Arraypath with various step values
Message 1 of 42
I would create a LISP that draw a circle at the starting or ending point (depends where I click) of a existing line.
Then with this circle I would do an ARRAYPATH but with different value of distance between the circles. The value of the distance should be taken from a fixed pool of values.
Example
1. I click on the line in the side where I want the circle (with fixed radius)
2. LISP command draws the circle
3. LIPS command draws a second circle "VAR1" unit far from the first circle, LIPS command draws a third circle "VAR2" unit far from the second circle, and so on until the end of the line/path.
"VAR1" "VAR2" "VAR3"... are fixed values that the command should take randomly.
It could be plus if I could edit manually some values of distance (maybe with something like a input text box between the circles).
Is it possible to do this? Maybe at the least without the random distance value?
Where I could find guide of the ARRAYPATH parameters?
Thank you
PS: I would change the default distance of the arraypath command. There isn't any system variable to change? I see only solutions with "actions recording" or "lisp" for this...and it can't be!!!šŸ˜…
Replies (41)
Message 2 of 42
Kent1Cooper
I don't think there's anything out-of-the-box that can do that.  It may be possible with a custom routine, for which you would be better off posting in the Customization Forum.
But I have a question [you could say something about it if you post there]:  Does "random" selection of distance values from a fixed list mean really random, or "controlled" random in some way?  For example, should it not use any value more than once?  A truly random selection, let's say 5 times, of values from a list could result in repeats of some value(s), or even [however unlikely] the same  value being drawn for all 5 selections.  Should a value that has been used be removed from the list before the next selection?
Of course, if the length of the path and the typical distances mean there will need to be more Circles than there are distances, it would be unavoidable to have repeats.  But should there be some attempt to have all the different values used, and spread the repeats around?
Kent Cooper, AIA
Message 3 of 42
Thank you for your reply, I will follow your suggest.
About your question on the "random mode", yes, I should have 5 times the same value.
About the attempts to fill the path completly using all the allowed distance value, it could be a nice feature but I think too much advanced for my case.
Can you help me about the default arraypath distance? There is a system variable to set?
Where a I could find a guide to make a custom LISP for the arraypath?
Thank you
Message 4 of 42
Š’eekeeCZ
Not sure if I follow you... but give it a try.
(vl-load-com)
(defun c:ArrayOfCircles ( / r d u p1 p2 d1 d2)
  (setq r 2.  				; radius
	d '(10. 8. 5. 3.5 3.5)		; distances
	i -1)
  (if (and (setq p1 (getpoint "\nPlace initial circle: "))
	   (setq p2 (getpoint p1 "\nPlace last circle: "))
	   (or (setq pl (car (nentselp p1)))
	       (setq pl (car (nentselp p2))))
	   (setq p1 (vlax-curve-getClosestPointTo pl p1))
	   (setq d1 (vlax-curve-getDistAtPoint pl p1))
	   (setq p2 (vlax-curve-getClosestPointTo pl p2))
	   (setq d2 (vlax-curve-getDistAtPoint pl p2))
	   (or (< d1 d2)
	       (prompt "\nError: Wrong direction."))
	   (entmake (list (cons 0 "CIRCLE") (cons 10 p2) (cons 40 r)))
    (while (< d1 d2)
      (entmake (list (cons 0 "CIRCLE") (cons 10 (vlax-curve-getPointAtDist pl d1)) (cons 40 r)))
      (setq d1 (+ d1 (cond ((nth (setq i (1+ i)) d))
			   ((nth (setq i 0) d)))))))
  (princ)
And to answer your question - the is no such variable. It's calculated somehow according to the actual length of the path.
Message 5 of 42
Moshe-A
@Anonymous  hi,
Check this one. it call ARPTH (Array Path)
this program is base on Lee's Mac (LM:randrange) function to get a random value so thank you very much Lee Mac
it works in a loop letting you pick a line path (actually it's a curve which lets you also select a polylines and splines) each one in a row.
the next code line defined the fix distances. you can changes these numbers as you like to meet your requirements.
