Array Object Not parallel to the line What error ?
jaimuthu
jaimuthu
(defun c:PT (/ o l pt va di an et xval noc obj1 e)
  (setq
    pt (getpoint "\nPick the first point:")
    xv(car pt) yv(cadr pt)
    va (getpoint pt "\nPick the second point:")
    et (getdist "\nEnter Thickness:")
    an (angtos(angle pt va)2 3)
    xval (getdist "\nEnter Length (X value):")
    sd(getint "\n Enetr Spacer :")
    dbc(+ xval sd)
     xy(list xv (+(- yv 80)et))
    p3(polar pt (/ pi 2) 10)
  (if (zerop xval)
    (progn
      (princ "\nError: Length (X value) cannot be zero.")
      (exit)
  (setq di (distance pt va))
  (setq noc (fix (+ 1(/ di xval))))
  (if (< noc 1)
    (setq noc 1)
  (command "ZOOM" "S" pt va)
  (command "_.Insert" "D:/IDS/OTHERS/PAT.DWG" pt "" "" an)
  (setq obj1 (entlast))
  (setq o (vlax-ename->vla-object obj1))
  (setq l (list (cons "X" xval) (cons "Y" et)))
  (foreach prop (vlax-safearray->list (vlax-variant-value (vla-getDynamicBlockProperties o)))
    (if (setq e (assoc (vla-get-PropertyName prop) l))
      (vla-put-value prop (vlax-make-variant (cdr e) 5))
  (command "copy" obj1 "" pt "ar" noc (polar pt (angle pt va) dbc) "")
  (command "ZOOM" "P")
  (princ an)
Moshe-A
@jaimuthu ,
why did you open a new thread?
i see you have a working lisp?
what do you mean by not parallel?
you want the blocks to be aligned exactly on the line you select?
komondormrex
add
(command "move" obj1 "" "_non" (vlax-get o 'insertionpoint) "_non" pt)
before
jaimuthu
thanks komondormrex its work good
