Area field + m²
Area field + m²
aclima
Message 1 of 18
Area field + m²
aclima
Hello.
I believe this lisp may already exists but I've not be able to find it. Maybe one of you can help me.
I'm looking for a lisp that creates an mtext with the area of a polyline as object "field" and the suffix "m²", will be very useful for the work I'm doing. thank you
Replies (17)
Message 2 of 18
dennis
Message 3 of 18
Ranjit_Singh
Here's a very basic version
(defun c:somefunc  (/ mtobject mtht)
 (setq mtht     (getreal "\nEnsert mText Height: ")
       mtobject (vla-addmtext (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
                              (vlax-3d-point (getpoint "\nInsert mText Insertion Point :"))
                              0
                              (strcat "%<\\AcObjProp Object(%<\\_ObjId "
                                      (itoa (vla-get-objectid (vlax-ename->vla-object (car (entsel "\nSelect Polyline: ")))))
                                      ">%).Area \\f \"%lu2%pr2%th44\">%"
                                      " m{\\H0.7x;\\S2^;}")))
 (vla-put-height mtobject mtht)
(princ))
Message 4 of 18
aclima
Hello
Thank you, this error appears after importing lisp with appload. Same arror appear after running the command.
"somefunc.lsp successfully loaded.
Command: ; error: malformed list on input
Command: ; error: malformed list on input"
Message 5 of 18
Ranjit_Singh
Try the attached
Message 6 of 18
aclima
Hi again!
Thanks a lot for the help.
I would make the following two changes: the command would not ask what the height of mtxt would be (it would use the default value), and more importantly, it would allow the user to change the pecision of the value it displays. In the work I am currently doing, for example, I should not present decimal places.
I also noticed that the text is not placed at the insertion point if the UCS is rotated.
Still, it's already a good help, thank you.
Message 7 of 18
Ranjit_Singh
I am mostly working in wcs and never try to catch ucs in my routines. Those are good points. Try below code.
(defun c:somefunc  (/ mtobject mtprec)
 (initget 7)
 (setq mtprec     (getint "\nEnter mText decimal Precision: ")
                              (vlax-3d-point (trans (getpoint "\nInsert mText Insertion Point :") 1 0))
                              0
                                      ">%).Area \\f \"%lu2%pr" (if (> mtprec 8) "8" (itoa mtprec)) "%th44\">%"
 (vla-put-height mtobject (getvar 'textsize))
 (mapcar '(lambda (x y) (setpropertyvalue (entlast) x y)) '("Direction/X" "Direction/Y") (list (car (getvar 'ucsxdir)) (cadr (getvar 'ucsxdir))))
 (princ))
Message 8 of 18
aclima
Nice 🙂
The only thing is, if i'm using it correctly, it doesn't allow to remove all decimal places with the "Enter mText decimal Precision" input. The minimum acceptable is 1.
I would also present the last value imputed in this option as default when running the command again command , to speed up the process of multiple area tagging.
thanks
Message 9 of 18
Ranjit_Singh
That shouldn't be too difficult.
(defun c:somefunc  (/ mtobject prec)
 (if (null *somefuncmtprec*) (setq *somefuncmtprec* 2))
 (initget 4)
 (setq prec     (getint (strcat "\nEnter mText decimal Precision <" (itoa *somefuncmtprec*) ">: "))
                              0
                                      ">%).Area \\f \"%lu2%pr" (if (> prec 8) (progn (setq *somefuncmtprec* 8) "8") (if (null prec) (itoa *somefuncmtprec*) (progn (setq *somefuncmtprec* prec) (itoa *somefuncmtprec*)))) "%th44\">%"
 (princ))
Message 10 of 18
aclima
Thank you! 🙂
It works beautifully and will be a great help.
Message 11 of 18
Ranjit_Singh
You are welcome Smiley Happy
Message 12 of 18
SufyanAhmed
Hi,Aclima
Find the attached file may be found useful to You.
Message 13 of 18
aclima
hello. This lisp is not working anymore, can you help?
Message 14 of 18
cadffm
It is working the same way as before,  also in 2023.
Open a new file, draw a rectangle
load the lisp by APPLOAD and run command AA2
after this (you say it dowsn't work),
open your Textscreen[F2] and share the log content with us all.
Sebastian
Message 15 of 18
aclima
Hi, Thanks for the feed back, I'm referring to this one from @Ranjit_Singh .
Cad loads but doesn't run, command is "mtobject", right?
Message 16 of 18
cadffm
Oh, okay - I checked the other one.
No (error)message?
Normally you get a message!?
Like "unknown command" is you try to start a command what doesn't exist.
That looks more like "somefunc" 🙂
Sebastian
Message 17 of 18
aclima
somefunc, of course.
silly mistake. 🙂 Beautiful!
Thanks!
Message 18 of 18
fpanUVCLZ
Observer
Observer
hello,
this LISP is good help for me. thank you for your sharing.
I'd like to make the following two changes: the command would not ask what the height of mtext, but it would use 200 height as default value. Also, the command would not ask what the precision of the value it displays, it would setting a precision of 3 d.p. as default value.
thanks.
