AUTO numbering and AUTO changing numbers
MichalHakel_SP
MichalHakel_SP
I would like to ask you for AutoLISP to have an option to create "text or labels or fields" (doesn´t matter) that would be able to auto number my parking areas.
More detailed explanation:
WHAT I HAVE
I am just designing new parking House (I attached one floor of this parking house as .dwg file in attachment below and also a .pdf file of this floor plan to better and faster representation).
In this parking House I need to have every parking space marked. I marked it like "P01, P87, P101 etc.) from "P01" to "P269".
I just did it by copying simple text and editing it.
WHAT I NEED
However, sometimes I need to change the number of some parking spaces because of changing my floor plan due to whatever reasons.
For example I have to remove parking space "P101" and then change numbers of all the others parking spaces.
I would like to have som AutoLISP to mark this parking spaces from "P01" to "P269" and when I remove some of parking spaces with their marked numbers, all numbers of other parking spaces would be changed so I wouldn´t have to change every number manually by editing simple text.
Also the AutoLISP should be prepared for future use, (not only for this project) when I will want to change marking for example to A001 instead of P01 etc.
Is it even possible to create some AutoLISP like this ?
Thank you for your replies and for your time dedicated to this post.
ВeekeeCZ
Tried THIS ?
Or THIS , a manual approach. Just select texts, ADD option and -1... it will recognize the number and P prefix.
MichalHakel_SP
Thank you, it´s enough for purposes I need 🙂