(setq FIXVAL '(5.35 6.68 4.59 7.51 8.23 9.15 5.35 6.75 7.45))
also there is a constant defines the circle radius you can set it with your radius
(setq RADIUS 2)
another constant refers to the randomize value. there must be a limit for trying to get a random value otherwise the program might enter an infinite loop šŸ˜€  if 96 is a low value, you can increase (or decrease) it to speed the program.
(setq RANDTRY 96)
the program make sure there will not be an overlapping circles if you did not mind this i can remove this check.
and last:
the circles in each line path (curve) is collected and put in a group, giving the feel of array path (it's totally static you can not edit it, only select to move\copy\rotate or delete)
enjoy
Moshe
;; Rand  -  Lee Mac
;; PRNG implementing a linear congruential generator with
;; parameters derived from the book 'Numerical Recipes'
(defun LM:rand ( / a c m )
    (setq m   4294967296.0
          a   1664525.0
          c   1013904223.0
          $xn (rem (+ c (* a (cond ($xn) ((getvar 'date))))) m)
    (/ $xn m)
;; Random in Range  -  Lee Mac
;; Returns a pseudo-random integral number in a given range (inclusive)
(defun LM:randrange ( a b )
    (+ (min a b) (fix (* (LM:rand) (1+ (abs (- a b))))))
(defun c:arpth (/ wcs->ucs randomize ; local functions
                  RADIUS FIXVAL ss0 ss1 pick ename p0 p1 d0 d1 d2 seg len rnd dirMode bool)
 (defun wcs->ucs (pt)
  (trans pt 0 1)
 (defun randomize (/ n r)
  (setq n 0)
  (while (and
           (< n RANDTRY) ; make sure not enter infinite loop
           (< (setq r (nth (LM:randrange 0 (length FIXVAL)) FIXVAL)) (* RADIUS 2))
   (setq n (1+ n))
  (if (= n RANDTRY)
   (alert "radomize fail to generate a reasonable number.")
   r)
 ); radomize
 ; here start c:arpth
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 ; constant declaration
 (setq RANDTRY 96)   ; max radomize tries
 (setq RADIUS 2)     ; fix circle radius
 ; fix dist values
 (while (setq ss0 (ssget ":s:e+." '((0 . "*line")))) ; line,polyline,lwpolyline,spline can be picked here
  (setq pick (ssnamex ss0))
  (setq ename (cadar pick))
  (setq p0 (cadr (last (car pick))))
  (setq d0 0.0)
  (setq d1 (vlax-curve-getDistAtParam ename (vlax-curve-getParamAtPoint ename (vlax-curve-getClosestPointTo ename p0))))
  (setq d2 (vlax-curve-getDistAtParam ename (vlax-curve-getEndParam ename)))
  (if (setq dirMode (< d1 (- d2 d1)))
   (setq bool '< seg 0.0 upto d2)
   (setq bool '> seg d2 upto 0.0)
  (setq rnd t len d2)
  (setq ss1 (ssadd)) ; for group
  (while (and rnd (eval (list bool seg upto)))
   (setq p1 (wcs->ucs (vlax-curve-getPointAtDist ename seg)))
   (command "._circle" p1 RADIUS)
   (ssadd (entlast) ss1)
   (if (setq rnd (randomize))
    (if dirMode
     (setq seg (+ seg rnd))
     (setq seg (- len (setq d0 (+ d0 rnd))))
    ); if
   ); if
  ); while
  (command "._group" "" "*" "" "_si" ss1)
  (setq ss1 nil)
 ); while
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
); c:arpth
Message 6 of 42
Š’eekeeCZ
Also, I remember THIS  video referring to SCATTER  routine. See if you find it helpful.
Message 7 of 42
Thank you!
of course I gave it a chance. The idea is correct but I need to select arcs too.
Do you think it can works with some edit?
Message 8 of 42
Thank you for your time.
I've tried with this
 (setq RANDTRY 20)   ; max radomize tries
 (setq RADIUS 3)     ; fix circle radius
 ; fix dist values
 (setq FIXVAL '(20 30 40))
but i got this (see picture below)
There is maybe something I've not understood.
What I meant is that the command must randomly choose between the values ​​"20" "30" "40" and draw the circle.
