Attsync in accoreconsole
kkstrand
kkstrand
Have a script that runs the attsync command. In autocad it runs without any problem but I would like to run it in accoreconsole. There I get the Unknown command error.
I need to either find a way to load it or find a lisp routine that have the same functionality.
dbhunia
Check This Link ......
Elaborate (the red mark), with your Script, what functionality......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
kkstrand
@dbhunia wrote:
Check This
The same functionality as the command Attsync.
kkstrand
Solved by making a lisp that replaces the block with a new one from the definition.
k.amulyapriyadarshini
Hi @kkstrand
Can you share the .lisp file for Attsync and how you called .lisp in your program?
Thank you
