Area Field LISP by Lee Mac to mod
karpki
Message 1 of 21
karpki
I use AFM Lisp made by Lee Mac to label areas by picking hatches (most often scenario)
How to mod the code (add some lines ?) so it will check all hatches in the drawing and place such label in the middle of each hatch by one click ?
Thanks in advance!
Regards
Kirill
Replies (20)
Message 2 of 21
ВeekeeCZ
Found this in my archive. You can play with part commented out if you want.
(vl-load-com)
(defun c:PLArea  (/ adoc acsp ss e ptList ID StrField txt p)
  (setq  acsp (vla-get-modelspace (setq adoc (vla-get-activedocument (vlax-get-acad-object)))))
  (vla-startundomark adoc)
  (if (setq ss (ssget ;(progn
			;(initget 1 "Y N")
                        ;(setq ans (getkword "\nProcess All Polylines [Yes/No]: "))
			;(if (eq "Y" ans)
			  ;"_X"
			  ":L";))
		      '((-4 . "<OR")
                        	(0 . "CIRCLE")
                        	(-4 . "<AND")
                        		(0 . "*POLYLINE")
                        		(-4 . "&")
                        		(70 . 1)
                        	(-4 . "AND>")
                        (-4 . "OR>")
    (repeat (sslength ss)
            (setq e     (ssname ss 0)
                  sum   '(0 0)
                  verts (cond ((cdr (assoc 90 (entget e))))
                              (1)))
            (setq ptList (mapcar 'cdr
                                 (vl-remove-if-not
                                   '(lambda (x)
                                      (= (car x) 10))
                                   (entget e))))
            (foreach x ptList (setq sum (mapcar '+ x sum)))
            (setq ID (itoa (vla-get-objectid (vlax-ename->vla-object e))))
            (setq StrField (strcat "%<\\AcObjProp Object(%<\\_ObjId "
                                   ID
                                   ">%).Area \\f \"%lu2\">%"))
            (vla-put-AttachmentPoint
                  (setq txt (vla-addMText
                                  acsp
                                  (setq p (vlax-3d-point
                                                   (mapcar '/ sum
                                                         (list verts
                                                               verts))))
                                  0  StrField))
                  acAttachmentPointMiddleCenter)
            (vla-put-InsertionPoint txt p)
            (ssdel e ss)
    (princ "\n0 Objects found:"))
  (vla-endundomark adoc)
  (princ)
Message 3 of 21
karpki
Thank you!
The code itself works
And yes I will "play" trying to adjust it for my tasks.
Good!
Will be back
Regards
K
Message 4 of 21
braudpat
Hello @karpki
An other beautiful Area Routine from (gile) !
PolyArea runs on many entities : ALL 2D PLines, Circles, Ellipses, Regions, etc ...
If you want to run ONLY on Closed PLines you can modify the Code !
You have BOTH Filters ... Comment / UnComment ...
You can easily change the code : number of decimals, suffix, ...
Thanks to Gilles (gile) !
The Health, Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 5 of 21
karpki
Hi
Changed your lisp little bit, so it works with hatches without asking Y or N, just one click
BUT can't handle that label appears quite away of the hatch
Could you pls correct it ?
Message 6 of 21
ВeekeeCZ
The thing with HATCH different from LWPOLYLINEs is that you need to omit the first 'vertex'.
Btw, the algorithm of center calculation is really simple, so if you have some odd shape it goes to hell anyway. Don't rely on it.
(setq ptList (cdr (reverse (cdr (mapcar 'cdr
                                 (vl-remove-if-not
                                   '(lambda (x)
                                      (= (car x) 10))
                                   (entget e)))))))
Edit: Last one too.
Message 7 of 21
karpki
Hi and thank you!!!
I tried to modify this code for hatches but unfortunately it wasn't successfully
Could you please help?
BR
K
Message 8 of 21
ВeekeeCZ
See the edit.
btw you can try yourself what vertices you've got to work with:
(mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car (entsel)))))
copy/paste it into the command-line.
Message 9 of 21
karpki
Shapes are quite simple in test file, see area 1 below
Hatches have their centers inside areas
But labels are in hell, yes, see area 2 below
adding (cdr................) didn't effect unfortunately
Message 10 of 21
karpki
ok , testing next edit in process
Message 11 of 21
karpki
no effect
again same picture
Message 12 of 21
karpki
test file
Message 13 of 21
ВeekeeCZ
Ok.. your layer def is bad. Also we need to fix no of vertices.