Does your LISP works with arcs too? It seems not on my tries.
Sorry, maybe I has not been enought clear on my question.
Do you think your command are "fixable" in this way?
Thank you in advance again
Message 9 of 42
Moshe-A
@Anonymous
@Anonymous wrote:
Thank you!
change this line
to this line
(while (setq ss0 (ssget ":s:e+." '((0 . "*line,arc")))) ; line,polyline,lwpolyline,spline + ARCs can be picked here
Message 10 of 42
pbejse
Indeed, the surprise is killing me, how is it supposed to look anyway?
Message 11 of 42
Moshe-A
of course it picks distance randomly, you did not specifies enough values to look it selects varies value
Message 12 of 42
Š’eekeeCZ
Here you go. Also added a second version for even more fun!
(vl-load-com)
(defun c:ArrayOfCircles ( / r d i p1 p2 d1 d2 o1 o2)
  (setq r 2.  				; radius
	i -1)
	   (if (< d1 d2)
	     (setq o1 < o2 +)
	     (setq d (reverse d) o1 > o2 -))
    (while (o1 d1 d2)
      (setq d1 (o2 d1 (cond ((nth (setq i (1+ i)) d))
  (princ)
(vl-load-com)
(defun c:ArrayOfCirclesRandom ( / r d i p1 p2 d1 d2 o1 o2)
  ;; Rand  -  Lee Mac
	  a   1664525.0
	  c   1013904223.0
	  $xn (rem (+ c (* a (cond ($xn) ((getvar 'date))))) m))
    (/ $xn m))
    (+ (min a b) (fix (* (LM:rand) (1+ (abs (- a b)))))))
  (setq r 2.  				; radius
	i -1)
	   (if (< d1 d2)
	     (setq o1 < o2 +)
	     (setq o1 > o2 -))
    (while (o1 d1 d2)
      (setq d1 (o2 d1 (nth (LM:randrange 0 (1- (length d))) d)))))
  (princ)
Message 13 of 42
Moshe-A
@Anonymous ,
here is a modified version supporting arcs plus adopting your distance list.
also i add a prompt for the circle radius so you can set a new value each invocation.
make sure you select a large curve to accept your distance list.
Moshe
;; Rand  -  Lee Mac
          a   1664525.0
          c   1013904223.0
    (/ $xn m)
(defun c:arpth (/ initialization askdist wcs->ucs randomize ; local functions
                  defrad RANDTRY RADIUS FIXVAL ss0 ss1 pick ename p0 p1 d0 d1 d2 seg len rnd dirMode bool)
 (defun initialization ()
  ; fix dist values
  (setq FIXVAL '(20.0 30.0 40.0 50.0 60.0))
  (if (= (getvar "userr4") 0.0)
   (setq defrad (setvar "userr4" 2.0))
   (setq defrad (getvar "userr4"))
 ); initialization
 (defun askdist (def / ask)
  (initget (+ 2 4))
  (if (not (setq ask (getdist (strcat "\nCircle radius <" (rtos def 2 2) ">: "))))
   (setq ask def)
   (setq def ask)
 ); askdist
  (trans pt 0 1)
  (setq n 0)
  (while (and
   (setq n (1+ n))
  (if (= n RANDTRY)
   (alert "randomize fail to generate a reasonable number.")
