0 . "SOLID") (-4 . "<OR") (62 . 1) (62 . 10) (-4 . "OR>"))))
  (cond (ss
          (repeat (setq cnt (sslength ss))
            (setq ent (ssname ss (setq cnt (1- cnt)))
                  elst (entget ent)
            (entmod (subst (cons 62 31) (assoc 62 elst) elst))
  (setq ss (ssget "_X" '((0 . "SOLID") (62 . 3))))
  (cond (ss
                  elst (entget ent)
            (entmod (subst (cons 62 141) (assoc 62 elst) elst))
  (princ)
Message 7 of 15
F.Camargo
@dlanorh
Thank you very much!
Worked like a charm!!!
It just saved me some hours!! Thank you
Fabricio
Message 8 of 15
ronjonp
@dlanorh  Did not test but I doubt breaking the two selsets would be a whole lot faster than this. You still have to iterate all the items.
(defun c:chc (/ c cnt elst ent l ss)
  (setq l '((1 31) (3 141) (10 31)))
  (if (setq ss (ssget "_X" '((0 . "SOLID") (-4 . "<OR") (62 . 1) (62 . 3) (62 . 10) (-4 . "OR>"))))
	    elst (entget ent)
	    c	 (assoc 62 elst)
      (entmod (subst (cons 62 (cadr (assoc (cdr c) l))) c elst))
  (princ)
I don't usually use command calls but this is waaaay faster 🙂
(defun c:chc_cmd (/ ss)
  (if (setq ss (ssget "_X" '((0 . "SOLID") (-4 . "<OR") (62 . 1) (62 . 10) (-4 . "OR>"))))
    (command "_.chprop" ss "" "_C" 31 "")
  (if (setq ss (ssget "_X" '((0 . "SOLID") (62 . 3))))
    (command "_.chprop" ss "" "_C" 141 "")
  (princ)
;;;Command: CHC
;;;< Elapsed time: 21.531 seconds. >
;;;Command: CHC_CMD
;;;< Elapsed time: 3.11 seconds. >
Message 9 of 15
dlanorh
Wow! That is much faster! I didn't even consider a command call.
I split them because on the first attempt with a single selection set, my machine threw a momory error and crashed AutoCAD. I put down to the size of the selection set, but could also have been caused by having 4 drawings open. I didn't consider this at that time.
Message 10 of 15
Sea-Haven
Maybe scope to add more colors.
(defun c:chc_cmd2 (/ ss lst)
(setq lst '((1 31) (3 141) (10 31)))
(repeat (setq x (length lst))
  (if (setq ss (ssget "_X" (list (cons 0 "SOLID") (cons 62 (car (nth (setq x (- x 1)) lst))))))
    (command "_.chprop" ss "" "_C" (cadr (nth x lst)) "")
  (princ)
Message 11 of 15
F.Camargo
Hi @ronjonp
Thank you for the helptr my old friend.
I really apreciate that.
Regards
Fabrício
Message 12 of 15
F.Camargo
@Sea-Haven
It is very interesting!
I've already tested other colors and worked fine!!
Thank you very much.
Fabrício
Message 13 of 15
ronjonp
  (princ)
Nice idea .. I'd use foreach to simplify a bit like so:
(defun c:chc_cmd2 (/ ss)
  (foreach x '((1 31) (3 141) (10 31))
    (if	(setq ss (ssget "_X" (list '(0 . "SOLID") (cons 62 (car x)))))
      (command "_.chprop" ss "" "_C" (cadr x) "")
  (princ)
Message 14 of 15
ronjonp
@F.Camargo wrote:
Hi @ronjonp
Regards
Fabrício
Glad to help 🙂
Message 15 of 15
sameerulcdc
hi
i need ur help regarding this lsp
i have solid hatch inside the block and outside also without block with different color in the dwg i need lsp to change the all color in side the block and outside also to color 254
and  if there  is option to select area by user it will be very good
thank you
