Areas to field (attribute in dynamic block)
djurk_haas
djurk_haas
I found the lisp: Areas2FieldV1-3.lsp at "www.lee-mac.com".
I wonder if it's possible to:
1) Instead of the select objects -> immeditly select polylines on one specific layer (e.g. 00---0--FM-RUIMTEDEFV)
2) Add the field to an atrribute (VLOEROPP) in a dynamic block (FM_RM3). In the drawing are multiple blocks, so I want to select the specific block (Totaal) where the field must be inserted.
Can some one help me with this?
Thanks in advance.
ВeekeeCZ
a) still need this?
b) don't understand your point 2. You want to match the polyline and block manually?
djurk_haas
My " prolem" is solved.
Thanks for your reply
