(defun c:PT (/ o l pt va di an et xval noc obj1 e)
(setq
pt (getpoint "\nPick the first point:")
xv(car pt) yv(cadr pt)
va (getpoint pt "\nPick the second point:")
et (getdist "\nEnter Thickness:")
an (angtos(angle pt va)2 3)
xval (getdist "\nEnter Length (X value):")
sd(getint "\n Enetr Spacer :")
dbc(+ xval sd)
xy(list xv (+(- yv 80)et))
p3(polar pt (/ pi 2) 10)
(if (zerop xval)
(progn
(princ "\nError: Length (X value) cannot be zero.")
(exit)
(setq di (distance pt va))
(setq noc (fix (+ 1(/ di xval))))
(if (< noc 1)
(setq noc 1)
(command "ZOOM" "S" pt va)
(command "_.Insert" "D:/IDS/OTHERS/PAT.DWG" pt "" "" an)
(setq obj1 (entlast))
(setq o (vlax-ename->vla-object obj1))
(setq l (list (cons "X" xval) (cons "Y" et)))
(foreach prop (vlax-safearray->list (vlax-variant-value (vla-getDynamicBlockProperties o)))
(if (setq e (assoc (vla-get-PropertyName prop) l))
(vla-put-value prop (vlax-make-variant (cdr e) 5))
(command "copy" obj1 "" pt "ar" noc (polar pt (angle pt va) dbc) "")
(command "ZOOM" "P")
(princ an)