;; Z9E3zK5E
;; в ответ: karpki
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/area-field-lisp-by-lee-mac-to-mod/td-p/10167964
(vl-load-com)
(defun c:AFM2  (/ adoc acsp ss e ptList ID StrField txt p)
  (command "_style" "ISOCPEUR" "ISOCPEUR" "500" "" "" "" "")
  (command "_layer" "_m" "_Areas" "_Color" "7" "" "")
  (if (setq ss (ssget "_A" '(( 0 . "HATCH"))))
	    sum   '(0 0)
			   (vl-remove-if-not
			     '(lambda (x)
				(= (car x) 10))
			     (entget e))))))
	    verts (length ptList))
			     ID
			     ">%).Area \\f \"%lu2%pr1%ps[, m\\\\U+00B2]%ct8[1.0E-006]\">%"))
		    acsp
			      (mapcar '/ sum
				      (list verts
					    verts))))
		    0  StrField))
      (ssdel e ss)
  (princ)
Message 14 of 21
karpki
The code (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car (entsel))))) in command line ask me to select the object, after picking the hatch result tells me nothing talking true
Message 15 of 21
karpki
Much better, almost perfect !
What do you think abt more difficult hatch with the "column" see screenshot below
Can this be fixed ?
Message 16 of 21
karpki
"_Areas"
is one of my working layer always presented in drawing
that's why I use  "_s"
Message 17 of 21
braudpat
Hello @ВeekeeCZ
I like this :
\\\\U+00B2
Patrice BRAUD
Message 18 of 21
ВeekeeCZ
Can this be fixed ?
Ok, it was enough of hatch vertices, here's another method.
(vl-load-com)
(defun c:AFM2 ( / *error* doc msp stl s i e o p m ll ur)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if stl (setvar 'textstyle stl))
    (vla-endundomark doc)
    (princ))
  (setq doc (vla-get-activedocument (vlax-get-acad-object))
	msp (vla-get-modelspace doc)
	stl (getvar 'textstyle))
  (vla-startundomark doc)
  (or (tblsearch "STYLE" "ISOCPEUR")
      (command "_.style" "ISOCPEUR" "ISOCPEUR" "500" "" "" "" ""))
  (or (tblsearch "LAYER" "_Areas")
      (command "_.-layer" "_n" "_Areas" ""))
  (if (setq s (ssget "_A" (list '(0 . "HATCH") (cons 410 (getvar 'ctab)))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    o (vlax-ename->vla-object e))
      (if (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list o 'll 'ur))))
	(progn
	  (setq p (vlax-3d-point (mapcar '/ (apply 'mapcar (cons '+ (mapcar 'vlax-safearray->list (list ll ur)))) '(2 2)))
		m (vla-addMText msp p 0 (strcat "%<\\AcObjProp Object(%<\\_ObjId "
						(itoa (vla-get-objectid o))
						">%).Area \\f \"%lu2%pr1%ps[, m\\\\U+00B2]%ct8[1.0E-006]\">%")))
	  (vla-put-AttachmentPoint m acAttachmentPointMiddleCenter)
	  (vla-put-InsertionPoint m p)
	  (vla-put-Layer m "_Areas")
	  (vla-put-Color m 7)
	  (vla-put-StyleName m "ISOCPEUR")
  (*error* "end")
Message 19 of 21
ВeekeeCZ
@karpki wrote:
"_Areas"
I did not see that you set the color as text's property, not layer's.
Anyway, it might happen that for some extraordinary reason the layer won't there, the program will crash without saying why, so you'll be wondering..... better make sure it's there or tell the user that it's required in the error message.
(or (tblsearch "layer" "_Areas")
       (prompt "Error: No layer _Areas in the drawing."))
Message 20 of 21
ВeekeeCZ
@braudpat wrote:
Hello @ВeekeeCZ
I like this :
\\\\U+00B2
Thanks, Patrice.
Here's the paradox - personally, I would never use this particular sign of index number in my drawings. Always use a regular number m2. It's just easier to do and still understandable enough. But it's a small exception from typography rules that I really do try to follow otherwise 🙂
But agree that it's a nice trick for the Unicode chars in generel.
PS. This one was added by @karpki  himself 🙂
