Visual LISP, AutoLISP and General Customization
Another block definition in code and ordering pages
0 REPLIES 0
Message 1 of 1
JelleDJs
180 Views, 0 Replies
Hello everyone,
A while ago, I got the following code which works good.
However, we want to be able to select another block definition.
How do I add that, or can someone give me the edited code?
We also have a second issue.
The code below automatically orders the pages in the order of: 01.01A, 01.01B, 01.01
Is it possible to change the order it gets to: 01.01, 01.01A, 01.01B
(defun c:Printen_liggend ( /  Bladnr sheet Tblocks i e pts order)
(if
  (setq Tblocks (ssget '((0 . "INSERT")(66 . 1)(2 . "PRINTBLAD"))
  (progn
    (repeat (setq i (sslength Tblocks))
      (setq e (vlax-ename->vla-object (ssname Tblocks (setq i (1- i)))))
	(vla-GetBoundingBox e 'll 'ur)
        (setq pts (mapcar '(lambda (p)
		    (setq pt (vlax-safearray->list p))
			     (list (car pt)(cadr pt))) (list ll ur)))
      	(setq Bladnr (vl-some '(lambda (At)
				 (if (eq "Bladnr." (vla-get-tagstring at))
				   (vla-get-textstring at)))
	  			(vlax-invoke e 'GetAttributes)
      	(setq order (cons (list Bladnr pts) order)
    (setq order
	   (vl-sort order '(lambda (a b)
		       (< (distof (car a))(distof (car b)))))
(while (setq sheet (Car order))
	  (command "PLOT" "Y" ""
	           ;"DWG to PDF"
		   ;"ISO A3 (420.00 x 297.00 MM)"
             "PDFCreator"
       "A3"
		   "M"
	           "L" "N" "W"
	           "_non" (caadr sheet) "_non" (cadadr sheet)
	           "F" "C" "Y" "2D_HSB HP" "Y" "A"
		   ;(car sheet)
	           "N" "Y" "Y")
  	(setq order (cdr order))
(princ)
 In case it wasn't clear, English isn't my motherlanguage. So if there are spelling mistakes, it is because of that.
Thanks in advance.
0 REPLIES 0
AutoCAD Inside the Factory
