Attributes upper and lower case lisp modification
Dear Helpers,
I got a lisp code that will update all attributes of single selected block to uppercase. But the lisp code I need is, it should update only single attribute to upper or lowercase for selected block. The code I have is below. It should work for multiple blocks.
(defun c:AUC ( / ent enx )
   (if (and (setq ent (car (entsel)))
            (= "INSERT" (cdr (assoc 0 (setq enx (entget ent)))))
            (= 1 (cdr (assoc 66 enx)))
            (setq ent (entnext ent)
                  enx (entget  ent)
       (while (= "ATTRIB" (cdr (assoc 0 enx)))
           (entmod (subst (cons 1 (strcase (cdr (assoc 1 enx)))) (assoc 1 enx) enx))
                 enx (entget  ent)
       (princ "\nNo object selected or selected object is not a block.")
   (princ)
T.Brahmanandam
dbhunia
Hi
Do you asking for this.......
enx (entget ent)
(setq Att_Val (cdr (assoc 1 enx)))
(setq Ans (getstring (strcat "Do you want to Change tha Attribute value (" Att_Val ") to Upper? (Y/N): ")))
(if (or (= Ans "Y") (= Ans "y"))
enx (entget ent)
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Thank you Sir for reply.
pbejse
Are you wanting to select an attribute string, change the selected item to upper/lower case then apply to all blocks with the same Block name and Attribute Tag?
pbejse
[ Took out "ACCEPTED AS SOLUTION" flag ]
I'm confused, the previous post is definitely NOT a solution but a query regarding the intended result tnvsb. 😄
[ I'm referring to MY post guys ]
I was thinking of an entirely different outcome.
(defun c:demo ( / mode att_str)
  (initget "L U")
  (if (null
        (setq
          mode (getkword "\nChoose option [Lowercase/Uppercase] <U>: ")
    (setq mode "U")
  (if
    (and
      (setq att_str (car (nentsel "\nSelect Attribute")))
      (eq "ATTRIB" (cdr (assoc 0 (entget att_str))))
     (vla-put-textstring
       (Setq att_str (vlax-ename->vla-object att_str))
       (strcase (vla-get-textstring att_str)
                (if (eq mode "L") T
  (princ)
AND/OR  apply the same to the rest of the blocks on the drawing. [ Not included ]
