Any lisp for copy/paste blocks from its insertion point
josue777torsan
josue777torsan
Architect, CAD Manager in Mexico City
komondormrex
multiple copying of selected block by its insertion point. not a clipboard copy/paste.
(defun c:block_multiple_copy (/ insert)
	(while (null (vl-catch-all-error-p
						(vl-catch-all-apply
							'vl-cmdf
							(list "_.copy"
							   	 (if insert
								 		insert
							   			(setq insert (car (entsel "\nPick a block to copy: ")))
							   	 (cdr (assoc 10 (entget insert)))
								 pause
Kent1Cooper
If you're talking about within the same drawing, just select the Block, pick on its insertion point grip, grip-editing will go into Stretch mode, and type the letter for the Copy option, and place as many as you like.  [Or, select it, pick on the insertion point grip, hit Enter/space to go into Move mode, type C and place them just as in Stretch mode.]
Or do you mean copying/pasting between different drawings?
Kent Cooper, AIA
pendean
Community Legend
Community Legend
@josue777torsan COPYBASE command (CTRL+SHIFT+C) is there all day long to do that if you have your INS osnap running: is that all you wish to automate, having the correct osnap running when you use that built-in tool to do what you seek?
john.uhden
@pendean ,
This response may not help the OP at all, but I love the way that if you select one or more objects and hit Ctrl+C, the selection is copied from the lower left extents of the objects selected.  It's great when copying notes and/or details from one dwg  or layout to another.  Yes, I also use COPYBASE when the objects must land at a specific location.
BTW, thanks for pointing out Ctrl+Shift+C.  That's a huge improvement over typing "COPYBASE."
John F. Uhden
josue777torsan
Yes, I think the best way is to use the typical ctrl+Shift+C and then paste.
Thanks everyone!
