Attribute Justifications En Masse
Designer_1E
Designer_1E
I downloaded an AutoLisp which can change the height of all my attributes, (pasted below), it works well.  Would anyone know how to edit this AutoLisp so that it can change the Justification of all my attributes?  I am constantly going into blocks supplied by our manufactures to change them to Bottom Center.
Thank you,
;;;Attribute height change
(defun c:ahc ()
(setq atth(getreal "\nEnter new attribute height: "))
(command "attedit" "y" "*" "*" "*" "c" pause pause)
(while
(= 1 (logand (getvar "cmdactive") 1))
(command "h" atth "n")
);;; end while
);;; end lisp
johnyDFFXO
;; attribute alignment 13
(vl-load-com)
(defun c:AA13 ( / x y)
(if (setq x (ssget '((0 . "insert") (66 . 1))))
(repeat (setq y (sslength x))
(foreach z (vlax-invoke (vlax-ename->vla-object (ssname x (setq y (1- y)))) 'getattributes)
(vl-catch-all-apply 'vla-put-alignment (list z 13)))))
(princ)
Designer_1E
This works. Thank you!
