Arrow Leader LISP
Arrow Leader LISP
ensomoran
Message 1 of 13
Arrow Leader LISP
ensomoran
This was my first attempt at making a LISP routine for myself.  Everything works fine except for the fact that when I use a "Clockwise" motion to draw the arch the arrow comes in 180 degrees in the wrong direction.  Everything works fine when I draw it with a counter-clock wise motion.
I'm pretty sure this is a funky geometry thing but can any one help me troubleshoot this/improve what I have so far?
Any comments about syntax and best practices would also be appreciated.
Replies (12)
Message 2 of 13
ВeekeeCZ
Did not test it  but it seem that wrong type parentheses could be the culprit.
[setq ar_ang (- ang 1.57)]
Also, instead of 1.57 I would use (/ pi 2)
Message 3 of 13
ensomoran
While this was a mistake it seems to have not resolved the issue
Message 4 of 13
ВeekeeCZ
An arc is tricky, how about to use a polyline?
(vl-load-com)
(defun c:artic nil
  (command "_pline" pause "_a" "_s" pause pause ""
	   "_.insert" "arrow" "_s" 1
	   "_r" (angtos (+ (/ pi 2) (angle (vlax-curve-getsecondderiv (entlast) (vlax-curve-getendparam (entlast))) '(0 0 0))) 0 6)
	   "_non" (getvar 'lastpoint))
  (princ)
Message 5 of 13
Kent1Cooper
Just in terms of format:
(if (<= ang 1.57); parentheses issues; not ar_ang
  (setq ar_ang (+ ang 1.57)); then
  (setq ar_ang (- ang 1.57)); else -- parentheses, not brackets
But I don't think what you really want to test is whether the angle from the center to an end is <= 90°.
And I agree, (/ pi 2) is better than 1.57, however small the difference.
Kent Cooper, AIA
Message 6 of 13
ВeekeeCZ
...or the arc version with your/Kent's ang calculation.
(vl-load-com)
(defun c:artic ( / ang)
  (command "_.arc" pause pause pause)
  (setq ang (angle (vlax-curve-getsecondderiv (entlast) (vlax-curve-getparamatpoint (entlast) (getvar 'lastpoint))) '(0 0 0))
	ang (+ ang pi (/ pi (if (<= ang (/ pi 2)) 2 -2))))
  (command "_.insert" "arrow" "_s" 1
	   "_r" (angtos ang 0 6)
  (princ)
Message 7 of 13
ensomoran
Yeah I know the Pline would be easier but the standard we use at my company is an arch for the end of branch circuits on drawings.  When the arrows are not tangent to the end of the arch it pisses some people off.
Message 8 of 13
ВeekeeCZ
See THIS how to use a VLIDE for debugging.
Message 9 of 13
ensomoran
I think this one better than my code because it lets me see the arch before its placed but I have not idea how this one works.  It also still has the same issues as my original code, the arrow is 180 degrees off of when you draw it clockwise.
Message 10 of 13
ВeekeeCZ
I see... I did not test it well.
So lets get back to a pline which... does not require that silly ang calculation.
(vl-load-com)
(defun c:artic (/ ent)
	   "_r" (angtos (+ (/ pi 2) (angle (vlax-curve-getsecondderiv (setq ent (entlast)) (vlax-curve-getendparam (entlast))) '(0 0 0))) 0 6)
	   "._explode" ent)
  (princ)
Message 11 of 13
Kent1Cooper
If you're willing to be restricted to drawing the Arc by 3 points [not some of the other optional ways, which could involve different numbers of inputs, or result in a different ending direction], you can avoid the need to check for the angle, and the problem of the Arc's information always being stored as if it was drawn CCW, and which way you actually drew it, and finding its center, and saving points to variables, and all that, by using the LASTANGLE System Variable.  Try this:
(defun C:ARTIC ()
  (prompt "\nDraw 3-point Arc:\n")
  (command
    "_.insert" "ARROW" "@" "" "" (cvunit (getvar 'lastangle) "radian" "degree")
Kent Cooper, AIA
Message 12 of 13
ensomoran
@Kent1Cooper @ВeekeeCZ Thank you both of these work just fine, I need to study these a little to really understand whats going on but this helps a lot.
Message 13 of 13
Kent1Cooper
The LASTANGLE approach will also work after drawing it as a Polyline of one arc segment, rather than calculating angles by derivatives and parameters in (vlax-curve....) functions, etc.  But if it's going to be drawn by 3 points, and end up Exploded into a regular Arc anyway, it doesn't seem worth drawing it as a Polyline in the first place.
Kent Cooper, AIA
