Assign Name to Numbered color in Autocad Color Index (ACI)
titus_CAD
Message 1 of 10
titus_CAD
The first seven colors in the ACI are named (red, yellow, green, etc). They are also associated with an index number (red=1, yellow=2, green=3, etc). So, if I want to change the color of an object or layer, I can type in "red" or "1" in the "Select Color" dialog box and get the same result (see photo).
Is there a way to assign a name to colors 8-255? Obviously, I wouldn't do ALL of those colors. But maybe just a few more that I commonly use, such as color 8. I could name that to "Gray."
Is there a way to do this?
Replies (9)
Message 2 of 10
Kent1Cooper
I don't think there's a way to do that in the dialog box.  You could do it in something like an AutoLisp routine for assigning colors, using something like a list associating your names with the appropriate index numbers, or even with TrueColor values.
[But who says color 8 should be "Gray," when there are numerous shades of gray in the system?]
Kent Cooper, AIA
Message 3 of 10
paullimapa
And then you’ll have to consider the various ways to spell it
https://www.rd.com/article/grey-vs-gray-which-is-correct/
Paul Li
IT Specialist
@The Office
Message 4 of 10
titus_CAD
Gotcha, so in other words, there is no text file stored somewhere on my computer that I can go in and edit that stores the information for these colors?
(I am ignoring your comment and any further comments on how the colors should/shouldn't be named - waste of time)
Message 5 of 10
Sea-Haven
The 1-8 colors are more than likely a hang up from the days of drafting ink pens the color indicated its thickness, we used those 1-8 as implied for thickness, you have to remember that Autocad started back in the days of manual drafting. Some stuff is still in Autocad from day 1 but is really not needed anymore. Some functions have been removed same as colors using names may 1 day be removed.
Message 6 of 10
titus_CAD
Thanks!
Message 7 of 10
komondormrex
however help tells that colors numbered 1 to 9 have to have their names)
Message 8 of 10
paullimapa
Of course another section of the help file contradicts that
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-14BC039D-238D-4D9E-921B-F4015F96CB54
and since there is no known names for colors 8 & 9 that should tell you which section is correct
Paul Li
IT Specialist
@The Office
Message 9 of 10
komondormrex
i wonder if they get it fixed ever)
Message 10 of 10
ВeekeeCZ
So tell them and watch.
