ATT TAG does not update in blockeditor
DGRL
Advisor Advisor
DGRL
Dear coders,
I use a nice routine to rename ATT Tags from old to new.
When i open the block in blockeditor is still see the old names of the ATT Tags,
Battman does not work
How can i update the block with the new ATT Tag names?
When double click on block i can see all the new ATT Tags // only not in blockeditor
Kind regards,
If this was of any help please kudo and/or Accept as Solution
Kind Regards
cadffm
So your routine DO NOT edit your Block, it is only editing the Attributes on them Blockreferences.
Normally (without a tool) you use BATTMAN to rename the TAGS Of ATTDEF/Attributes (set autom. sync-function ON [Settings] ).
Sebastian