   r)
 ); randomize
 (initialization)
 (setvar "userr4" (setq radius (askdist defrad)))
  (setq d0 0.0)
  (setq rnd t len d2)
    (if dirMode
    ); if
   ); if
  ); while
  (setq ss1 nil)
 ); while
 (princ)
); c:arpth
Message 14 of 42
@Š’eekeeCZ
@Moshe-A
Thank you VERY much! šŸ’™šŸ˜ŠšŸ»
Message 15 of 42
pbejse
Another
(defun c:Crayon ( / LM:rand LM:randrange _DistList rad ss en eLent sym d)
  ;; Rand  -  Lee Mac
	  a   1664525.0
	  c   1013904223.0
    (/ $xn m))
(Defun _DistList (data / opt d)
(setq inc 0)(initget "Yes New")
(cond
 ( (and data
     (eq (setq opt (Getkword (strcat  "\nUse Previous data :[Yes/New]"
				      (vl-prin1-to-string data) "<New>?"))) "Yes"))
    data
 ( (and data (/= opt "Yes"))
  	(_DistList nil)
 ( (null data)
   (while (and (null (initget 6))
	       (setq d (getdist (strcat "\nEnter Distance " (itoa (setq inc (1+ inc)))))))
  	(print (reverse (setq data (cons d data))))
(and
	(setq rad 2.0 values ( _DistList values))
	(while 	(setq ss (ssget "_+.:S:E" '((0 . "*LINE,ARC"))))
		(setq en (cadar (ssnamex ss)))
		(setq nsp (vlax-curve-getClosestPointTo en (cadr (last (car (ssnamex ss))))))
	  	(setq eLent (vlax-curve-getDistAtPoint en (Vlax-curve-GetEndpoint en)))
	  	(setq sym (if (< (vlax-curve-getDistAtPoint en nsp) (* eLent 0.5))
			    (progn (setq eLent 0) +) -))
	  	(while (and (setq d (nth (LM:randrange 0 (1- (length values))) values))
			 	(setq pt (vlax-curve-getPointAtDist en (setq eLent (sym eLent d)))))
	  	 	 (entmake (list (cons 0 "CIRCLE") (cons 10 pt) (cons 40 rad)))
  (princ)
Similar approach as @Š’eekeeCZ : added extra features like prompting for distance values
Command: CRAYON
Enter Distance 18
(8.0)
Enter Distance 26.3
(8.0 6.3)
Enter Distance 35.2
(8.0 6.3 5.2);< shows current listing
Enter Distance 4
Select objects:
Select objects: <- continue selection
Command:  CRAYON
Use Previous data :[Yes/New](8.0 6.3 5.2)<New>? Y ;<--- Shows current data
Select objects:
Command:  CRAYON
Use Previous data :[Yes/New](8.0 6.3 5.2)<New>?N <--- type in new data
Enter Distance 14
(4.0)
Enter Distance 28
(4.0 8.0)
Enter Distance 35.2
(4.0 8.0 5.2)
Enter Distance 4
Select objects:
HTH
Message 16 of 42
Thank you.
In my case I don't need to change the values, but sure it's useful see the code and keep it for the future. šŸ˜‰
Message 17 of 42
pbejse
@Anonymous wrote:
Thank you.
No worries mega-mini, was just thinking since you mention it needs to be random, whats more random than the capability to provide diffferent distance.  We can however set the initial values?
Anyways, glad you like it.
Message 18 of 42
In my case, a really improved could be the possibility to edit manually some distance after the circles have been drawed.
Example (setted distances: 15 18 21 24).
Command drawed four circle with distances 21, 18, 18, 24. Distance between the first and the last circle is 81 (21+18+18+24). I would be able di change the second distance (maybe with an input textbox) moving all the follwing  step. So i could manually change distances 21, 15, 18, 24 and moving the third and the fourth circles, distance between the first and the last circle should be 78 now.
Message 19 of 42
Š’eekeeCZ
Did you end up with my random version of routine? Or which one?
The described process...
- are you doing this fine-tuning right away with every single 'array placement'?
- if the routine zoom-in to your segment and pop-up list of actual values to you to edit... would that be ok? Or do you need to make some kind of measurements before the edits?
I'm thinking of this "edit" screen at the end of the routine... there would be listed the actual values.. you'll set what you want and it will be applied on the circles. But it's a modal dialog.
Edit: Do you need to see those circles drawn at all? Won't be enough to give you just numbers - you know, overall length and randomly generated numbers...   That might be easier to do...
Message 20 of 42
pbejse
Command drawed four circle with distances 21, 18, 18, 24. Distance between the first and the last circle is 81 ....should be 78 now.
I guess "random" means any order of the four given distance [ 15 18 21 24 ] but no repeats Yes? what about the next group after that? or does it mean when you reach the total of the distance list, the program terminates regardless how long the selected object is?
Please show us how it really should look  @Anonymous  šŸ™‚
