AutoCAD 2016 script stops running
I'm running a script to edit drawings. On one computer the script is running without a problem, on another computer the script stops every time after the Lisp routine. On the command line you see a Cancel after the routine. When I run the routine manually, this causes no Cancel. On the other computer I have no issues with this script.
This is the script:
Open
"DUCTING LAYOUT.dwg"
(ConvertLayout "Convert4Vault_20161025_2017.csv" nil)
qsave
close
Open
"02DUCTING LAYOUT.dwg"
qsave
close
Alfred.NESWADBA
Did you verify that the lisp ended without errors? What happens when you create a dummy-code in the lisp that does nothing, just starts and ends ... is _QSAVE then initiated?
And every time a script should work with multiple drawings make sure that no ACADDOC.LSP blocks something + compare the SDI variable.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thanx for your quick respons. As I said the script is running with no errors on another computer. The Lisp routines end with no Cancel. It looks that the QSAVE command does it. I have an ACADDOC.LSP. But also on the other computer which has a same environment.
Regards Leo
Alfred.NESWADBA
I have seen that, but I don't know what's inside the LISP, it might e.g. access pc3-files which might be different on that two systems, there might be a lot of differences, therefor I asked to change the lisp to a dummy one without any functionality just to isolate the source of the problem.
With the same content?
What you can try too:
  • From both systems run command SYSVDLG (from the expresstools), export all system variables and compare that exported files using e.g. Excel.
  • Other option: from the working computer export the AutoCAD profile, on the non-working workstation create a new Windows user with admin permissions, login with that account, start AutoCAD and import that arg-file, make sure this new profile is the default for new AutoCAD starts and try your scripts again.
Generally to:
I'm quite sure that after a few minutes of working with AutoCAD the environments are not equal any more, especially noting that also system devices of Windows influence the AutoCAD environment too.
- alfred -
Alfred NESWADBA
Hi Alfred,
You were right. An incompatible version of the plot wizard link was the reason the script stopped. I have deleted the file and now the script continues.
Thanks!
Regards Leo
