Angle between two beams in Advance Steel
acbsdesign
Mentor Mentor
acbsdesign
I am looking for a LISP to measure the angle between two beams projected horizontally per the current UCS
- taking the system or physical end points X and Y ordinates and returns the angle.
Thank you.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Sea-Haven
Like others do not have Advanced steel so post a dwg so can have a look at objects.
pendean
Community Legend
Community Legend
Greetings @acbsdesign
Advanced Steel has a dedicated customization forum where everyone is actually using AS if you'd like to repost there https://forums.autodesk.com/t5/advance-steel-customization/bd-p/6114
I found a similar post there where you might wish to expand on too https://forums.autodesk.com/t5/advance-steel-forum/angle-between-two-beam/td-p/6372085
acbsdesign
@pendean
Thank you.
