angle defined by two points
Could someone please help/remind me how I calculate the angle defined by two points which I have
assigned to two variables - Point1 and Point2
George
Ranjit_Singh
(angle point1 point2)
This returns the angle in radians. I believe the angle is based on current UCS but I cannot verify at the moment. Also look into angtos for other formats.
Great thanks - you fixed my mental block 🙂
marko_ribar
(angle p1 p2) function don't work in UCS, but it calculates angle through specified coordinates no matter what current UCS is...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Thanks Mark,
Do you mean that it only works in the World UCS - not a user defined one?   How do you get around this limitation?
Regards
George from New Zealand
marko_ribar
@Anonymous wrote:
Thanks Mark,
Regards
I usually use (trans) function to obtain desired points from UCS to WCS or from WCS to UCS or alternatively to OCS or DCS - and only then, I, if I think that's correct way, use (angle) function... Note that angles obtained from (angle) are always {0.0-2pi} interval and 0.0 and 2pi radians are of those points that are left to right - vector is '(+XXX 0.0) - so (angle '(0.0 0.0) '(1.0 0.0)) = 0.0 (vector is '(+1.0 0.0))
john.uhden
If you want the angle in the WCS, then be safe...
(angle (trans Point1 1 0)(trans Point2 1 0))
If the UCS is the same as the WCS, then no transformation will take place,
so your result would be the same as
(angle Point1 Point2)
John F. Uhden
