Visual LISP, AutoLISP and General Customization
Angle of polyline with tilt.
32 REPLIES 32
Message 1 of 33
HarrySK
2039 Views, 32 Replies
I'm trying to angle of polyline. Identify Angle of the polyline left side or right side is which side tilt. And it must report in CSV format. Attached lisp file, it gives polyline angles.
Advance Thanks.
(defun w_ang? ( p1 px p2 / l_pt l_d p ang)
(setq
l_pt (mapcar '(lambda (x) (list (car x) (cadr x))) (list px p1 p2))
l_d (mapcar 'distance l_pt (append (cdr l_pt) (list (car l_pt))))
p (/ (apply '+ l_d) 2.0)
(if (zerop (* p (- p (cadr l_d))))
(setq ang pi)
(setq ang (* (atan (sqrt (/ (* (- p (car l_d)) (- p (caddr l_d))) (* p (- p (cadr l_d)))))) 2.0))
(angtos (- pi ang) (getvar "AUNITS") (getvar "AUPREC"))
(defun c:id_pline_ang ( / js a_base a_dir ent dxf_ent pt_lst l_ang)
(while (not (setq js (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))))
(setq
a_base (getvar "ANGBASE")
a_dir (getvar "ANGDIR")
ent (ssname js 0)
dxf_ent (entget ent)
pt_lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_ent))
(setvar "ANGBASE" 0)
(setvar "ANGDIR" 0)
(while (and (car pt_lst) (cadr pt_lst) (caddr pt_lst))
(setq
l_ang (cons (w_ang? (car pt_lst) (cadr pt_lst) (caddr pt_lst)) l_ang)
pt_lst (cdr pt_lst)
(setvar "ANGBASE" a_base)
(setvar "ANGDIR" a_dir)
(reverse l_ang)
32 REPLIES 32
Message 21 of 33
HarrySK
in reply to: CADaSchtroumpf
Revised bearig excel sheet.
Message 22 of 33
CADaSchtroumpf
in reply to: HarrySK
With bearing...
(defun c:deflection_ang ( / js a_base a_dir ent dxf_ent pt_lst bear count l_ang cumd ang0 ang1 ang v1 v2 det_or file2open f_open)
  (setq
    ent (ssname js 0)
  (setvar "ANGDIR" 1)
  (setvar "ANGBASE" (* 0.5 pi))
  (setq bear (angtos (angle (car pt_lst) (cadr pt_lst)) 1 4))
  (setvar "ANGDIR" 0)
  (setq
    count 0
    l_ang
      (list
        (strcat "P" (itoa count) ","
          (vl-string-subst "°" "d" (angtos 0.0 1 4)) ", ,"
          (vl-string-subst "°" "d" bear) ",0.000\n"
    cumd 0.0
  (while
    (and
      (car pt_lst)
      (cadr pt_lst)
      (caddr pt_lst)
    (setq
      ang0 (angle (car pt_lst) (cadr pt_lst))
      ang1 (angle (cadr pt_lst) (caddr pt_lst))
      ang (abs (- ang0 ang1))
      ang (if (or (> ang (* 0.5 pi)) (< ang 0.0)) (abs (- (* 2 pi) ang)) ang)
      ang (if (> ang pi) (rem (* 2 pi) ang) ang)
    (setvar "ANGDIR" 1)
    (setq bear (angtos (angle (cadr pt_lst) (caddr pt_lst)) 1 4))
    (setvar "ANGDIR" 0)
    (setq
      v1 (mapcar '- (polar (cadr pt_lst) ang0 1.0) (cadr pt_lst))
      v2 (mapcar '- (caddr pt_lst) (cadr pt_lst))
      det_or (apply '(lambda (x1 y1 x2 y2) (- (* x1 y2) (* y1 x2))) (append v1 v2))
      count (1+ count)
      l_ang
        (cons
          (strcat
            (vl-string-subst "°" "d" (angtos ang 1 4))
            (if (< det_or 0.0) ",Rt." ",Lt.") ","
            (vl-string-subst "°" "d" bear) ","
            (rtos (setq cumd (+ cumd (distance (car pt_lst) (cadr pt_lst)))) 2 3) "\n"
          l_ang
      pt_lst (cdr pt_lst)
  (setq l_ang
    (cons
      (strcat
        "P" (itoa (1+ count)) ","
        (vl-string-subst "°" "d" (angtos 0.0 1 4)) ","
        (rtos (+ cumd (distance (car pt_lst) (cadr pt_lst))) 2 3) "\n"
      l_ang
  (setq
    file2open (strcat (getvar "DWGPREFIX") (getvar "DWGNAME") ".CSV")
    f_open (open file2open "w")
  (princ "Points,Angle (DMS),L/R,Bearing,Chainage\n" f_open)
  (foreach n (reverse l_ang)
    (princ n f_open)
  (close f_open)
  (princ (strcat "\nInfo as be writen in " (getvar "DWGPREFIX") (getvar "DWGNAME") ".CSV"))
  (prin1)
Message 23 of 33
HarrySK
Sir, I think the 0°0'0" should not come in the end of the bearing. In the beginning of 0°0'0" to be so good. I am sorry for the trouble.
Message 24 of 33
CADaSchtroumpf
In your exemple in post 21, you wrote for P169 a bearing to : 132°28'01"
I don't understand how you obtain this?!
I have prefer to writre 0d0'0" at this place
If you want nothing, change:
    (setq l_ang
        (cons
            (strcat
            l_ang
by:
    (setq l_ang
        (cons
            (strcat
            l_ang
Message 25 of 33
HarrySK
I have to highlight in red the changes were meant to. I had the correct change in csv.
If the right changes is shown in red (Images).
Message 26 of 33
CADaSchtroumpf
With arrangements?
Message 27 of 33
HarrySK
Thank you very much.
Message 28 of 33
HarrySK
Sir, I again found an error in your Lisp. Please Point No. 77, 101, 114 check.
Message 29 of 33
ВeekeeCZ
As I watch this thread so I wonder, would not it be much easier to export only the angle of each segment in radians and you would count all you need in Excel?
Message 30 of 33
CADaSchtroumpf
I don't have problem with the file generated!
I don't know why you have this problem!
NB: 12°43'0" = 12°42'60" but the notation is not correct
See my CSV
Message 31 of 33
HarrySK
AutoCAD drawing file was a problem. Polyline pasted into another drawing so CSV come correct answer. I am sorry about the trouble.
Message 32 of 33
symoin
Dear Sir,
Thanks for the routine, Can I request you update the code to give the coordinates easting and northing also along with these details.
Many thanks in Advance.
Message 33 of 33
CADaSchtroumpf
in reply to: symoin
@symoin  a écrit :
Dear Sir,
@symoin
It's easy to update the code with  coordinates Easting and Northing.
AutoCAD Inside the Factory
